Old 12-01-2001, 02:00 AM   #1
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Default What is this connector? (WRX stereo)
Make: Matsu****a (Panasonic?)
Model: 86201FC080 (Subaru part number, actually)
Reference Number: CQ-EF7910A
So what is the connector on the left?
(one on the right connects to the car)
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 12-01-2001, 02:02 AM   #2
WRXIN4IT
Member#: 12374
2002 Impreza WRX
ASPEN WHITE
im thinking that its for the sub/amp for under the seat every thing is pre wired just needs to be hooked in
WRXIN4IT is offline   Reply With Quote
Old 12-01-2001, 02:05 AM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Seems like a lot of pins for that.
Speaking of which, any of THIS stuff look familiar?
http://www.maco.panasonic.co.jp/maco...p08e/car3.html
Old 12-01-2001, 02:05 AM   #4
supersubee
Member#: 351
97 Legacy GT
could be output for amp, input for changer, or steering wheel controls. depends on what other cars use that radio. could be for inputs for a nav unit. it looks like the plugs for ford factory changers to be honest.
Kevin
www.subee-sound.com
supersubee is offline   Reply With Quote
Old 12-01-2001, 02:24 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Go to http://www.pasc.panasonic.com/epartr/
and enter CQEF7910A - you get a parts list!
No manuals listed though.
Glenn
Old 12-02-2001, 12:21 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
bump
Old 12-02-2001, 12:53 AM   #7
G-REX
Member#: 8804
2008 Impreza STi
Dark Gray Metallic
Don't know what it is but it's more likely that it's the sub woofer plug. It's not pre-wired though.
I just ripped apart my WRX today (seats, carpet, gauge cluster, console, and dash) and didn't see any pre-wiring for the stock sub. There was also another harness connector that was bundled with the stereo harness but not plugged in. Didn't even think to see if that would have fit in the receptacle.
G-REX is offline   Reply With Quote
Old 12-02-2001, 10:33 AM   #8
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
It's not for the sub. The sub for the MY02 WRX comes with a harness that fits between the right connector and the car's stock harness.
Rocky WRX is offline   Reply With Quote
Old 12-02-2001, 11:32 AM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
And to be clear, there is nothing existing in the car that plugs into this connector.
Glenn
Old 12-02-2001, 04:36 PM   #10
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
How about for the Satellite Navigation System/TV System as found overseas? I know from speaking with a gentleman with a grey market STi import in England that the Nav System connected to the radio on his STi 6. Granted, Japan uses a different set of radio frequencies than we do, but it's probably the same head unit with a different crystal for their frequencies. Just a guess .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 12-02-2001, 07:35 PM   #11
cantex
Member#: 9611
Default one is not used
when you hook up the sub, you use the plug with more pins, the other one remains unused
cantex is offline   Reply With Quote
Old 12-02-2001, 08:20 PM   #12
lgkahn
Member#: 9793
2002 2010 legacy gt
red
speaking of plugs anyone have the plug for the subwoofer lying around unused.. I bought a subwoofer from someone but the connector was for an aftermarket head unit.. thus cannot use it easily in my wrx.
or save that anyone know the part number for the connector that comes with the subwoofer kit.. either from subaru or panasonic.
thanks
lgkahn is offline   Reply With Quote
Old 12-04-2001, 01:43 PM   #13
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The service manual for the stock head unit from Panasonic is $6 ish + tax + shipping.
I ordered one.
Glenn
Old 12-04-2001, 02:02 PM   #14
lgkahn
Member#: 9793
2002 2010 legacy gt
red
can you post the part number and where you got it from ..
thanks
Old 12-04-2001, 02:30 PM   #15
Buford T Justice
Member#: 8857
While what I am offering has already been posted, I found some useful info at the subarparts.com site. As mentioned by previous replys, the sub hookup plugs in between the existing wiring connector and the 14-pin receptacle on the right hand side of the radio (orientation via Glenn's picture). This info can be found in the installation instructions for the subwoofer which are posted on the subaruparts.com site....There are install instructions for all sorts of stuff. Just find the part that you want to purchase and there should be a link to a .pdf for the install instructions.
