Old 06-20-2002, 12:17 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Exclamation Make your handle how you like it!
I posted this in General forever ago but wanted to resurect it in these newer forums where I think it belongs! Enjoy
OK,There has always been a huge debate over what to do if your car oversteers or understeers. The first thing people go to is always the swaybar when someone always asks how to "loosen" or "tighten" their car. However, there is a lot more to making your car handle to your liking, and everything will do a little something different depending on speed, turn-in rate, braking percentage, weight distribution and a number of other factors. To help everyone out, here is a list of things you can do to your car to get it how you want. You might even want to print it out and bring it to the track with you. Here goes:
TO REDUCE UNDERSTEER or INCREASE OVERSTEER:
Front tires:
- Increase tire pressure in 2.5psi increments
- Increase Section Width
- Lower the Aspect Ratio
- Reduce front tread depth
Rear Tires:
- Reduce tire pressure in 2.5psi increments
- Reduce section width
- Install higher aspect ratio tires
- Increase rear tread depth
Front Wheels:
- Install wider wheels
- Install lighter wheels
Rear Wheels:
- Install narrower wheels
- Install heavier wheels
Front Alignment settings:
- Dial in more negative camber
- Dial in More toe-out
- Dial in more positive caster
Rear Alignment settings:
- Dial in more positive camber
- Dial in more toe-out (Same as front)
Anti-Sway bars:
- Soften the Front
- Stiffen the Rear
Spring rates:
- Soften the Front
- Stiffen the Rear
Shock absorbers:
- Soften the Front
- Stiffen the Rear
Suspension Bushings:
- Soften the Front
- Stiffen the Rear
Brake Proportioning
- Reduce Front brake pressure
- Increase rear pressure
Weight Distribution
- Reduce front weight
- Increase rear weight
Aerodynamics:
- Increase Front Downforce
- Reduce rear downforce
TO REDUCE OVERSTEER or INCREASE UNDERSTEER:
Front tires:
- Decrease tire pressure in 2.5psi increments
- Decrease Section Width
- Install higher Aspect Ratio tires
- Increase front tread depth
Rear Tires:
- Increase section width
- Reduce aspect ratio
- Decrease rear tread depth
Front Wheels:
Rear Wheels:
- Dial in less negative camber
- Dial in less toe-out (to toe-in if needed)
- Dial in less positive caster
- Dial in less positive camber
- Dial in less toe-out (Same as front)
Anti-Sway bars:
- Stiffen the Front
- Soften the Rear
Spring rates:
- Stiffen the Front
- Soften the Rear
Shock absorbers:
- Stiffen the Front
- Soften the Rear
- Stiffen the Front
- Soften the Rear
Brake Proportioning
- Increase Front brake pressure
- Reduce rear brake pressure
Weight Distribution
- Increase front weight
- Decrease rear weight
Aerodynamics:
- Reduce Front Downforce
- Increase rear downforce
Well there you go. Keep in mind that any adjustment you do will affect the car so do not do more than 2 adjustments at one time. If those don't work or you still want more, keep trying but don;t do to many adjustments at one time. Any question, feel free to ask
Eric
PS: Possibly a good stickie
Eric SS is offline   Reply With Quote
Old 06-23-2002, 01:54 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I can't believe no one cares about this Just trying to clean up the forum a bit.
Eric
Old 06-23-2002, 06:41 AM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
yeah honestly that should be a sticky
how many times per week does someone come on here and complain about understeer???
ellisnc is offline   Reply With Quote
Old 06-23-2002, 11:49 AM   #4
jesse370
Member#: 12147
2005 g-35
ivory pearl
too many times. I found this very helpfull and informative. I'm still waiting for my baby to get here, but I hope that with the sti suspension it will give the car a more neutral feel to it.
jesse370 is offline   Reply With Quote
Old 09-12-2002, 02:13 AM   #5
oops
Member#: 24394
A bump for someone that has dedicated the last 2 years of his life to helping the i-club only to get temporarily banned.
This is a good thread people. Read it and remember it if you ever have questions like "My car understeers. what should I do?" or vice verse.
oops is offline   Reply With Quote
Old 09-12-2002, 05:18 AM   #6
dorifto88
Member#: 17684
1989 pathfinder
rusted red
dorifto88 is offline   Reply With Quote
Old 09-12-2002, 01:04 PM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Damn
What'd you do Imprez?
Thanks for the great info.
subysouth
subysouth is offline   Reply With Quote
Old 02-23-2003, 06:47 PM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Bizzump again.
Maybe you can add this to the threads to note section or something.
Old 04-04-2003, 01:04 PM   #9
ResQDawg3
Member#: 14117
2005 Nissan Murano
Pewter
Someone please Sticky this thread!!! I get tired of looking for it all the time.....
ResQDawg3 is offline   Reply With Quote
Old 04-04-2003, 02:35 PM   #10
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
there is a link to this thread in the "threads of note" sticky
RokketRide is offline   Reply With Quote
Old 04-04-2003, 04:39 PM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
IMO, tire pressure should be looked at as "Fine Tuning" because when you're on a race track, adjusting it along with camber settings will give you maximum contact thorughout the race track.
