Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 04-07-2002, 07:05 PM   #1
Subaruman03
Member#: 15298
2002 Impreza WRX
Badass Midnight Black
Default Turbo timer w/factory alarm
Does anyone know if the blitz turbo timer works in conjunction with the upgraded alarm from subaru or does it cause it to go off.
Thanks
-David
Subaruman03 is offline   Reply With Quote
Old 04-07-2002, 10:21 PM   #2
krave
Member#: 13908
2002 WRX Sedan
296 whp
You have to cut two wires...check this thread
http://www.i-club.com/forums/showthr...hreadid=167030
krave is offline   Reply With Quote
Old 04-07-2002, 11:01 PM   #3
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Talking Works
Yup, it works like a charm.
KwanDDS is offline   Reply With Quote
Old 04-09-2002, 04:09 AM   #4
WRX Power
Member#: 7142
Does this also go for enabling the factory keyless entry (not security system) to work w/ a timer?
WRX Power is offline   Reply With Quote
Old 04-09-2002, 08:13 AM   #5
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Default Yes
I believe it works for the keyless entry setup as well. You probably have one less wire to cut.
Old 04-16-2002, 06:35 PM   #6
GoodFinder
Member#: 8943
2006 MINI + Corvette
Both Blue
If you are interested, I have an HKS Turbo Timer (with the WRX harness) for sale (new, never installed) in the Private 'For Sale' Classifieds. You can click on this link WRX Goodies for Sale for more information.
Regards, GoodFinder
GoodFinder is offline   Reply With Quote
Old 04-17-2002, 11:42 AM   #7
BlueRidgeRS
Member#: 1953
2002 WRX SportWagon
Platinum Silver
I'm not sure if this will work on the Blitz timer but since they use the same HKS wiring harness it's worth a shot.
HKS type-1 install
BlueRidgeRS is offline   Reply With Quote
Old 04-17-2002, 01:11 PM   #8
krave
Member#: 13908
2002 WRX Sedan
296 whp
The blitz doesn't tap into ECU wires as the HKS does. Follow the instructions for the blitz on the link I posted above, follow those instructions if you're getting an HKS
Old 05-18-2002, 11:39 PM   #9
DjRez4
Member#: 18155
1985 4runner
AWD Pirates, Unite!
Default security dash light?
I already posted this elsewhere, but this looks like a good thread to place it in too...
My dash light for the security system is flashing two flashes constantly whether the car is on or off. it has never done it before and i've had my HKS type-0 timer installed for at least two weeks now.
what caused this and how can i fix it?
-Dave
DjRez4 is offline   Reply With Quote
Old 01-04-2003, 07:31 PM   #10
DtownIan
Member#: 31447
'82 Volvo 245
turbo/intercooled/4-spd
Default What about an Apex Auto?
I've been reading the posts that deal with the HKS wiring harness. I'm using this harness in conjunction with my APEXi Auto Timer. The upgraded security system doesn't work when the timer is on. Do I use the sames steps suggested above, or can I not correct the problem?
DtownIan is offline   Reply With Quote
Old 01-04-2003, 09:38 PM   #11
-=Ice-T=-
Member#: 30956
holy shlt...8 month bump
-=Ice-T=- is offline   Reply With Quote
Old 04-07-2005, 08:26 PM   #12
409Industries
Member#: 55553
2004 WRB STi
2001 Black RS
Bump for the answer to this as i am interested too.
409Industries is offline   Reply With Quote
Old 06-12-2005, 05:50 PM   #13
Absubtle
Member#: 85862
-Dave
My wife has a 03 Forester XS and her security LED has done that since we picked it up from the dealer new w/ 7 miles on it. I am not sure if this helps or not, but it did take a couple of days before I noticed it blinking after parking it in the dark garage.
BTW-all we have on it is the standard keyless entry.
Absubtle
PA
Absubtle is offline   Reply With Quote
Old 06-13-2005, 04:12 PM   #14
Tanj!
Member#: 9339
2005 Forester XT
80, 86, 87, and 88 RX-7
Sounds like you're in valet mode. Open the drivers door and press and hold the unlock button for two seconds. The security light should now flash a single time every few seconds.
