Welcome to the North American Subaru Impreza Owners Club Wednesday August 5, 2015
Old 05-25-2002, 07:13 AM   #1
romanom
Member#: 16215
2002 WR WRX wagon
Lightbulb Brake Performance Vs. Brake Feel
I think too many are mixing these two up from reading some posts. Especially about the 4 piston Subaru fixed calipers. Just to clarify, in brief, the differences.
Brake feel: pedal effort and pedal travel for any given desired deceleration. Ease of brake pressure modulation, accuracy and precision of modulation. Feedback through the pedal "describing" pad rotor contact dynamics and pressure fluctuations.
Brake Performance: Level of brake torque produced and the resistance to brake torque loss, better known as fade.
For performance I do not use the term stopping distance because that involves more than just the brakes.
Benefits of "better" feel:
Brake feel is just like steering feel. The better the feel/feedback is the more of the inherent performance you will actually be able to use.
Imagine a car that has 1.0g of lateral grip, but has lousy steering. Too light, completely dead, nothing happens just off-center, poor linear response and too much or too little ratio. Like a Mercedes AMG
How much of that great 1.0g are you ever going to be actually using with poor steering?
Same with brakes. Improving feel will allow you to better use what you have.
However, it will not objectively increase brake performance. If you are already getting the max out of you system then better feel will not get you more.
I will not go into how to improve performance as this has already been posted mulitple times. Sorry, but do a search
romanom is offline   Reply With Quote
Old 05-25-2002, 11:03 AM   #2
romanom
Member#: 16215
2002 WR WRX wagon
Old 05-25-2002, 11:25 AM   #3
romanom
Member#: 16215
2002 WR WRX wagon
I never posted this before, because to be honest to me it's obvious. But to others it might not be.
The formula below is a decent way to estimate what, if any, increase you have in brake torque after an upgrade:
Brake Torque Increase %=
[(caliper piston area new/old) * (effective radius new/old)* (brake pad friction coefficient new/old)]
*effective radius is the distance from the center of the hub to the center of the brake pad
*For sliding calipers multiply the areas by 2
Any answer equal to 1 means no increase. Any answer less than 1 means you've gone backwards. Any answer greater than 1 means a torque increase.
This will NOT give you the actual brake torque, just the difference.
Now things like steel lines, stiffer calipers effect feel not performance. Only force applied, torque arm and friction do that. You can change things like lines, calipers, pedals and boosters to change the characteristics. Such as, initial bite point and initial deceleration level, pedal travel and effort, pedal force mulitiplication. However, these do not actually produce more brake torque.
Old 05-25-2002, 11:35 AM   #4
adam99rs
Member#: 20
Good post...I would differ slightly that things that effect feel can effect performance over time. In other words, less fad due to stainless lines or better pads for example, can deliver more consistent performance lap after lap..long after stock stuff gives up. So in that way, you get better feel and performance
Oh...and check your packages next week Mike!
adam99rs is offline   Reply With Quote
Old 05-25-2002, 11:37 AM   #5
romanom
Member#: 16215
2002 WR WRX wagon
Yeah, you make a point about fade. The stuff above is for torque only not torque loss! Excellent point!
Packages huh? WoooooHOOOOO! Cool thanks!
Old 05-25-2002, 01:04 PM   #6
BIGSKYWRX
Member#: 7958
09 GH B+
This begs the question then- will Subaru 4 pots increase brake torque? Are they increasing effective area or piston area (twice as many pistons)?
Or do the 4pots simply provide better feel/feedback? Or both?
Curious as I have toyed w/ this upgrade.
Thanks,
Big Sky
Old 05-25-2002, 01:18 PM   #7
romanom
Member#: 16215
2002 WR WRX wagon
Thanks,
Big Sky
Having 4 pistons on a fixed is the same as having 2 on a slider. Becuase the force of the pistons on a slider are applied on both pads equally.
That is why you need to double the piston area on a slider in the equation above.
If the piston area of one side on the 4-pot is larger than the stock 2 piston slider then it will increase brake torque.
