#26 |
Member#: 5211
Vehicle:1997 Legacy Outback Spruce Pearl green |
I am debating whether to wait for these or go with Impreza AGXs (and the lowering that comes with that). Anything new?
Thanks, Doug
#27 |
Member#: 6214
AKIC
Vehicle:92 Corrado SLC 01.5 S4 |
Not to stir the pot, but does the Outback Sports (i.e. Impreza's) have any sport struts/springs? If so I think that SubieGal might have been alluding to the fact that since Legacy = Impreza, then possibly OBS = OB as far as struts/springs.
Just a thought. |
#28 |
Member#: 3198
Vehicle:2005 GT LTD Wagon Garnet Red |
OBS' use Impreza suspension components, and are a direct replacement. They won't work on an OB.
#29 |
Member#: 4615
BAIC
Vehicle:05 STi, 97 Leg OB |
to clarify; the impreza stuff will bolt right on. Whether it'sa good idea is another question. I put RS struts on my OB as an experiment and they were severely underdamped for the OB springs.....
But they fit with no problems, other than that the OB strut shaft is ~10mm thicker than the RS part......beefy looking strut, so the bumpstops from my OB were *way* too big... |
#30 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
Seeing as the new Subaru Baja "Pickup trukette" is basically an Outback with the rear roof section cut away, and it has a much firmer suspension then the Outback, Perhaps these new KYB "Outback" Struts are in reality "Baja" struts that will fit the 2000-2003 "Outbacks" ?
Does any one have the part numbers for the 'Baja' struts ? |
#31 |
Member#: 3312
Vehicle:1999 Outback Wagon Sapphire Blue |
since it has no rear struts. Like all 2k and newer Legacys.
KYB's estimate for the front struts is early winter (given thier track record on this product, I wouldn't count on it). Rear struts are available now. Luke@tirerack.com can give your the latest scoup |
#32 |
Member#: 5211
I don't get onto this board much anymore. Is there any new info on these? Are they actually available
![]() Thanks, Doug |
#33 |
Member#: 30556
Vehicle:2000 Legacy GT (BE) over 250,000 Miles |
I know might be little off topic..
how about new struts front & rear for 2000 Legacy GT Sedan..? pm me with the info or post here.. nothing special required.. just something that will replace little bouncy worn stock ones. |
| Thread Tools | |
| Display Modes | |
| '00-04 KYB GR-2 struts outback NIB$160 | outbackwbeer! | Legacy Specific Parts | 0 | 11-22-2009 01:59 PM |
| 04/05 owners what aftermarket struts are you using? | jt0thevizzle | General Community | 0 | 08-19-2008 11:44 PM |
| What are some aftermarket parts that are compatible with the WRX AND STI? | disque71 | General Community | 1 | 09-28-2006 02:27 PM |
| kyb gr2 struts, are they any good? | wrxracer55 | Brakes, Steering & Suspension | 3 | 03-10-2004 07:43 AM |
| kyb agx struts, are they worth it (looking to fix bad ride quality)? | wrxracer55 | Brakes, Steering & Suspension | 14 | 09-27-2003 12:38 AM |
