#1 |
Member#: 61724
Vehicle:04 FXT silver |
I plan on getting a (or two) mechless head unit this coming Black Friday and wanted to know if the experts on here can give some advice on which to get. I will be at a Fry's store for the hunt and hope I will find what you guys suggest.
I guess my questions are: Is there a brand that took advantage of the free space and put larger amps to put out more watts per channel? If not, which single DIN would be a good one to get? Thanks
#2 |
Member#: 149752
Vehicle:07 wrx tr rr tuned stg2 12.9@103mph |
mechless?
#3 |
Member#: 99289
International
I'm totally lost, what are you looking for? A headunit, or an amplifier?
#4 |
Member#: 46500
Vehicle:2004 STi Sedan Now with 100% more bugeye |
I think he means "mechless" = fixed faceplate/screen etc.
If thats the case, you still really don't have lots of choices if you're going off of Black Friday sales, as they vary so much. More of a get-lucky kinda thing. However, i usually prefer JVC for their decent quality, single-DIN HU's that come with options like front+rear usb, Bluetooth, etc, all for very low prices (easily under $200 brand new). Just got the GF a new R900 for X-mas for her Acura, for example. Think I paid 180shpd. |
#5 |
Member#: 61724
Mechless head units are the ones without cd players.
#6 | |
Member#: 99289
International
Ahh, in that case:
As far as what to get? Select from: Alpine, Kenwood, Eclipse or Clarion, Avoid: Dual, Boss, Jensen or Blaupunkt. |
#7 |
Member#: 61724
Anyone here familiar with the mechless (cd mechanism less) units?
I'm just wondering what they did with all that free space. I have opened up cd head units and know that the cd mechanism takes up what looks like more than half the volume space of the housing. It would just seem to make sense to put larger amps in there. Thanks for the suggestions btw. Another question. I'm not into the big showy amp boxes. What is the smallest good quality amp made for cars? |
#8 |
Member#: 146104
RMIC
Vehicle:2002 wrx vf39'd silver |
i love the new alpine amps..pretty small in size, under rated on power and affordable
#9 | |
Member#: 99289
International
Adding an amplifier would be tough due to other constraints: heat and power availability. |
#10 |
You need a little Sony ES amp about the size of a pack of smokes. Dont put it in you head unit maybe behind it or behind the dash.
R- |
#11 |
Member#: 46500
yeah, if you need more than headunit power, or want some nice clean power for your quality speakers, you need to be thinking about wiring in a real amp anyway.
And now i am more edumacated. I now know what mechless is... ![]() |
#12 | |
Member#: 1026
Vehicle:00' RS/WRX Stg4 Mindless Self Indulgence |
Alpine has a few... No, they don't provide any more space or power for anything else... They may provide different functionality, but that's nothing more than additions to the CPU... The amps built into a CD player are roughtly 1"wx3/4"hx3/16"d regardless of brand... (obviously there would be SOME variation to this, but not much, I can assure you) But no, they don't put any more in.. They don't put out much... never have, never will... if it "claims" 50x4 you can bet it's 20x4 at BEST.. |
#13 | |
Member#: 61724
#14 |
Member#: 61724
This seems to be headed in the right direction:
"Additional power can be had by way of the upcoming headunit power pack, which boosts average power to 50 watts per channel, with an unstated max,..." http://reviews.cnet.com/in-dash-car-...l?tag=txt;page |
#15 |
Hey that will work But I think the power pack is a septate piece that does not live in the head unit.
It is small Upgrade your Alpine receiver to 45 watts RMS x 4 * 2-9/16"W x 1-1/2"H x 7-13/16"D If your interested in the power pack Crutchfield has a video showing how its installed. Good luck. R- |
#16 | |
Member#: 118209
Vehicle:2002 WRX Sedan |
here is why that would be a horrible idea! Every vehicle on the planet has either a 10 or a 15 amp circuit that powers the radio, and usually a couple other accessories. (There MIGHT be a 20 amp one out there, i've never seen one though) Anyway, if you had a head unit that had a 50 watt true power rating on 4 channels, you are talking at least 15 amps of current just for the amp portion. Ideally you would run a dedicated circuit from the battery for this monster, but the majority of people installing it wouldn't actually do that. So now you are either going to blow fuses on a regular basis, or some idiot is going to swap in a larger fuse (or a chunk of wire!) That brings up problem #2. Heat. 50 watts of audio output on 4 channels generates a non-trivial amount of waste heat. Head units are often right next to heating ducts, which makes the problem even worse. If someone managed to actually run that head unit, it would cook itself in a very short time. My current head unit has the typical small internal amps, and STILL needs a fan to cool itself. |
#17 | |
Member#: 61724
You gotta think outside the (???) head unit. Design solutions to these issues are not far fetched. I'll bet we'll see a nice powerful mechless real soon... Dual has a nice powerful one, but as some of you stated, it's the one to stay away from. It looks like Alpine is the only reliable mechless out there for the time being. |
#18 |
Member#: 229792
Vehicle:2010 WRX WR Blue |
Pioneer FTW!! Great headunits and small amps!
#19 | |
Member#: 99289
International
The dual one is only powerful because the play dirty with specs. |
#20 |
Pioneer did release a radio a few years ago with a more powerful amp. the DEH-P8MP. It was advertised as 60x4 and ended up putting out around 30 watts rms per channel.
You did have to run the constant power to a separate power source that could handle the higher current draw. (usually the 12 volt lead at the ignition harness would suffice) It never really caught on. I think they only offered the high power line for a year. Now what I would like to see is a double din unit with a higher power output. Like 40 or 50 watts per channel rms. It has to be do-able. Most of the basic double din units are super light so I bet there is a decent amount of empty space inside the unit. |
#21 | |
Member#: 118209
