#1 |
Member#: 198968
Vehicle:2008 WRX Lightning red mo****a |
Okay, so I wanted to try and change my maplights and domelights to White LEDs.
I bought the kind of bulbs where there's two metal wires(that's the best way I can describe it sorry) Coming off of the bulb. The Map+Dome light are 12V, so I bought 22-Ohm Resistors which is 1/2 watt or 5% tolerance(That's what the package said and the guy at radio shack told me what to use ). Here's the questions, I hooked up the resistor to the power wire and then the ground to the bulb and it's not working. I tried switching which metal wires they were connected to also. Can anyone tell me what I'm doing wrong?? I didn't wanna spend big bucks to buy the lights that just plug in as I thought I'd be able to do this myself. Thanks a lot everybody.
#2 |
you can just buy pretty cheap lights that directly plug in ...
#3 |
Member#: 198968
Well I already have them all so If I'm able to do it then that would be great... It really doesn't seem to hard, I just need a little info.
#4 |
Member#: 198968
And from fastwrx.com, the maplights and domelight would come to 100 bucks.... That's not what I would call "Cheap".
#5 | |
Member#: 100117
VIC
Vehicle:2002 Impreza 2.5TS Subie Heaven |
#6 |
Member#: 198968
Yea I switched the poles, that's what I was referring to when I said tried switching the meal wires. The specs for the bulbs are:
Forward Current- 20Ma Forward Supply- 3.5V(typical), 4.0V(max) |
#7 |
Member#: 198968
Ok I just tried it again and it flashed but then went out. I need a different resistor I think, can anyone tell me what size??
#8 |
Member#: 198861
SCIC
Vehicle:2004 WRX PSM |
i did my maplights, domelights, licenseplate, trunk, radio, hvac all for $25.
#9 |
Member#: 198968
Okay that's nice. Do you think you could explain to me how to do it??
#10 |
Member#: 50586
SCIC
Vehicle:2004 WRecked Black with dents & scrape |
OH yea I did my maplights, domelights, licenseplate, trunk, radio, hvac all for $24
#11 |
Member#: 211432
Vehicle:2007 Honda Accord Royal Pearl Blue |
#12 |
Member#: 106714
E. Canada
Vehicle:2003 WRX |
#13 |
Member#: 197363
BAIC
Vehicle:05 STi AW |
just got a set from autozone that are pnp for about 15 bucks.. did both dome n map lights..
#14 | |
Member#: 123843
NESIC
Vehicle:2006 WRX S2 230/300 Let LED's light your way! |
#15 |
Just put 4 of those LEDs in a series and be done with it. If you want a bit more output, add a second series of 4. If you do it like that, I don't think you'll have to bother with a resistor.
