Old 10-21-2002, 11:22 AM   #1
twlai
Member#: 11811
2002 09 MiniCooperS
02WRX 08EvoMR (sold)
Default help! I messed up my brake!
I found out the reason why there is a grinding noise in my
wheel! I put the brake pad in the wrong way!!!!!
I have the brake pad chip grinding the rotor!!!
The rotor is groove big time! Would I have damage the
brake piston?
:~{ Did I mention I did many 60mph - 20mph breakin!!
What else do I need to change???
twlai is offline   Reply With Quote
Old 10-21-2002, 11:45 AM   #2
Porter
Member#: 486
2004 Forester XT
bug spattered
Wait...
You put the backing plate against the rotor?
And it stopped that way?
I don't get it... slow down and explain.
Porter is offline   Reply With Quote
Old 10-21-2002, 12:51 PM   #3
twlai
Member#: 11811
2002 09 MiniCooperS
yes, backing plate against rotor....
well, the car still stop, it is just 1 out of 8 pads that I messed up.
so I still have some stopping power left...
Old 10-21-2002, 01:04 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Are you talking about the silver piece on the brake pad? instead of putting it on the back part of the pad?
Robin
Robin2 is offline   Reply With Quote
Old 10-21-2002, 01:13 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whoa ...
i see new rotors in your future...
Old 10-21-2002, 03:19 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
twlai: Dude Im sorry for doing this but you will become the topic of discussion at lunch today when all of my co workers will be laughing
Im just curious, why did you install it this way? You should get a job in beta testing video games. I know someone who works for Microsoft as a tester and his job every day is to try and do everything backwards, basically the opposite of what the average person would do.
Old 10-21-2002, 04:15 PM   #7
DBAsteve
Member#: 16839
Default Re: help! I messed up my brake!
brake piston?
At least your pads wont wear out.
You'll need to get the rotors remachined (turned) to remove the metal pickup.
DBAsteve is offline   Reply With Quote
Old 10-22-2002, 03:56 AM   #8
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
you COULD just use this opportunity to upgrade your brakes then. pretty good reason, i'd say.
yuletak is offline   Reply With Quote
Old 10-22-2002, 10:31 AM   #9
twlai
Member#: 11811
2002 09 MiniCooperS
I thought about getting the subaru 4pot, but I have snow tires
on my stock rims, which will not fit.
I 'll checked the rotor, it is bad, but I am not spending money
to retune it, I'll just see if the pad will smooth it out in coupe
weeks. If not, I will just change the rotor, or get the 4pot in
spring.
Help, I messed up my AC!! mummer43 Service & Maintenance 31 11-10-2006 12:28 PM
messed up my tach! help! RedRex02 Electrical & Lighting 2 03-10-2004 05:14 PM
Help - Did I just mess up my coolant flush?!?? DanZ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-01-2004 05:21 PM
so i go to LA mess up my brakes and end up on the Fast and the Furious set gokou006 Southern California Impreza Club Forum -- SCIC 4 03-18-2003 07:27 PM
Help, Am i messing up my tranny? TheShadowWRX Transmission (AT/MT) & Driveline 6 07-06-2002 02:43 AM