Buford T Justice is offline   Reply With Quote
Old 12-04-2001, 06:53 PM   #16
lgkahn
Member#: 9793
2002 2010 legacy gt
red
as I said before IU have the subwoofer kit and the instructions but apparently the guy I bought it from they hacked it and didin't have the factory cable and cut the wire instead..
ie mine has a connector into the subwoofer that goes to 4 wires
cut - fuse and power, ground and right and left channel.
I do not want to install it in this hacked manner and cannot find a part number fora the correct connector that is supposed to come with it as per the install instructions.
Old 12-04-2001, 10:50 PM   #17
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I ordered the manual from Panasonic. No part number, just called 800-833-9626 and asked for the manual for CGEF7910A.
They only had one. Dunno what the wait will be now.
Boy, I'm really hogging the WRX documentation; first the shop manual supplement, now this.
For the guy missing the sub cable, call Subaruparts and see if they have the p/n for the cable by itself. It isn't in the instructions.
Glenn
Old 12-06-2001, 10:34 PM   #18
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The answer from the Panasonic service manual which arrived today:
This 16pin connector is for an external CD changer!!!!!!!!!
I guess 6 CDs isn't enough!
It has L+R inputs, mute, bus signals etc.
You use the "CD" button to roll between the internal changer and external. I assume it must detect it first on the bus. I assume it must be a Matsu****a/Panasonic changer.
Pity. You could use these external inputs for something.
Glenn
Old 12-07-2001, 01:08 PM   #19
iouri
Member#: 9412
2002 WRX Wagon
I wonder if you'll use a 10 disk changer, how would you select disks # 7-10?
iouri is offline   Reply With Quote
Old 12-07-2001, 07:38 PM   #20
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I was wondering that myself. Suspect it only really supports +6, based on the display and keys. No mention in service manual.
Glenn
Old 12-07-2001, 07:44 PM   #21
SubEd
Member#: 717
With the Pioneer 12 disc changer, buttons 1-6 select those CD's. Push and hold button one selects CD 7, etc....
SubEd is offline   Reply With Quote
Old 12-08-2001, 12:38 AM   #22
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Looking at the display, there may be other (>=7) LCD elements there.
Old 12-09-2001, 12:10 AM   #23
Cavic
Member#: 13143
Default Specs on Head unit
Can you share any relevant specs from the manual you ordered for the factory radio such as watts RMS?
Thanks
Cavic is offline   Reply With Quote
Old 12-09-2001, 12:35 AM   #24
jlw
Member#: 12654
02 WRX Sdn, 2.5L
Element Tuning GT65r/hdrs
How about a function table of the connectors ... or at least which pin is "mute"? My Nokia hands free cell phone cradle can use it to automatically mute the radio when a call is received.
Also, what are the specs. for the mute line? Mute when grounded I'd guess.
jlw is offline   Reply With Quote
Old 12-12-2001, 09:42 PM   #25
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The other thread on this connector has the pinouts, as discussed.
Re specs of stock head unit:
General:
Power Supply: DC 12V (11V ~ 16V), Negative ground, Test voltage 13.2V
Current Consumption: Less than 2.5A (max vol)
Power Output: 25W x 4ch (no statement about RMS or not)
Output Impedence: 4 ohms.
AM Radio:
Frequency Range: 530 ~ 1710 kHz
Usable Sensitivity: 26db (uV) S/N 20dB
FM Stereo Radio:
Frequency Range: 87.7 ~ 107.9 MHz
Usable Sensitivity: 6dB (uV) S/N 30dB
Cassette Player:
Reproduction system: 4 track, 2 program stereo.
Tape speed: 4.76 cm/s
Wow and flutter: < 0.2% WRMS
S/N Ratio: 55dB
CD Changer
S/N Ratio: more than 68dB IHF-A
THD: < 0.4%
Channel Sep: 62dB IHF-A
Dimensions: 178W x 100D x 174H mm
Weight: 2.7 kg
What is this connector? WRexxer Electrical & Lighting 1 06-20-2006 09:23 AM
What is this connector for? subysouth Transmission (AT/MT) & Driveline 6 09-27-2004 01:35 PM
What is this connector? (photo) 66666 Electrical & Lighting 0 08-12-2004 09:15 PM
What is this connector, and why is it unplugged?? Kwyjibo Electrical & Lighting 7 09-24-2003 01:21 AM
What is this connector called ? brunetmj Car Audio, Video & Security 3 06-14-2002 12:12 PM
