Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 11-24-2009, 10:14 PM   #1
vica153
Member#: 76586
1995 Impreza C.Green
Default Stuck Tail housing Removal
I finally got the pins out of the shift linkage and I thought I was home free, but noooooooooo...
All 9 bolts off and its only the 2 pins left holding it on. It will not budge at all and there aren't really accessible edges to hammer it off.
Whats the trick to this?
vica153 is offline   Reply With Quote
Old 11-24-2009, 11:25 PM   #2
theotherguy
Member#: 191514
2008 wrx vf39
05 FXT 6 spd,'00 RS 2.0T
The extension case that is attached to the transfer case? Hit the dowel pins with a punch and hammer from the transfer case side, the pins are attached to the extension case.
theotherguy is offline   Reply With Quote
Old 11-25-2009, 12:41 AM   #3
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
PB Blaster and a BFH
Old 11-26-2009, 02:04 PM   #4
PSolbergfan
Member#: 112612
2001 Impreza RS BRP
2002 Impreza WRX WRB
BINGO! +1
PSolbergfan is offline   Reply With Quote
Old 11-26-2009, 02:49 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
View Member's Myspace Profile
You need a knife!!! I normally use a rubber mallet and hit the side. It works all the time. Other times I use my sharp butcher knife to crack it open.
FuJi K is online now   Reply With Quote
Old 11-26-2009, 03:08 PM   #6
Storm
Member#: 5218
96L FSP project
98RS DSP
A combination of the above will definately persuade it to come apart. Knock the pins through after spraying the penetrant all around the seams and now empty bolt holes, then use a knife or stiff scraper tapped into the seam line to start the separation. Work your way around with more penetrant as you gradually use bigger tools.
Beer doesn't help the case come apart....but it makes you feel better while fighting it.
Jay
More Hot Topics on NASIOC...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:15 PM.
