Old 03-12-2002, 04:58 AM   #1
korpse
Member#: 15386
Default DIN Pocket
Can someone post a link to a site where I can order a DIN sized pocket that will mount in the OEM cage on a 2002 WRX? I just replaced the stock radio with a Pioneer Premier 740MP and now I have a big gap in my dash! Thanks in advance!
-Kory
korpse is offline   Reply With Quote
Old 03-12-2002, 06:31 AM   #2
SubEd
Member#: 717
Pick one up at your local Best Buy, Circuit City, or stereo shop. Cost me about $14.
Ed
SubEd is offline   Reply With Quote
Old 03-12-2002, 08:00 AM   #3
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
I was looking at buying one for my car as well. I looked at Circuit City and Tweeter and they both showed me a cubby that would have to be modified a little to fit properly.
The best solution is to pick one up at your Subaru dealer that is made to fit the 2.5RS with a single din radio.
bobgrice is offline   Reply With Quote
Old 03-12-2002, 12:38 PM   #4
FoRCeFeDWRX
Member#: 12624
2002 Impreza WRX
Hey...The universal DIN size pocket is made by Metra (Model No. 88009000) for $15, or you can go to your local subie dealer and pick up a pocket from a Legacy which has a little cover you can open and close...
Ian
FoRCeFeDWRX is offline   Reply With Quote
Old 03-12-2002, 01:23 PM   #5
lenyx
Member#: 8221
2011 Legacy 2.5i Ltd
Hey speaking of the legacy pocket.. how does that thing work anyway? Does the cover just hold itself open? Or do you have to manually hold it? Does it slide in? Pop off?
Thinking of hacking one and sticking my AVC-R in there.. if it'll fit my needs.
lenyx is offline   Reply With Quote
Old 03-12-2002, 07:08 PM   #6
korpse
Member#: 15386
Ed
I stopped in a Best Buy, Circuit City, and a local stereo shop today. None of them had a pocket that would fit a 2002 Impreza. Does anyone know a website where they sell these?
Old 03-12-2002, 07:12 PM   #7
korpse
Member#: 15386
Ian
I found a site ( http://shop.store.yahoo.com/audiosto...ersalkits.html ) that sells the Metra pocket for $19. Will this fit my 2002 WRX without any modifications? Thanks.
-Kory
Old 03-12-2002, 07:31 PM   #8
Spooled
Member#: 14958
1991 318is
check out summit racing's website. They have a universal SIN pocket made by blitz that will fit a gauge and has 2 slots for turbo timers and boost gauges or whatever. Check it out, I'm interested in it too. I forget the part number though.
Spooled is offline   Reply With Quote
Old 03-12-2002, 11:21 PM   #9
ellisz
Member#: 15870
2015 WRX
Ice Silver Metallic
Default pocket
I talked to my salesman and he gave me a pocket for free. I told him I had heard that they might have some laying around. He checked with the parts dept. and gave it to me
Mike
ellisz is offline   Reply With Quote
Old 03-13-2002, 12:11 AM   #10
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
The pocket for the legacy, imprezza and forrester are all the same fit. go to a junkyard or a subaru dealer and you can get one easy without having to modify it. The 6 cylinder legacy that has the traction control has a pocket with a button built into it and there is a pocket with a door in some cars but I don't know which models...
Go to a junkyard and get one for $5 - $10. And recent subaru model...
janikphoto is offline   Reply With Quote
Old 03-15-2002, 06:46 AM   #11
ppek
Member#: 15349
2002 Impreza WRX
Default DIN Pocket with Door
I just got the Legacy DIN pocket from Subaru. It is supposed to fit without modification into the WRX opening. It appears to be constructed pretty good and the door has a quality feel to it.
The subaru part number is 66120AE050 and it was $18.87 from subaruparts.com. I know that is a little more expensive than some of the generic ones out there, but I did not want to mess with modifying it, and I wanted the clean looks of a cover.
I have taken a picture of it, but I have never posted anything with a photo. I will try to figure it out and post it here.
Paul
ppek is offline   Reply With Quote
Old 03-15-2002, 07:17 AM   #12
ScoobieBoy
Member#: 2681
2002 WRX Wagon-sold
2015 WRX-sold
Default Looks good...
How good a match is that cover to the rest of the WRX dash color? Looks pretty good; post some pics when you get it in.
Lance
ScoobieBoy is offline   Reply With Quote
Old 03-15-2002, 08:51 AM   #13
lenyx
Member#: 8221
So Paul... can you tackle this question for me? Is the door easily popped off?
