Notices
Old 04-01-2003, 11:16 AM   #1
SupaWu
Member#: 34351
2008 STI
Spark Silver
Default DIN Pocket with Flip-up Door
Can anyone help me? I am going to install a Panasonic MP3 player in my '03 WRX Wagon and I need to know where to get the DIN Pocket with the flip-up door, so I don't have an ugly space under the single DIN unit. I have seen them on the Forester and Legacy and they are even silver like the trim around the radio and a/c controls on the WRX. Any suggestions would be appreciated.
SupaWu is offline   Reply With Quote
Old 04-01-2003, 03:11 PM   #2
palaban
Member#: 16691
I have a Legacy din pocket (with the flip up door) but it isn't silver. I got it from the dealer.
palaban is offline   Reply With Quote
Old 04-01-2003, 06:58 PM   #3
snoopydoo
Member#: 29817
suggestion: search.
hints:
thread 1
thread 2
snoopydoo is offline   Reply With Quote
Old 04-01-2003, 08:37 PM   #4
imprezu
Member#: 32224
02 WRX Wagon
WRB Bone Stock
i don't have te flip pocket but i did get the din pocket from the 02-03 RS. fits like a glove!
imprezu is offline   Reply With Quote
Old 04-02-2003, 07:47 PM   #5
SupaWu
Member#: 34351
2008 STI
Spark Silver
Thanks Snoopydoo! I ordered the silver pocket w/door PN# 66128SA040 from subaruparts.com. Thanks again.
Old 04-03-2003, 01:31 PM   #6
plunk10
Member#: 32342
2004 :derp:
I ordered one from Subaruparts.com and they sent me one without the flip door unfortunately. can't remember the part number.
plunk10 is offline   Reply With Quote
Old 04-03-2003, 02:09 PM   #7
quasi888
Member#: 25213
2003 WRX (Sonic)
2003 Honda CBR600RR (Red)
I've installed the silver Forester DIN pocket in my WRX and it looks great. Especially with my Alpine 7995 head unit which is also silver, the two look great against the silver center console.
Only thing is, you will need to drill some new holes in the sides of the pocket, as it is not a direct fit in the WRX.
If I remember tonight, I'll post pics here.
Dave
quasi888 is offline   Reply With Quote
Old 04-03-2003, 05:44 PM   #8
SpecK
Member#: 34554
'03 WRX
Sonic Yellow
quasi post pics!
I just ordered the part and I'll have it in about 3 days
I got a yellow 03 wrx too and I'm anxious to see how it'll look
thx
SpecK is offline   Reply With Quote
Old 04-04-2003, 02:21 AM   #9
quasi888
Member#: 25213
2003 WRX (Sonic)
Default Here are the pics!
OK folks, here are the pics of the Forester DIN pocket modifications/install.
First, here's the DIN pocket fresh out of the box:
Here's the side view. Red arrows indicate its mounting holes.
Unfortunately, these holes don't match up with the holes on the WRX's stereo brackets. So we need to do a little drilling. This image shows the rearward hole being drilled on the left bracket:
Don't "eyeball" the placement of the holes just based on these pics...they need to be precise if you want the pocket to be correctly aligned flush with the center console! I recommend test-fitting the whole assembly and placing it in the console multiple times until you get its placement right, before you start drilling!
This image shows what the left bracket looks like after both holes have been drilled:
I would like to have put the head unit below the DIN pocket, but due to the way the pocket is designed, the HU needs to be on top. So, put the whole thing together....
...and then put your center console back together, and here's what you get:
Closeup view, DIN pocket closed...
...and opened:
Hope this helps, let me know if you have any questions...
Dave
[edit: added more pics]
Old 04-04-2003, 03:03 AM   #10
quasi888
Member#: 25213
2003 WRX (Sonic)
Hey Speck-
Noticed you're in the City...I'm in South City. Lemme know if you need any help with the install....
Dave
P.S. Saw your other post about the Pioneer DEH-4500. Don't forget to get the wiring harness that will plug right into the factory harness. Check with your install department at Best Buy...
Old 04-04-2003, 09:03 AM   #11
plunk10
Member#: 32342
2004 :derp:
Great install guide on the DIN Pocket
Someone should post this one up on scoobymods
Old 04-05-2003, 12:35 AM   #12
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
I've got the Forester pocket in the same location; below my Pioneer HU. One thing I ran into in the install is that the bottom of the pocket was riding on top of the A/C and defroster buttons, which made the pocket bind a bit when opening or closing; so I dremelled a few mm off the bottom lip. Now it closes real nice!
fragment is offline   Reply With Quote
Old 04-05-2003, 01:59 AM   #13
quasi888
Member#: 25213
2003 WRX (Sonic)
Fragment -
I noticed the same thing when I first test-fit the pocket/stereo togther in the console, so I kept making adjustments to the position of the pocket until it fit perfectly -- that's why it's so important to do several "dry runs" before you start drilling the mounting holes! Obviously you were able to fix it by dremeling the lip, though, so kudos to you. In fact, dremeling that entire lip off will probably allow you to place the pocket on top, which is what a lot of people prefer. (I originally wanted it on top too, but I don't own a dremel, and at 2AM I didn't feel like taking my chances with my jigsaw.)
