Old 03-11-2003, 12:51 AM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default Spark Plugs
What kind of spark plus are you guys running on your RS-T's?
FatCatTurbo is offline   Reply With Quote
Old 03-11-2003, 01:58 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I have stock NGK plugs. I only run 4.3psi though.
Drac9 is offline   Reply With Quote
Old 03-11-2003, 02:31 AM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
lower boost (less then 8psi) it is recommended to use the NGK BKR7EVX-11. That comes straight from Shiv. That is what I was using all the way up to 15psi. I recently have moved to 8 range plugs.
kastle is offline   Reply With Quote
Old 03-11-2003, 10:07 AM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I use NGK 7's also
Eric SS is offline   Reply With Quote
Old 03-11-2003, 01:14 PM   #5
jdmimpreza
Member#: 10644
2001 impreza
Blue Ridge Pearl
NGK 7's
jdmimpreza is offline   Reply With Quote
Old 03-11-2003, 01:38 PM   #6
Impreza25RS
Member#: 4850
1998 EJ22.5RS-T
more mods coming soon!!
same here I use the NGK 7s as well
Kyle
98RS-T Owners UNITE!
Impreza25RS is offline   Reply With Quote
Old 03-11-2003, 01:44 PM   #7
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
so would you guys recommend 8's for 12-14 psi?
boysetsfire is offline   Reply With Quote
Old 03-11-2003, 02:15 PM   #8
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Talking
-Best that money can buy for 12psi application?.
-Second Best?.
saludos,
Mariano
Mariano is offline   Reply With Quote
Old 03-11-2003, 02:54 PM   #9
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I'd used the 7's in my RS-T at 15psi no problems. When I blew the head gaskets, that's when I replaced the 7's with 8's. I'd still say you could use 7's at 12-14psi no problem
Old 03-11-2003, 03:53 PM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
7's, all the way. Kevin, drive down to Summit, they should have em in stock.
Old 03-11-2003, 04:41 PM   #11
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
good info Bill!
Old 03-11-2003, 08:05 PM   #12
smacksube
Member#: 4067
01 2.5 rs
I would highly recommend staying away from the stage 8 ngk plugs....I am 75% sure they were behind my ecu failure. Unbeknownst to me the stage 8's are high resistance (like 5k ohms) while stage 7s are 250 ohms IIRC. After about 15 minutes my car stopped working and my ecu was fried. No mechanic could figure out what was wrong, then I did some research and there was another person who experienced the same problem with the stage 8's on the stock ecu. Just letting you know!
smacksube is offline   Reply With Quote
Old 03-11-2003, 08:16 PM   #13
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
good to know... I run them with the TEC-II...
Old 03-12-2003, 11:00 AM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
?? I don;t understand what you mean by "stage" 7 or 8. The heat range of a plug (as far as I know) only has to do with the length of them and how far away from the center of the combustion chamber they are. In other words, an "8" (for NGK) will not be as long as a "7". the electrode will be farther from the center of the cylinder and will therefor take a hair more time to light the mix which also helps deter detonation.
Old 03-12-2003, 11:37 AM   #15
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The heat range is essentially a quantified (albeit arbitrary) scale describing the plugs ability to remove heat from the combustion chamber. All plugs are designed to be a heat sink, the colder heat ranges remove heat 1 "level" better than the last. Therefore a stock "6" plug will remove "x" amount of heat, a "7" will remove "x+a=y" (not sure if its additive, multiplicative, or exponential) and an "8" will remove "x+b=z" such that x<y<z and a<b... there will be a quiz hope you took notes.
http://www.densoiridium.com/heatranges.htm
Old 03-12-2003, 11:58 AM   #16
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Yeah, that's basically what I said above
Old 03-12-2003, 07:05 PM   #17
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
scratch me running 8's... that plan is out... back on the 7's now
Old 03-12-2003, 07:26 PM   #18
boysetsfire
Member#: 6218
2001 2.5rs-t
are you sure that is the right part number for the 7's, i searched on ngk's sight and couldnt find them.
Old 03-12-2003, 07:50 PM   #19
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Yup.. that's right off of the plug and right from the TEC-II FAQ & TEC-II Forums.
http://www.vishnutuning.com/ubb/Forum1/HTML/000229.html
Also information on pages 6 & 8 of the tec-faq http://www.vishnutuning.com/files/tecfaq.pdf
Old 03-13-2003, 02:51 AM   #20
Austin
Member#: 7089
2016 STi
The one problem with a BKR7EVX-11 (or any -11 plug) is that it comes gapped at .044. To close the gap down enough for a boosted motor you end up with a funky angle.
BKR7EVX-11 is a platinum plug which is no longer made, although you may still be able to buy units left in stock.
BKR7EIX-11 is it's replacement - it's an iridium plug. Iridium is even harder (longer wearing - better for boosted applications) material than platinum.
An even better plug is the PFR7G. It's a premium platinum plug with a tapered center electrode. The stock plug in the wrx is a PFR6G, so this is one heat range colder.
You can get by with a BKR7EVX-11 (or EIX-11) gapped down to .026 or .028 - that's what I'm using - but it's less ideal.
Austin is offline   Reply With Quote
Old 03-13-2003, 02:57 AM   #21
Ethan
Member#: 246
AH! This would explain my problem with the stores not being able to order my plugs! Its not made any more huh...
Ethan is online now   Reply With Quote
Old 03-13-2003, 09:59 AM   #22
RS_NW
Member#: 2301
Ethan- Call up Action Auto on Everett Mall way... they will have it. I got a call 2 days after I picked up my plugs saying they had another set in stock.
RS_NW is offline   Reply With Quote
Old 03-13-2003, 11:56 AM   #23
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
i'm confused now, Bill, which one should I get?
Old 03-13-2003, 12:15 PM   #24
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
BKR7E-11
Old 03-13-2003, 05:37 PM   #25
boysetsfire
Member#: 6218
2001 2.5rs-t
anyone know where i can get the ngk 7's plugs by tomorrow?
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 708 06-22-2016 10:58 AM
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
NEED: Plug/Clip that plugs into WRX spark plug coil BeBop86 Private 'Wanted' Classifieds 16 07-16-2008 03:05 AM
Help! Sparks between distributor cap and spark plug wires! Stickee Normally Aspirated Powertrain 13 04-23-2003 11:23 AM
Ignitions, spark plugs & plug wires? scubaracer Normally Aspirated Powertrain 8 03-19-2002 04:17 AM
