Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 11-20-2009, 09:48 PM   #1
bluemicamatt
Member#: 220246
2007 WRX TR
Default Does straightening out bent TMIC cooling fins help?
I just noticed most of the visible fins on my tmic are pretty bent up.
is it worth the effort/time to straighten them out??
bluemicamatt is offline   Reply With Quote
Old 11-20-2009, 09:53 PM   #2
i_c_the_light
Member#: 88618
1990 JDM Legacy
RS-RA-GT White
Nope.
i_c_the_light is offline   Reply With Quote
Old 11-20-2009, 09:53 PM   #3
Unabomber
Amish Rake Fighting
Member#: 18062
is available for
purchasing
You would need a Cray computer and about 6 years of processing time to determine that it would net you .034% in efficiency that would net you .00000324 HP so you tell us.
Old 11-20-2009, 10:08 PM   #4
fastwrx25
Member#: 126441
02 bugeye
if you ever take off the tmic, flush out the inside and outside with degreaser, and use tweezers to straighten off the fins.
I don't know empirically how much it'll help but it does help efficiency. you'd be suprised how oily the inside of the tmic can get if its never been cleaned. The oil inhibits thermal transfer
fastwrx25 is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 11-20-2009, 10:12 PM   #5
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
^ was wondering what to use to clean out my tmic. So just regular engine degreaser?
happs subi is offline   Reply With Quote
Old 11-20-2009, 10:17 PM   #6
turb04
Member#: 61386
04 PSM WRX
Police Interceptor
deluted
turb04 is offline   Reply With Quote
Old 11-20-2009, 10:22 PM   #7
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Is Purple power diluted? I have a few gallons somewhere in the shed
Old 11-20-2009, 10:59 PM   #8
wrxdrvr
Member#: 79222
'09 STi Stage 1
Of course it will help... how much... is yet to be determined. Them Crays are starting to warm up.
wrxdrvr is offline   Reply With Quote
Old 11-21-2009, 07:55 AM   #9
alohakids4
Member#: 127764
Chapter/Region: HIIC
04 STI
i use simple green diluted with water...works great.
alohakids4 is offline   Reply With Quote
Old 11-21-2009, 08:48 AM   #10
CynicX
Member#: 48199
06 WRX
If its damaged enough it will help. If you are talking about just a couple fins then its not going to make a difference. However it does add up. You may want to take care of it now before it gets worse...
CynicX is offline   Reply With Quote
Old 11-21-2009, 11:14 AM   #11
bluemicamatt
Member#: 220246
2007 WRX TR
Good replies, many thanks. I have an Exacto knife kit with an ice pick attachment that works great to straighten the little fins. Amazing how fragile the metal is, as easy to bend as heavy duty aluminum foil it seems like. buttery soft!
Tomorrow I'm installing a new SS clutch line and will have the tmic off for a while.
About how long should I let it dry out IF i run some diluted degreaser through it? Also, is it OK to use tap water to dilute, or get distilled h2o??
Old 11-21-2009, 11:26 AM   #12
neko
Member#: 46500
2004 STi Sedan
Now with 100% more bugeye
Straightening the fins might not offer a huge improvement, but it doesn't hurt. Anytime I mount a used one one something (or if i sell one), i usually go over it and straighten them. They are very soft, you've got to have a light touch. Its not hard to do, just takes time...
As far as cleaning out the inside, its a good idea, but a better idea is preventing it from getting nasty again.
IC's get nasty because crankcase ventilation gets routed through the intake, pre-turbo.
Get yourself a catch can on any turbo car, and never worry about your IC getting clogged up again.
neko is offline   Reply With Quote
Old 11-21-2009, 11:27 AM   #13
dr3w
Member#: 222318
1993 JDM GC8 STi
Ovcourse it will help... in industrial intercoolers we use tools to undo them to make it quicker.
EX:
dr3w is offline   Reply With Quote
Old 11-21-2009, 11:50 AM   #14
reddoak
Dorothy
Member#: 147628
2008 DGM STI
I'll get you, my pretties
Don't run a high pressure hose through it if you flush it out....
As far as straightening fins, it's probably a minor help, if any. But it makes it look a bit nicer to have all straight fins, so go for it.
reddoak is offline   Reply With Quote
Old 11-21-2009, 01:09 PM   #15
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
I disagree with all the "experts" here. If you have a few fins bent, it won't make a notable difference. If you've got 3/4 of the fins bent, then yes straightening them out will definitely help.
CKxx is offline   Reply With Quote
Old 11-21-2009, 03:56 PM   #16
fogell
Member#: 219902
09 M3
Even if it doesn't help other than marginally, it definitely helps it look better if/when you show off your motor.
I used to dig the bugs out of mine with a thin knife. While minorly bent fins may not make a diff, I agree with the others on here that debris which can block air flow can and will.
fogell is offline   Reply With Quote
Old 11-21-2009, 04:37 PM   #17
CynicX
Member#: 48199
06 WRX
Who is the expert you are disagreeing with? I think we are all under the same impression as you. If there is just a couple it wont help, if there are a lot it will..
Old 11-21-2009, 05:49 PM   #18
dr3w
Member#: 222318
1993 JDM GC8 STi
X2 thats exactly what i have in my head :P
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:43 AM.