Fixed calipers require opposing pistons because that is the only way to get a force on both pads. And companies use fixed because they are dramatically stiffer than sliders. Not to mention usually lighter, more reliable and lower height.
Old 05-25-2002, 02:00 PM   #8
jmott
Member#: 6713
2007 Prius
brown
Default Re: Brake Performance Vs. Brake Feel
Originally posted by romanom
I think too many are mixing these two up from reading some go into how to improve performance as this has already been posted mulitple times. Sorry, but do a search
one way you can improve performance on bumpy spots is to PULL THE ABS FUSE
jmott is offline   Reply With Quote
Old 05-25-2002, 02:11 PM   #9
romanom
Member#: 16215
2002 WR WRX wagon
Default Re: Re: Brake Performance Vs. Brake Feel
Wise a55!
Old 05-25-2002, 03:55 PM   #10
romanom
Member#: 16215
2002 WR WRX wagon
Unhappy Re: Re: Brake Performance Vs. Brake Feel
jmott,
you hate the ABS now what if:
check it out (if you haven't)
For those that like pulling the ABS fuse
Old 05-03-2003, 02:48 PM   #11
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Anyone have the numbers to use in the "old" for the stock USDMY 2003 WRX wagon?
turboICE is offline   Reply With Quote
Old 05-03-2003, 03:59 PM   #12
NeoteriX
Member#: 20999
2002 PSM WRX Stg 2
knee - Aw - teh - rix
Thanks,
Big Sky
From what I understand, and it's limited for sure...
The Subaru 4 Pots have the same caliper piston area as the 2 Pots... So it's just a feel thing.
NeoteriX is offline   Reply With Quote
Old 05-03-2003, 11:22 PM   #13
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
One thing to add, improvements of a brake system are variable depending on what the starting setup brought to the table. Sometimes decreasing brake torque selectively can increase chassis braking performance. Sometimes less is more. You have to take a holistic approach to brake system upgrades or they can turn out as downgrades.
ss
subysouth is offline   Reply With Quote
Old 05-03-2003, 11:29 PM   #14
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks,
Big Sky
I have examined USDM Legacy GT and WRX and JDM B4/GT-B 2pot front calipers and they all appear identical in every aspect except caliper brackets, which are dependent on year and rotor used.
The Legacy GT calipers use a smaller bracket to use the 277mm rotor. All the others use the 294mm rotor just like the 4pots. The caliper piston sizes in the 4pots apear identical in diameter to the 2pots. So any of the 2pot Subaru front calipers being used with the 294mm rotor should have nearly identical torque output to the 4pots(assuming equal pad coefficient of friction.)
The 4ots vs 2pot WRX calipers bring feel and uptake(and bigger pad choice) to the table.
ss
Old 12-16-2012, 03:30 PM   #15
njdriver04
Member#: 248747
04' SG XT
Blk
Originally Posted by romanom View Post
is this link correct?
njdriver04 is offline   Reply With Quote
Old 12-16-2012, 05:47 PM   #16
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Obviously not. 10 years ago, when this thread was started, NASIOC was the i-club, hence the link from 10 years ago points to the i-club. I'm guessing if you search for threads started by the same guy that started this thread you can find the correct link.
Patrick Olsen is online now   Reply With Quote
Old 12-16-2012, 06:31 PM   #17
jdblock
Member#: 235211
2004 STi
jdblock is offline   Reply With Quote
Old 12-16-2012, 09:21 PM   #18
njdriver04
Member#: 248747
04' SG XT
Blk
got it thanks
where is the nasioc history thread?
stock brake lines vs. brake fluid swift2fly Brakes, Steering & Suspension 10 07-21-2009 06:40 PM
Performance vs. Non-performance Mods neorealist General Community 21 07-14-2006 10:22 AM
Big brake kits vs performance MikalsWRX Brakes, Steering & Suspension 41 06-19-2005 06:26 PM
Please Explain High Performance vs Ultra High Performance Tires. andyfish Tire & Wheel 10 02-04-2005 12:52 AM
brake calipers VS brake pads iloveturbos Newbies & FAQs 2 09-21-2002 03:21 PM
