Closed Thread
Old 12-30-2001, 06:14 PM   #1
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Default Rear door speaker install photos
veloLexus inspired me to dig these out and post them. Each is resized/compressed to fit under 50k, but (oh great Moderators) if the total space (or usefulness!) is a problem, let me know and I'll try to find someplace to post them on a different server.
These are photos of my rear door install (these are all of right rear door) of DEI Studio 3045s (4" 'woofer' + neo tweeter) in place of stock (non-upgraded) speakers on MY02 OBS. I next plan to dynamat (or equiv) the openings that you can see in the inside metal door panel.
Hopefully, some of these will help out people thinking about changing their rear door speaker setup.
Photo 1: Stock door panel, removed. Note cavity under armrest suitable for mounting crossover.
armand1 is offline
Old 12-30-2001, 06:18 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 2: Passive crossover glued in place (Marine Goop), speaker area masked off and sprayed w/Cascade Audio VB-1s.
armand1 is offline
Old 12-30-2001, 06:20 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 3: Masking removed, crossover cover attached, tweeter hole drilled and tweeter flush-mounted. Tweeter wiring connected to crossover (with disconnects installed mid-wire).
armand1 is offline
Old 12-30-2001, 06:22 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 4: View of passenger side of door panel at this stage.
armand1 is offline
Old 12-30-2001, 06:23 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 5: Interior of door w/panel removed, and stock 4" speaker removed.
armand1 is offline
Old 12-30-2001, 06:30 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 6: DEI 4" 'woofer' mounted in stock mounting ring. Note 3 pairs of holes on outside; one from each pair is used to screw the stock ring to the door (see later photos). The 4" DEI was almost too small for this mounting ring (hence people reporting they fit 5 1/4" speakers in back, with some enlargement of the door's metal opening); I used the sticky foam gasket that came with the speaker to bridge the gap between inner edge of mounting ring and outer edge of speaker. I also had to dig up some washers for the 4 inner mounting screws to make sure all 4 tabs of the DEI speaker were held down securely. See next photo for back view of this.
armand1 is offline
Old 12-30-2001, 06:33 PM   #7
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 7: Back view of DEI 4" woofer mounted in stock mounting ring. Note protective rain/water shield extending out from back of mounting ring almost 270 degrees around. Note also thin strip of foam outside this shield to fill any gaps between door metal and speaker mount.
armand1 is offline
Old 12-30-2001, 06:38 PM   #8
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 8: Closeup of speaker mount opening in rear door, with the 3 screw points circled. (The black circular pad inside the opening, glued to the outer metal panel is Cascade Audio 5" Deflex) You can also see the stock location of the OEM speaker wire.
armand1 is offline
Old 12-30-2001, 06:39 PM   #9
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 9: 4" DEI woofer installed in door. OEM speaker wire has been pulled out and rerouted throug slit in clear plastic, facing toward back (it will plug into short pigtail with matching connector coming out of crossover mounted in door panel). Woofer wires were routed through same metal hole as OEM speaker wire, and out same slit in plastic. Disconnects were soldered on the ends, and these will plug into short pigtail with matching disconnects from woofer side of crossover.
armand1 is offline
Old 12-30-2001, 06:41 PM   #10
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 10: View of inside of door panel with pigtails attached to crossover (see photo 9 for pigtail info). Photo 11 has closeup view of crossover and pigtails. Foam tape was wrapped around middle of tweeter wires to prevent rattling noises.
armand1 is offline
Old 12-30-2001, 06:44 PM   #11
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 11: Closeup view of crossover with pigtails for OEM speaker wire and for woofer wire disconnects.
armand1 is offline
Old 12-30-2001, 06:47 PM   #12
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Photo 12: Door panel about to be put back on door. Speaker pigtails have all been connected to wires from door, but power window connector has not yet been attached.
armand1 is offline
Old 12-30-2001, 06:48 PM   #13
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
That's it for now, folks! Hope these prove helpful.
armand1 is offline
Old 12-30-2001, 08:34 PM   #14
veloLexus
Member#: 4920
2002 WRX Sedan
Plain old blue!
Great pics, gives me a few ideas. Thanks for posting them. Does the spray on vibration damper make a big difference. I'd like to quiet down the WRX a little bit but I thought it would be a chore. A spray on would certainly be easy and if it made a big difference I'd pull the rear door panels off as well while I'm doing the front speaker install. Did you do anything to waterproof the crossover and what's "Marine Goop"? I'm assuming I can get it at a marine store .