Old 03-15-2002, 11:07 AM   #14
Fubaru
Member#: 6046
'08 Prius
lenyx - why not just get the doorless version in the first place
#66128AE000
It's definitely a ripoff at $20 but it fits the stock bracket alright.
I considered somehow mounting the AVC-R with it, but no dice - pocket's too small. Without the pocket the AVC-R actually just squeezes into the space above (or below) a single DIN. I ended up not doing that and just leaving the AVC-R sitting in that tray area by the shifter.
Fubaru is offline   Reply With Quote
Old 03-15-2002, 11:52 AM   #15
lenyx
Member#: 8221
#66128AE000
Well I was planning on hacking the pocket a bit to make the avc-r fit and I kinda liked the idea of having the door to hide it while parked. I guess I could probably just make something as I'm gonna have to build a plate for it anyway.
Old 03-15-2002, 12:43 PM   #16
ppek
Member#: 15349
2002 Impreza WRX
The door on the bracket is spring loaded, with a small button by the pull. When you push in the button, the door flips up from the springs. You can pull the tabs outward on the door and it would probably come off, but I don't think that would happen in day to day use.
Why the question on whether the door comes off? I looks pretty durable. If you don't want the door, you can get the one from the Impreza RS that is just a pocket, which is cheaper.
Paul
Old 03-15-2002, 01:09 PM   #17
lenyx
Member#: 8221
I figured if the door swung up I'd probably want to be able to quickly remove/attach it to cover up my avc-r... because even if the door held itself open it'd probably block visibility.
Looks like I'm just gonna build myself something.. thanks anyway.
Old 03-15-2002, 04:51 PM   #18
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
I also have the legacy pocket. works great!
If youre lucky your local subaru dealer will have these lying around and will give to you free =)
Orbiter is offline   Reply With Quote
Old 03-15-2002, 05:53 PM   #19
well_armed
Member#: 15204
Is that the JVC Mp3 unit?
What is that thing in your power outlet? a disco ball?
well_armed is offline   Reply With Quote
Old 03-16-2002, 01:06 AM   #20
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
haha
no thats an Alpine 7965
and the disco ball is a Jellyball (air freshner) =)
Old 03-16-2002, 06:22 PM   #21
korpse
Member#: 15386
Just to update anyone that cares, I got my hands on a Metra universal pocket (Model No. 88009000). It installed easily with no modifications and it looks great!
Old 03-17-2002, 11:36 AM   #22
cwb124
Member#: 15571
2006 06 Forester XT
Can you tell me where to get that metra universal pocket? I can't track down exactly what you're talking about. Website or number where I can order it would be appreciated. Thanks,
CB
cwb124 is offline   Reply With Quote
Old 03-17-2002, 03:13 PM   #23
korpse
Member#: 15386
CB
This place has them for $13.50 http://www.partsexpress.com/pe/showd...=6604&CATID=35 . It doesn't mention being compatible with Subarus, but trust me it is.
Old 03-17-2002, 04:27 PM   #24
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Yep, I got one for free from my dealer like Orbiter did. Plenty of these out there, no need to buy one.
Check the members forum for a pic in my dash.
Paul
Snowphun is offline   Reply With Quote
Old 03-26-2002, 04:55 PM   #25
ccbad
Member#: 16512
Gone WRX Wagon
Currently: F80
I just got one of those Din pockets with the door and for some reason, the Trim ring won't snap into place with the pocket installed! Btw, I have the pocket installed in the upper portion of the double din. It seems that I need to trim the sides fo the pocket for the trim ring to fit, or am I simply doing something wrong?
ccbad is offline   Reply With Quote
WTB: Radio pocket / DIN pocket SC2000 Private 'Wanted' Classifieds 1 02-20-2008 10:45 AM
FS: DIN Pocket / Blank DIN Spacer & 06 Ashtray johnso156 Interior/Dressup/Audio & Security 32 02-13-2007 05:31 PM
Will these DIN pockets work to install a single DIN Player? roksax Car Audio, Video & Security 20 01-06-2007 11:01 AM
2005 WRX: Can I get single DIN head unit + DIN pocket? Also, wiring same as 2004? grue Car Audio, Video & Security 0 11-08-2004 06:44 PM
WTB: Silver Subaru Radio DIN Panel or DIN Pocket STI 2 NV Private 'Wanted' Classifieds 15 10-31-2003 11:35 PM
