South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-08-2003, 09:16 PM   #1
AzSubie
Member#: 19285
2003 Cobra
Default Trick 101 gas octane ?'s
JUst wondering if anybody knows what method is used to calculate the octane rating of this fuel. It's the racing fuel available down at the Mobile in Ahwatukee.
Thanks,
Pete
AzSubie is offline   Reply With Quote
Old 03-09-2003, 02:32 PM   #2
RacingBlue
Member#: 3325
Most pump gas is an average of RON and MON numbers.(RON + research octane number, MON = motor octane number) No telling what trick uses, though I seem to recall all octane #s above 100 were RON. Call Trick.
RacingBlue is offline   Reply With Quote
Old 03-09-2003, 08:00 PM   #3
AzSubie
Member#: 19285
2003 Cobra
Thanks for the response. I'll do a little research on the web to see if I can find out. If nothing else, I can call them like you said.
Cheers
Old 03-09-2003, 08:59 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Let me / us know what you find out. I'm betting a bunch of us want some good stuff for the upcoming track day
kastle is offline   Reply With Quote
Old 03-09-2003, 11:49 PM   #5
gdog
Member#: 6189
Red No More
It's the good stuff; I mix it 50/50 with 91 for competition. I was able to add 5 degrees of timing to my 91 octane map, pulled a fair amount of fuel out as well, and it still runs great.
AzSubie, I mentioned it since I believe you have a utec.
A 101 map intrigues me...
gdog is offline   Reply With Quote
Old 03-10-2003, 12:48 AM   #6
AzSubie
Member#: 19285
2003 Cobra
Yeah Gdog, I've got a UTEC with a stage 4 +TMIC set-up. I run trick 101 straight since my WRX isn't my primary transportation and so I can afford to feed it the good stuff. I've run as high as ~22 psi (had to turn the ABC down after the dyno day) without any knock. I've got it set for about 19-20 psi right now and I've added a fair amount of timing too. All without any knock. Before doing to much more tuning, I'll be installing my Perrin fuel rails and then hitting the dyno with AZScoobie. Plus, I'm sending my current map and some logs to Nathan at TXS to see what recommendations he has. When I made the dyno pulls, i was way way rich. It'll probably be even more so with the rails. What set-up are you running Gdog? Once I get my map down, you can have a looksy if you so desire.
Cheers,
Pete
http://www.trickgas.com/unleaded.htm
Old 03-11-2003, 01:29 AM   #7
DubuRX
Member#: 24307
05 Evo MR
AWD LUV
Question about the Perrin fuel rails (if you know, or anyone who does)...
Can you use the stock FPR or do you need to upgrade??
I know it doesn't come with one and the Vishnu does, but I like that Perrin uses steel braided lines standard.
Thanks.
DubuRX is offline   Reply With Quote
Old 03-11-2003, 11:01 AM   #8
gdog
Member#: 6189
Red No More
You don't have to upgrade, though there are advantages to doing so.
I'll be installing mine at some point soon (whenever I can get reasonably priced injectors), but until I upgrade my turbo I'm keeping the stock fpr.
If you're also installing a new fuel pump, the stock unit may have problems handling it. You might get Clark's opinion on that.
Gas Octane Question chris7 Texas Impreza Club Forum -- TXIC 9 10-14-2007 11:55 PM
for those of you who think gas octane doesn't matter attitude General Community 7 05-07-2004 08:33 PM
what gas octane do u guys fill for ur car?? fukamoto Vancouver Impreza Club Forum -- VIC 31 11-29-2002 12:43 PM
Whats the best Gas Octane to use on WRX TrademarkWRX Tri-State Area Forum 18 04-04-2002 07:12 PM
Gas Octane HuRyde General Forum Archive 1 03-22-2001 01:27 PM