Dave
Old 04-05-2003, 10:39 AM   #14
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
quasi:
With my headunit fastened into the bracket, I aligned the pocket to fit right against the bottom of the headunit. I don't think I could have moved the pocket anywhere else except further back into the chasis. It didn't even occur to me that I had other options.
Old 04-05-2003, 03:16 PM   #15
SpecK
Member#: 34554
'03 WRX
Sonic Yellow
omg your interior looks SICK quasi
what HU do you have? Does that one do MP3s?
I've never done car stereo installation stuff before and I'd like to learn, but I could also have my guys at work do it for super cheap.
I'm debating right now. I installed my V1 radar detector myself and hard wired it. It was pretty fun and I was anxious to take some other stuff apart to see what I could do.
I've been building and repairing computers for years so I'm not really afraid of getting my hands into stuff, but this is my one and only car and I'd KILL myself if I messed something up.
I've got a couple of days until the DIN pocket arives at my dealer so I've got some time to think it over.
HOPEFULLY my rex will look as nice as yours on the inside. I've also got the MOMO shift knob on order but mine is the all leather one. can't wait till it's all done
Old 04-05-2003, 03:17 PM   #16
SpecK
Member#: 34554
'03 WRX
Sonic Yellow
one more thing quasi...what size bit did you use to drill the new holes in the bracket?
thx
Old 04-05-2003, 08:12 PM   #17
quasi888
Member#: 25213
2003 WRX (Sonic)
SpecK:
That's an Alpine CDA-7995, and yes it does do MP3s. No internal amp, pre-outs only. (I have an Alpine MRV-F340 amp under my seat). About $350 new on Ebay. There is also the CDA-7894 (which has an internal amp) which is very popular, and costs less $ but has a black face instead of silver.
I *think* I used a 3/16" drill bit for the holes. As I recall, the first time I drilled it, the hole was not big enough, but moving up to 1/4" would have been too big, so I stuck with the 3/16" and went over it again and just wiggled the bit around to slightly increase the hole size.
Dave
Old 04-05-2003, 08:26 PM   #18
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
Cool
Here is my Legacy din pocket
free from local dealer.
Orbiter is offline   Reply With Quote
Old 04-05-2003, 11:00 PM   #19
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
If you drill new holes in the bracket for the HU, is there enough room for it to sit more flush mounted???
I can't decide if i want one of these, or a DVD screen....
Kwyjibo is offline   Reply With Quote
Old 04-05-2003, 11:21 PM   #20
quasi888
Member#: 25213
2003 WRX (Sonic)
You're referring to the Alpine? Yes, the faceplate does protrude out a bit, and drilling a new set of holes might allow you to set the HU back a little further. On the other hand, the distance required to make it more flush might be so small that you end up making the existing hole larger, resulting in a less-secure mounting point.
For most people (including me), I don't think it's worth the effort/risk...
Old 04-06-2003, 01:09 AM   #21
Orbiter
Member#: 66
2002 Impreza WRX
Britney Edition
I have drilled new holes in my alpine HU from you can see the pix above it is now flush mounted =)
Old 04-06-2003, 01:09 AM   #22
SpecK
Member#: 34554
'03 WRX
Sonic Yellow
well I bit the bullet and went for this deck
http://ecominet2.alpine-usa.com/img/asb/cda-9813.gif
Alpine CDA 9813. IT's a black face but I like the green on it. Plus it was 100 bucks cheaper than 7995. Crutchfield is cool too and lets you finance it interest free for 6 months. I've got a lot of money coming to me from tax returns and past pay raises from my job so I'll be in the clear in a couple of weeks.
Hopefully the black will look alright too
Old 04-06-2003, 06:41 AM   #23
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Yeah, I noticed that...but i'm more interested in the 7995. I don't think all Alpine HUs would have the same depth.
thanks for the detailed pics guys.
Old 04-06-2003, 02:27 PM   #24
Stevins
Member#: 33931
2001 Impreza RS
Do they make that pocket with the door for the GC8??
Stevins is offline   Reply With Quote
Old 04-07-2003, 12:45 PM   #25
00GTS
Member#: 10738
2003 WRX Sedan
I'm confused by your question. They don't make this pocket for the WRX, it's from the Forester/Legacy. It's just a single DIN size pocket, I'm sure it would fit in ANY car.
-Josh
00GTS is offline   Reply With Quote
WTB: din pocket with flip down door MoFoHead Private 'Wanted' Classifieds 8 05-07-2006 02:56 AM
forester din pocket with flip cover silver gmodc7 Private 'For Sale' Classifieds 3 03-11-2006 02:28 AM
05 Sti Forester Radio Pocket with flip up lid install coil222 Car Audio, Video & Security 1 01-15-2005 07:45 PM
WTB: Legacy DIN Pocket with Door (black) TROLL Private 'Wanted' Classifieds 5 12-06-2004 12:47 PM
Does the DIN Pocket with the door (Legacy?) fit in the upper empty spot? Schleppy Car Audio, Video & Security 13 05-14-2002 09:29 PM