Tanj! is offline   Reply With Quote
Old 06-13-2005, 04:33 PM   #15
v8killer2pt5
Member#: 62275
2004 Sti
Is anybody located in Queens, NY that can come on over and help me trouble shoot this??? I have a blitz tt and need to arm the autopage alarm the dealer installed while the car is running.
v8killer2pt5 is offline   Reply With Quote
Old 06-16-2005, 01:37 PM   #16
bdcz2
Member#: 39790
2004 WRX Sti
Default STI alarm with TT
Let me just say that I HAVE searched for this, and yes, I know that I DONT NEED a turbo timer in the STI. So no need to attack me on these points.
I was wondering if anyone with a turbo timer currently installed in their STI has a functioning security system. I have the Apexi turbo timer and although I can lock the doors, I cannot arm the security system.
Things I've tried:
cut the dark green/black wire from the keyless entry box (above fuse)
cut the dark green/black wire from the security box (behind glove box)
screaming at it
Still no alarm
Any help would be greatly appreciated
-Chris
bdcz2 is offline   Reply With Quote
Old 04-02-2007, 02:55 AM   #17
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
06 with same question - which wire behind the glove box? I have found something labeled shock sensor - i have seen pictures of the box labeled subaru security that resides under the ebrake cover - this doesn't appear the same. Does anyone know which box/ location relative to dash/ which wire actually allows proper alarm function for the 06 STi ? Thanks -
joe-6STi is offline   Reply With Quote
Old 10-18-2007, 06:40 PM   #18
skibum761
Member#: 68354
2006 STI
I'm wondering the same thing about the secuirty module. where exactly is it located. can anyone take pics?
skibum761 is offline   Reply With Quote
Old 04-06-2008, 02:52 PM   #19
davidmount
Member#: 173026
2003 WRX
I have an Apexi turbo timer with the HKS harness in my 05 STi, the shop that installed it for me told me I couldn't arm the car while the timer was counting down. Tried to once just to see, and they were right. The stock Subaru alarm won't let you, you can lock the doors, you just can't arm the alarm. The 3 parts - alarm, harness and timer just don't allow for it.
davidmount is offline   Reply With Quote
Old 07-07-2010, 02:22 PM   #20
btothefnrock
Member#: 237978
02 WRX
Bump from forever ago- anyone still have the directions as to which wires to cut/splice? Mine is in an 02 WRX with keyless/security. Original link up there doesnt work...
btothefnrock is offline   Reply With Quote
Old 07-07-2010, 02:39 PM   #21
inthenameofweez
Member#: 201374
2004 Broken down
slow ass wagon
Don't bump an 8 year old thread.
Search.
inthenameofweez is offline   Reply With Quote
Old 07-08-2010, 01:04 AM   #22
btothefnrock
Member#: 237978
02 WRX
Why is there always the azhole that knows the answer to a question, looks at the thread, then actually wastes their time posting just to say "search you noob, lol" instead of "Its on XYZ Forums"
Thanks for your great wisdom sir...
by they way, how do you think I came across an 8 year old thread- wow- maybe by a search...
anyways, does anyone know where I can find the info now?
Old 07-10-2010, 12:20 PM   #23
btothefnrock
Member#: 237978
02 WRX
12) Above the fuse panel, there is a black Keyless entry module. Remove this - 1 10mm bolt.
13) Find the dark green w/ black trace wire and cut it. Tape both ends and bolt the keyless entry module back where it came from.
14) On the security system module (located on the drivers side of the parking brake) find the gray wire and cut that, taping both ends.
from the bible- http://www.northursalia.com/modifica...ain/tt/tt.html
Is this correct for my Blitz? i dont just want to start cutting wires.
Old 07-11-2010, 01:26 AM   #24
my name is joe
Member#: 171412
Search.
the whole point of searching is to find an old thread that has discussed it, like this one. thanks for telling the bumper something he has already done. and since you have so much time to go through the thread and make a comment how about making use of yourself FIND the thread that solves this and post it?
i have a blitz turbotimer and my factory alarm seems to arm and lock but aftermarket alarm cannot while the car is still on..
my name is joe is offline   Reply With Quote
turbo timer and factory alarm scrmblr2 Newbies & FAQs 7 09-18-2002 06:51 PM
Turbo Timer and Factory Alarm KIMUTAKU Newbies & FAQs 7 07-26-2002 05:00 PM
Turbo Timer w/Factory Alarm,Possible? sc00by71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 02-08-2002 11:12 AM
HKS Turbo Timer & Factory Alarm - wires cut but.... wy_wrx Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-21-2001 07:47 PM
Turbo Timer with Factory Alarm wildguineapig Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-16-2001 09:12 AM