To adjust the tire pressure to it's optimum, you need a temperature probe thingy, that way you can mesure the heat across the tire so you can tell if you're getting contact on the outside (more camber needed), inside (less camber needed), center (lower pressure), or both outside (more tire pressure needed).
Remember, adjusting for AutoX is quite different from Road course i.e Road America, Road Atlanta, Laguna Seca.
FuJi
FuJi K is offline   Reply With Quote
Old 04-05-2003, 05:03 PM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Hey good job.
I don't need it myself, but it will save me from explaining a gazillion times to other people.
Thanks for the work.
Old 04-05-2003, 06:14 PM   #13
teiva-boy
Member#: 22825
ttt
teiva-boy is offline   Reply With Quote
Old 04-07-2003, 01:08 AM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
FuJi
Those are just generals. everything listed can be "fine tuned."
Old 04-07-2003, 03:17 AM   #15
kidatari
Member#: 10441
Eric-
Thanks a lot for this post, definately needs to be a sticky. I'm going to print out a copy, and post it on the wall of my garage
kidatari is offline   Reply With Quote
Old 04-07-2003, 11:50 AM   #16
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
do you guys have me on ignore?
this thread ALREADY is a stickie
Old 04-07-2003, 12:10 PM   #17
vile
Member#: 32371
'02 t-rex wagon
platinum
also, some more info to help the subaru community would be to put down the info bout the different cars
i can only speak for the wrx wagon....which has a tendancy to understeer....stock tire pressure is 32 psi front and 29 psi rear.....front sway bar is 20mm and rear is 18mm
and bonus points if you can include spring rates and such
vile is offline   Reply With Quote
Old 04-07-2003, 02:45 PM   #18
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Front tires:
Rear Tires:
I'm assuming the tire pressure is a cold setting for AutoX. More flex for oversteer, it looks like. PM me your resorces. Okies?
Maybe I'm being too specific and technically too into details. Sorry.....I'm just concerned about the tire pressure thingy because there's talk about it like increasing and decreasing it for AutoX. I understand the concept of it. In road course, the tire pressures are going to be a lot different from Autocrossing courses.
Old 04-07-2003, 05:33 PM   #19
mattf87
Member#: 29967
Eric,
Please correct me if i'm wrong but wouldn't you want to add TOE IN up front (instead of the posted toe out), to increase turn in and therefore decrease understeer/increase oversteer?
thanks for the help,
Matt
mattf87 is offline   Reply With Quote
Old 04-07-2003, 05:42 PM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally posted by mattf87
Eric,
Matt
My understanding is that Toe-out will increase initial cornering response. Quicker response upsets the vehicle, which when all the components are working together, it'll make your car oversteer quicker.
BUT, IMO it'll not turn as good when the front is under load throughout the corner.
Old 04-07-2003, 10:08 PM   #21
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
That is a great reference, although maybe you should stress that the front and rear tire circumferences have to remain within 1/4" of each other with all the tweaks you can do, on Subarus and other AWD cars.
mtb_dude is offline   Reply With Quote
Old 04-11-2003, 12:07 PM   #22
Bart
Member#: 18544
bump for good info
hudos to Eric v2.1
Bart is offline   Reply With Quote
Old 04-11-2003, 12:49 PM   #23
ITWRX4ME
Member#: 24472
2001 Miata
It should be added to the FAQ and Threads of Note in this forum.
Mods, how 'bout it?
ITWRX4ME is offline   Reply With Quote
Old 04-11-2003, 01:01 PM   #24
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Its already there
did you read the whole thread?
Old 04-12-2003, 05:28 PM   #25
MrDisibility
Member#: 30590
It should be noted that changes should be made in small increments, making fewer changes at one time will be good too...
Also, keep in mind that the ride is going to be effected greatly by doing a lot of that stuff, especially when stiffening the rear of the car. Also, big swaybars will handle like ass over uneven surfaces. The reasoning for going slowly with it is to get the ideal handling and ride compromise...These are street cars, right?
And I was always under the impression that increasing tire pressure will generally decrease the overall grip. Lower pressures allow the tire to give with the pavement, adding grip when it is stressed laterally. I don't see why increasing front pressure will help them stick through a turn better. Likewise, adding more air in the back would probably help the car rotate better.
MrDisibility is offline   Reply With Quote
Turn In Concepts makes your car handle better Turn in Concepts Suspension/Brakes/Handling 20 10-04-2007 09:38 AM
We know what you want and we know how you like it. (SWS) blaster88 Off-Topic 24 05-15-2005 05:19 PM
PolTec End Links and Lateral Links, Make Your Car Handle As It Should PolTec Inc Suspension/Brakes/Handling 90 03-24-2005 06:07 PM
What's Your Job and Do You Like It??? xfactor834 Off-Topic 106 05-17-2003 04:09 PM
How to make your car handle to your liking Eric SS General Community 4 11-10-2001 05:34 PM
