Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 11-22-2009, 10:57 AM   #1
kcvpr
Member#: 228954
Default oil pressurte light?
so I was driving home from Jack in the box last night..... then out of nowhere after putting the clutch in to coast to a red light the motor dies , So im like wtf, and start the motor back up didn't hear any weird noises and go on my way, like nothing happend... well about a mile down the road theres a stop sign, as I am comeing to a stop the oil light comes on for a second and turns off So at this point I'm just down the street from my house, so I drive the rest of the way back... and shut the car off, pop the hood let it cool, and check the oil.
And FML its not even on the dipstick!
I'm not going to drive it till I change the oil and refill it....
Should i be worried????
Thanks for the help!
kcvpr is offline   Reply With Quote
Old 11-22-2009, 12:38 PM   #2
jigga
Member#: 9960
Yes, you should be.. Usually, if that oil pressure lamp comes on while you are driving, it is telling you that it is time for a new shortblock.. It comes on when you have close to no oil pressure left.
And since you kept driving when it came on.....
How often do you check your oil?
jigga is offline   Reply With Quote
Old 11-22-2009, 12:43 PM   #3
evan_impreza
Member#: 115276
04 PSM WRX
p&p fp 16g -- UTI tuned
Very very bad. Start saving for a new motor. Check your oil regularly!!
evan_impreza is offline   Reply With Quote
Old 11-22-2009, 01:13 PM   #4
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
your negligence caused you to kill your engine
More Hot Topics on NASIOC...
Old 11-22-2009, 01:20 PM   #5
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
Yea, sorry to be all doom and gloom about it, but the stock light come on when you are below 2.1psi... When cruising, you should be at something like 60psi, for reference.
As everyone has said, you should probably start saving some money. There is a chance it will still drive for some period of time (maybe a year, maybe 20 minutes) but I would bet my $1 that there is damage to the bearings.
CKxx is offline   Reply With Quote
Old 11-22-2009, 05:54 PM   #6
supersuby2
Member#: 161678
2002 wrx
white
Yeah i had this happen on a honda several years ago and though it did run afterwards the bears where toast and the motor needed to get rebuilt. All i can say is that in my case the light came on at high RPMs but only breifly. You could get lucky here but driving it with the light usually damages things fast. I have often wondered why even put the damn light in the car since its totally useless since once it come on its usually too late. Good luck though maybe it will work out for ya bud.....
supersuby2 is offline   Reply With Quote
Old 11-22-2009, 07:18 PM   #7
spinningcain
Member#: 176490
2004 WRX VF39
God damn CHECK YOUR OIL EVERY TIME YOU GET GAS....I can't believe how lazy people are
spinningcain is online now   Reply With Quote
Old 11-22-2009, 08:25 PM   #8
bigolrig
Member#: 185347
2002 Golfball wagon.
FBHIC-Peterbilt
Ruh Roe!
Check your oil! Subies eat it up
bigolrig is offline   Reply With Quote
Old 11-23-2009, 01:03 AM   #9
northpolerex
Member#: 192408
2002 wrx
Originally Posted by bigolrig View Post
Ruh Roe!
I don't want to thread jack, but how much oil is consummed every 3,000 miles ya think? My car has a slight leak, but I usually drop about a quart every time I change my oil. Think this is normal or a little excessive?
northpolerex is offline   Reply With Quote
Old 11-23-2009, 10:45 AM   #10
timmah
Member#: 54203
2004 WRX
JBP
it may be on the "Higher" side of what you'll find around here, but according to subaru, it's within specification.
i was using about a quart of 5w30. i switched to 5w40 rotella and now it consumes much less oil.
timmah is online now   Reply With Quote
Old 11-23-2009, 12:08 PM   #11
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
They consider up to 1qt/1000mi to be acceptable. That would be insane on any other car, but again, they say it's ok.
Just check your oil every time/every other time you get gas. That's what many of us do.
Old 11-23-2009, 12:56 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Wow, that's a lot.
My wife's 1.8L N/A Corolla eats almost that much (engine known for oil consumption + 180k miles) My WRX eats less than 1 qt per oil change at 148k miles.
Concillian is online now   Reply With Quote
Old 11-23-2009, 01:24 PM   #13
Longshot55
Member#: 164121
2005 WRX
2.0L EvoIII 16G
Rotella ftw, holds up nicely against high engine temps.
Longshot55 is online now   Reply With Quote
Old 11-23-2009, 04:59 PM   #14
bigolrig
Member#: 185347
FBHIC-Peterbilt
^^ correctumondo!
Rotella is meant for big turbo diesels, so it puts up with a little bit more of a beating then standard oil
Old 11-23-2009, 05:40 PM   #15
JVD
Member#: 213130
2002 WRX Wagon
Do not rely on your oil pressure SWITCH to tell you when you need oil.
It is NOT meant to act as a pressure gauge. It will come on when you have basically no oil. By then your motor is most likely pooched.
JVD is online now   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:36 PM.
