Old 02-03-2003, 05:52 AM   #1
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Lightbulb My own humble Subaru oil filter study
Here's the link: Armand's Subaru Oil Filter Study
Which other filters would be good to look at for Subies?
Old 02-03-2003, 09:35 AM   #2
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
page not found
elgorey is offline   Reply With Quote
Old 02-03-2003, 09:50 AM   #3
motojosh
Member#: 19838
2003 WRX wagon
Platinum silver
Originally posted by elgorey
page not found
Worked for me.
Looks like some great info, Armand. I haven't had time to pore over it completely, but I'll definitely be back to the site later.
motojosh is offline   Reply With Quote
Old 02-03-2003, 12:24 PM   #4
george_puli
Member#: 15731
2002 wrx
wrb
How about Amsoil's SDF 20/ SDF 13?
I use sdf 20 for my '02 wrx. They say the MY03 wrx's should use SDF 13. I think these might be made by hastings, but I may be wrong.
george_puli is offline   Reply With Quote
Old 02-03-2003, 01:21 PM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Thank you!!!
Thank you so much for doing this! I really appreciate your work! I have been apprehensive about the OEM filter because Purolators usually use a string around the filter element that could cut the material and allow dirt to flow through. Your findings clearly show that there is no such string in the Subaru filter and that the filter itself is of excellent quality. I will continue using OEM filters with renewed confidence!!!
Thank you x million!!!
vvk is offline   Reply With Quote
Old 02-03-2003, 01:24 PM   #6
balyndraks
Member#: 28678
2003 Legacy L-SE Wgn
Mystic Blue Pearl
yeah i use the amsoil sdf20, too. though it's so damned expensive i think i might just oem from now on. i'm religious about oil changes and use mobil 1. nice article, though.
jay
balyndraks is offline   Reply With Quote
Old 02-05-2003, 11:01 AM   #7
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
AC/Delco, and Motorcraft are about the same as the subaru.
cavymeister is offline   Reply With Quote
Old 02-05-2003, 12:38 PM   #8
KenpoKev
Member#: 32564
Default New Fram's ???
I purchased a couple of Fram's latest "high-end" filters for about $10 each. I think they are called X-2's or something like that. After examining them, I found that they are quite well-constructed, however I didn't cut one open for further examination.
Perhaps Armand will investigate this new filter and add it to his well-written research.
Thoughts?
KenpoKev is offline   Reply With Quote
Old 02-05-2003, 03:01 PM   #9
Bottom Feeder
Member#: 2808
Fram's have two things going against them:
1) They don't make a Subaru-specific filter, and
2) They're cheaply-made pieces of crap, proven by this and a few other studies.
The X-2's may be better filters, but they're still Honda filters that only happen to work on Subarus. Until Fram makes a Subaru X-2 filter, there's no reason at all to ever buy one.
I wouldn't put one on my car even if I got a case of them for free.
Bottom Feeder is offline   Reply With Quote
Old 02-05-2003, 09:07 PM   #10
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
There's a store down the street from my place that sells Wix filters, and I've heard good things about them.
I bought some of the PureOne filters at Fred Meyer and there were some good coupons on the shelf so the unit cost was pretty low.
You might try cutting open Pennzoil (sp) and some of the other filters to see how they compare to the Fram as far as cheapies go.
CosmoTheCat is offline   Reply With Quote
Old 02-05-2003, 09:21 PM   #11
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Thumbs up
Another vote for Amsoil! If your someone who changes their filter/oil every 3k miles they say the Pure one and Mobil one filter are pretty good.
http://www.amsoil.com/products/sdf.html
And as far as Mobil one being the best...check this out
http://www.go-synthetic.com/amsoil_v...vs_mobil1.html
This is probably one of the most informative web pages I have found on lubricaton.
http://go-synthetic.com/index/index.html
Camperguy is offline   Reply With Quote
Old 02-05-2003, 11:04 PM   #12
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
That is probably one of the most biased web pages I have found on lubrication.
For the record, I have Amsoil in the car now but will be switching to Mobil 1 next time because it's just easier to procure. 1% better this, 3 grams more that, 6 degrees lower the other thing....those differences are just too small to make a disciple out of me. Both are almost certainly better than dino oil.
Zola is offline   Reply With Quote
Old 02-06-2003, 02:53 PM   #13
scoobybrande
Member#: 12362
Platinum Silver
Good work Armand, it sure is funny how these subjects bring out some serious trash talk.
I would be interested in seeing the Amsoil SDF-20 (-13 is laughably small) and the Mobil 1-104. I would be willing to supply one or two to you for the dissection.
scoobybrande is offline   Reply With Quote
Old 02-06-2003, 03:54 PM   #14
Camperguy
Member#: 21274
2002 Mc_Bains car
Thumbs up
Just remember Filtration efficiency is derived from the materials used in its construction and test results with SAE standards not the size of the filter.Biased you bet Iv`e been racing and tinkering with engines(crappy V8`s) for over 20 years and been researching this issue to death thats why I`m biased Hey run K-Mart oil and a roll of toilet paper if you want.Yes I think getting Amsoil is a P.I.A. but so is driving out of my way to run Sunoco Ultra 94 gas.