Thanks, Joe
veloLexus is offline
Old 12-30-2001, 09:25 PM   #15
Tomnel
Member#: 12625
MY02 WRX Impreza
Great stuff! so much information there.
Can wait to get started on mine.
Tomnel is offline
Old 12-30-2001, 11:43 PM   #16
hman
Member#: 3747
2002 Impreza WRX
Platinum Silver Metallic
Great info and pix. Now I can get going on my rear speakers project with all of this information.
Thanks.
hman is offline
Old 12-31-2001, 02:29 AM   #17
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
veloLexus,
I only used the spray-on damper because I was concerned that the relatively lightweight plastic of the woofer grille/tweeter mount area might rattle (and the spray-on was fairly cheap -- looks like 1-2 cans for two coats on all four doors). I don't think the spray-on will do anything for general noise from the outside, especially after seeing the big size of the openings in the inner metal door panel! I'm going to put dynamat equivalent (VB-2) all over that inner metal door, in place of the clear plastic liner, to try to cut down on that noise.
I thought about waterproofing the crossover, but thought that not blocking its air vents was important, too. Besides, (a) it's sheltered a bit under the armrest indentation and (b) it's on the "dry" side of the clear plastic line (or VB-2 once I get that installed).
Finally, adhesives were surprisingly a major decision. It turns out that epoxies do not do that well at cold temps (under freezing), and since I'm living near the ice belt, I figured I'd avoid that. www.thistothat.com gives a fair amount of useful advice about how to glue "this to that". They recommend the "Goop" brand of solvent-based silicone adhesives as really good stuff.
For the crossover to plastic door panel mounting I chose Marine Goop. According to the package for "Marine Goop" (oriented slightly more toward wet/damp uses), once dry/cured it can handle -40F to +150F temp, and it's waterproof and slightly flexible (thus the crossover won't suddenly "snap" off of rigid dried adhesive due to shock or slight temp-caused size changes). Since the door panel was slightly curved, I just made a big puddle of way too much goop and plopped the crossover down into, pressing it hard against the armrest corner.
To attach the rubbery Deflex disks to the outer metal door panel, I chose Permatex "Pit Crew's Choice Adhesive & Sealant" which is designed to reattach loose trim as a contact adhesive. I spread some out on the metal door panel and "rotated" the Deflex disk onto it. Supposed to be non-toxic; milky white but dries clear.
I bought the Marine Goop at Home Depot and the "Pit Crew's Chioce" at my local auto parts store.
armand1 is offline
Old 12-31-2001, 04:37 PM   #18
Martin Ritchie
Member#: 6771
2002 WRX WagonSilver
04 WRX Sedan Red
Thanks again for the pictures and instructions. Very helpful.
Martin Ritchie is offline
Old 05-23-2003, 02:46 PM   #19
SBC2night
Member#: 36556
2003 WRX Wagon
Howcome most of the pictures are gone?
SBC2night is offline
Old 05-23-2003, 03:26 PM   #20
RedBean
Member#: 23132
2004 Impreza WRX STi
World Rally Blue Pearl
Maybe because the post was from a year and a half ago?
RedBean is offline
Old 05-23-2003, 10:11 PM   #21
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Because when NASIOC split off from the unnamed other, a lot of the old pictures were lost/dumped to save disk space. Also, new posts can't include photos anymore for the same reason (but they can include links). It's a bummer, but then again we don't have to pay for NASIOC, so it's not our decision.
armand1 is offline
Old 05-28-2003, 07:26 PM   #22
ent2b
Member#: 36293
03 OBS
PS
who is the unnamed other? I-club?
ent2b is offline
Old 07-31-2003, 04:56 PM   #23
okiedude
Member#: 37736
2003 WRX Race Wagon
The Voldemort of the Subaru world
okiedude is offline
Old 09-14-2003, 04:52 AM   #25
Doughboy
Member#: 27398
2002 Impreza
Doughboy is offline
Closed Thread
installing front and rear door speakers on my 05 WRX g_$ Car Audio, Video & Security 7 04-23-2009 12:29 PM
rear door speaker installation (and front tweeters)? SeaRex Car Audio, Video & Security 3 06-11-2006 11:04 PM
Rear door speaker install ppierce04wrx Car Audio, Video & Security 3 05-19-2005 01:07 AM
Rear Door Speaker install/mod questions Aflaedge Electrical & Lighting 1 10-04-2004 01:45 PM
Rear Door speaker install, and measurements Rally1 Car Audio, Video & Security 0 11-28-2003 08:22 PM
