Old 05-03-2002, 11:40 AM   #1
romanom
Member#: 16215
2002 WR WRX wagon
Exclamation Brake Fluid and Cold Temps.
Kinematic viscosities: All brake fluids (DOT 3, DOT 4 and DOT 5) must meet a minimum viscosity test of not less than 1.5 centestokes at 100 C (212 F) and must not be more than the following to meet their various classifications (the larger numbers indicate higher kinematic viscosities just like with motor oils).
DOT 3 1500 Centestokes at minus 40 C
DOT 4 1800 Centestokes at minus 40 C
DOT 5 900 Centestokes at minus 40 C
*-40 C = -40 F*
Higher kinematic viscosities means it "flows easier" at the cold temps.
A centestoke is is 1 mm^2/s
English: The higher the number the more likely it is to turn to goo at low temps. It is a linear relation. So at those cold temps it takes 16% more pressure to flow the same amount of DOT4 as DOT3. This MAY cause an issue with ABS.
By the way, KV does not change in a linear way as temps fall. Up to about 0 F DOT3 and DOT4 are close, but below that DOT4 starts to become more viscous.
romanom is offline   Reply With Quote
Grinding/rubbing noise after snowfall and cold temps moestock Normally Aspirated Powertrain 16 04-10-2009 11:58 PM
Got a little reminder about summer tires and cold temps.... f4phantomii Off-Topic 47 01-18-2009 09:56 AM
New Super-Blue Racing Brake Fluid and New Subaru Rear Diff Fluid! liupj NWIC Private Classifieds 7 09-11-2007 01:56 AM
whats the color of the stock brake fluid? and color of Valvoline and Motul? Bumble Bee 03 Service & Maintenance 6 01-12-2004 06:50 PM
Cooking your brake fluid and your brakes firedust Brakes, Steering & Suspension 2 08-25-2003 09:50 AM