Bill
Old 02-08-2003, 10:43 PM   #15
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
I used to run OEM subaru filters....then amsoil....now the big daddy of them all......
http://www.cmfilters.com/spin-on.cfm
Personally I like the idea behind the filter. Also when I had the stock engine I had a drivers side lifter tick for the first few sec on initial startup....that disappeared after this filter. I believe it flows with much less restriction and its filter efficiency is superior. Yeah, so the price is a little ridiculous but hey, it gives you that warm fuzzy feeling.
mr2guru is offline   Reply With Quote
Old 02-10-2003, 12:33 PM   #16
BluSuby
Member#: 12154
04 Sti
99 Outback
Default Re: My own humble Subaru oil filter study
I've been using NAPA gold 1334(by wix) since my 1st change. I'm at 31k now. No problems so far, it looks like it is constructed well, and I've heard nothng but good thing about it. Maybe you could check that out too. BTW nice page,
Bryan
BluSuby is offline   Reply With Quote
Old 02-10-2003, 12:59 PM   #17
micah
Member#: 3154
This is the second hacksaw-type "Oil Filter Study" I've seen that calls Fram's filter media "cardboard". But I was under the impression that it's a glass fiber/cellulose composite? Just like the vaunted Amsoil SDF filters?
I'm curious what about this material made you guys think it was cardboard vs the composite material
micah is offline   Reply With Quote
Old 02-10-2003, 01:23 PM   #18
Bottom Feeder
Member#: 2808
No one's saying that the filtering media is carboard. It's the caps on the ends of the filter cartridge that seal it against the filter that are made of cardboard. Everyone else's is either rubber or steel.
Old 02-10-2003, 01:42 PM   #19
micah
Member#: 3154
My bust! I misread the part that said "cardboard filter cartridge" :blush:
Old 02-12-2003, 11:10 AM   #20
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
Thumbs up
very good page, and it proves my point that Fram is the root of all evil.
subyguy2 is offline   Reply With Quote
Old 02-12-2003, 01:47 PM   #21
motojosh
Member#: 19838
2003 WRX wagon
Platinum silver
Default Just a thought
I've been mulling this idea over for a few days now . . . I wonder if, in addition to the already comprehensive information that Armand has provided, it might be useful to somehow measure the flow through the filters. I don't mean something as precise as "what's the smallest micron that can pass through the filter media?", but maybe something simpler. Like pouring a specified amount of oil into each filter and then timing how long it takes to filter out.
Would that be a good measure of the filtering ability, or would we not learn anything useful?
Old 02-28-2003, 01:33 PM   #22
DucatiBoy
Member#: 31904
02 WRX Wagon
Oh crap I have been using Fram PH3593A for over 27K on my WRX. I better change it now!
I guess the biggest concern is the "cardboard" components. Interestingly oil filters have been made that way for years. Also a weak bypass valve is the other concern. Well I would rather have the by-pass valve fail open than closed! Of course having it work properly is better.
We Subaru owners don't have to worry so much about the oil filter holding oil for cold start up. Our filters mount vertically. Also if you change "dino" oil every 3K mi a "top of the line" filter is really not worth the extra money.
Still not convinced but here is another hacksaw study;
http://www.ntpog.org/reviews/filters/filters.shtml
DucatiBoy is offline   Reply With Quote
Old 03-01-2003, 01:28 AM   #23
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You might want to change a bit more frequently, like every 3-5k miles
But seriously, you don't have to pay very much for a decent filter. The "top of the line" ones run $10 or more, but a decent one like the Subaru OEM, normal Purolator, etc will only cost $4 +/-. Even if a Fram costs only $2, spending an extra $1 or less per 1000 miles doesn't seem like a big expense compared with the risk.
As for the Fram, my concern would not be the cardboard construction (as DucatiBoy points out, many have been made that way for a long time), but rather with the significantly lower-than-OEM spring tension on the bypass valve, and the significantly less surface area of filter material. Less surface area will increase backpressure; that, combined with the easier-opening bypass valve, means that the Fram will NOT be filtering the oil (due to bypass) much more of the time than the OEM or PureOne filters. Why save $2 at the expense of less-than-OEM levels of oil filtration?
Old 02-09-2004, 02:52 PM   #24
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Don't panic if you have used Fram filters. That's pretty much all I have used on my 95 Legacy and it's still running fine after 170,000 miles. I am using OEM in the WRX, though.
Mike Wevrick is offline   Reply With Quote
Old 02-09-2004, 03:38 PM   #25
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Thumbs up
Good to know...
I always crack up when someone says something like, "14K miles and no problems!" I had a girlfriend who didn't change the oil in her 626 for almost 30K miles and she didn't have any "problems". I'm guessing her engine wouldn't make it much past the 100K mark, though.
Stanley is offline   Reply With Quote
(4)oem subaru oil filters and (1) mobil 1 oil filter ubi_scoobi SCIC Private Classifieds 0 01-09-2010 03:35 AM
OEM 05 STI subaru oil filter is it good oil filter? garboplateNY88 Service & Maintenance 3 10-12-2007 12:16 AM
Which factory Subaru oil filter to use on my 2002 WRX gsodonis Service & Maintenance 2 10-02-2003 02:20 PM
Oil filter study, Help!? WRXDAN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-18-2001 04:32 AM
Aftermarket Vs. Genuwine Subaru Oil Filters???? KuyaKRS South East Region Forum 11 03-08-2001 07:48 AM
