Old 04-18-2002, 12:44 PM   #1
aphex twin
Member#: 10426
Midnight Pearl Black
Default rust on rotors
i just noticed my rotors are starting to rust. obviously not where the brake pads make contact, but on the inner part where it comes out for the rims to sit on. is it safe to use a brillo pad or some fine sandpaper to sand it off and primer it? or do i have to use a special paint? TIA
aphex twin is offline   Reply With Quote
Old 04-18-2002, 01:22 PM   #2
hunter001
Member#: 12153
4EAT WRX Wagon Silvr
Acura 3.2TL w/Navigation
Default Re: rust on rotors
I think rust occurs on every car that I have known of, including my in-laws' Mercedes S500, my Acura 3.2TL etc. It is not something that we need to be worried about, I would suppose ?
Later...AH
hunter001 is offline   Reply With Quote
Old 04-18-2002, 01:24 PM   #3
Tkacik
Member#: 847
'06 Titan Crew Cab
'08 Forester LL Bean
Yeah, look at your rotors after a good rain. They will be rusty. It all gets scraped/burned off as you drive.
Tkacik is offline   Reply With Quote
Old 04-18-2002, 01:58 PM   #4
romanom
Member#: 16215
2002 WR WRX wagon
Are you talking about the rotor hat?
romanom is offline   Reply With Quote
Old 04-18-2002, 02:13 PM   #5
aphex twin
Member#: 10426
the rust is NOT where the brake pads leave the wear mark. its the inner portion where the studs for the rims stick out. that is the area where it rusted. its so very visible with the wheel on. if i find a pick of a rotor, ill show you what i mean
Old 04-18-2002, 02:31 PM   #6
romanom
Member#: 16215
2002 WR WRX wagon
Yeah it's the hat.
This can be OK if it's just light surface rust. If it's flaking you have an issue.
The surface that contacts the wheel is basically protected from the outside world so it will rust very slowly. In that area the coating gets abused by just mounting the wheel. Then a bit of water gets in there and you get a light surface rust.
Piics would be helpful.
Old 04-18-2002, 07:08 PM   #7
TerenceT
Member#: 9510
04 FX35
Pearl White
i have the same thing, i believe they are surface rust, sort of like the one on the rotor surface but since these are on the hat, they don't rub off
i went to home depot and got myself a can of grey primer, took the wheels off, wax the rims while i had them off i might add, and spray the hat with 2 coat of grey primer, use a card board to block off the excessive over spray on to the rotor, a little bit on the rotor is fine
so far it's holding up quite well and the rust haven't shown thru
TerenceT is offline   Reply With Quote
Old 04-18-2002, 10:43 PM   #8
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Cadium plated rotors- 8 months with ZERO rust.
HIHO is offline   Reply With Quote
Old 04-19-2002, 04:07 AM   #9
Crzykdd
Member#: 11617
Rotors are made of iron. They are untreated/uncoated usually. If it rains or water gets on them, they will rust. No problem.
-Jason
Crzykdd is offline   Reply With Quote
Old 04-19-2002, 08:31 AM   #10
XT6Wagon
Member#: 524
04 STi
Heck even rust on the braking surface can be good. I noticed the SHO braked MUCH better after it sat around long enough to pick up a fair ammount of rust on the braking surface. I guess it broke up the smooth rotor and pad surfaces for a little more grip.
XT6Wagon is offline   Reply With Quote
Old 04-19-2002, 09:09 AM   #11
romanom
Member#: 16215
2002 WR WRX wagon
-Jason
The hats are always coated. The problem is the EPA makes it almost impossible to use a good coating that is low cost. All the EPA safe stuff that works is very expensive.
So, the OEMs just use whatever crap that fits the budget but is EPA safe.
Old 04-19-2002, 09:34 AM   #12
hunter001
Member#: 12153
Hmmm...I had the reverse effect with the WRX, after it had sat around a while. The braking improved after the rust wore off.
Later...AH
Old 04-19-2002, 10:00 AM   #13
XT6Wagon
Member#: 524
04 STi
Ya, it wasn't great till the surface rust got scrped off, but It had sat around long enough for a little bit of minor pitting on the surface.
Old 05-16-2004, 11:03 PM   #14
M E R C U R Y
Member#: 2007
2000 2.5RS BRP
NewImageMotorsports.com
do you think that zinc plated would have the same protection?
M E R C U R Y is offline   Reply With Quote
Old 01-24-2008, 09:02 PM   #15
Worxman02
Member#: 66563
2002 Impreza WRX
WR Blue Pearl
Bump for old thread. Is it ok if the rotors have rust flaking off on the INSIDE of the rotors, ie where the vanes are?
Worxman02 is offline   Reply With Quote
Old 11-16-2008, 08:21 PM   #16
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
what if I want to make this rust go away... forever.
Krang is offline   Reply With Quote
Old 11-16-2008, 09:06 PM   #17
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
no, they aren't. On nicer rotors, they are either painted or have a sacrificial coating of some sort on them, but the cheapies are not (nor do they need to be - the rust is purely a cosmetic issue - has effectively no impact on performance)
Old 11-16-2008, 10:03 PM   #18
Addict
Member#: 88434
2006 Maxima 3.5SE
Super Silver Color
Its almost impossible to avoid. I had a set of Brembos on a previous car. The hat rusted on them too. About the only way to avoid it is to get a rotor that's been coated (zinc or otherwise).
But its just cosmetic. If its already rusty, you're just going to have to live with it. Or buy new rotors.
Addict is offline   Reply With Quote
Rotors have rust on them Kuonji Brakes, Steering & Suspension 19 01-06-2004 11:12 AM
Rust on my rotors Quick WRX Brakes, Steering & Suspension 9 10-06-2002 11:12 AM
Brake pad rust mark on rotor ChrisWRX Brakes, Steering & Suspension 3 04-26-2002 02:14 PM
Rust on rotors HIHO Legacy Forum 1 06-24-2001 05:31 PM
Rust on rotors? Poseidon Brakes, Steering & Suspension 5 03-26-2001 10:29 PM
