Old 04-25-2003, 11:01 AM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default Using the USDM WRX Crossmember
I have heard opinions on both sides of the fence saying that it can or can't be used. Some say it bolts in, some say it doesn't work at all, some say you have to shim the control arm bushings to remove some slop.
I'm beginning to believe that shimming is necessary. yamarocket said you could just use the WRX wagon control arms or have the WRX control arm bushings pressed in and it will work without a hitch. I haven't been able to get him to confirm this.
How did you get it to work in your car? Using the turbo Legacy crossmember probably isn't an option for me right now since I don't want to pay the extra $200 to get one.
-Jon
Old 04-25-2003, 01:32 PM   #2
Craig W
Member#: 643
1999 2.5RS
WRX powered
for my I-Speed swap, we used the USDM 02 WRX crossmember on my '99RS. Bolted right up to the frame. We did have to shim the lower suspension arms. No big deal. You just have to use the suspension bolts from the 02 seeing as they're longer than the original bolts.
Craig W is offline   Reply With Quote
Old 04-28-2003, 07:54 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Anybody else have any comments on this?
-Jon
Old 04-28-2003, 10:44 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The cross member has extra "tabs" that the WRX uses for a stiffer body. The RS doesnt have spots for these, but they dont bother anything (no need to remove them).
Old 04-28-2003, 10:45 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
Old 04-28-2003, 11:46 PM   #6
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
I have one on my car. It fits fine, you do need to shim the control arms. I didnt at first and I was getting some horrible noises from the control arms moving around. I really dont think you could get away with not doing that. I did use the same bolts and I dont remember noticing they were short. The little plastic splash guards under the front bumper also do not clear well. Mine are just hanging down. However, Im sure five minutes with a blade would solve that problem.
Surb00 is offline   Reply With Quote
Old 04-29-2003, 08:18 AM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
How did you guys rig up the shims?
-Jon
Old 04-29-2003, 04:59 PM   #8
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
You can use washers to take up the slack.
Crawford/I-Speed is offline   Reply With Quote
Old 04-29-2003, 05:56 PM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
anyone have a pic with the USDM WRX crossmember all shimmed up?? ide like to see. Ill probably go this route if i like what i see.
Hawk296 is online now   Reply With Quote
Old 04-30-2003, 09:37 AM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
I would reccomend a 91-94 turbo Legacy crossmember as they fit the stock RS control arms....part#20100AA111..that way you don't have to shim up the arms......the 91-94 Bolts right in...no problems...
List price for this is 366 bones....but you can probably get a used one for less than a hun....Happy wrenching
Bill
Old 04-30-2003, 03:27 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I know the Legacy crossmember works; heck, I've installed one in my car before. I had found it for $150 and that was back when they were just barely starting to disappear.
I'd much rather be able to use the new-age crossmember that I will be receiving with my engine.
I have heard that the wagon's control arms actually have the same dimensions are the GC/GF arms, but they just use a thicker bushing where it mounts to the crossmember. Anybody actually investigated this to the fullest?
-Jon
Old 04-30-2003, 06:22 PM   #12
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
I've heard something similar to this from a friend in the business, but I can't confirm it.
Paul G.
paultg is offline   Reply With Quote
Old 05-02-2003, 03:24 PM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I called the dealership today and the RS control arm and the wagon control have different part numbers. However, she did mention that they both come with the front bushing (the location in question). The only way to know seems to be a direct comparison.
In this thread here, Leonardo says:
Well the GC8 body controll arms fit the new WRX wagon. It's the WRX sedan arms that are diferent.
Unforunately, the from control arm bushings are NOT available for individual purchase. You must buy the entire control arm. The dealership doesn't have the WRX wagon control arm in stock so I can't compare them anyhow. Looks likes it's shims unless somebody has some cheap and creative way to acquire WRX wagon control arms.
-Jon
Old 05-03-2003, 12:23 PM   #14
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Default Re: Using the USDM WRX Crossmember
-Jon
Jon... I shimmed my control arms, I did not change the bushings or control arms, because I only had one good control arm and bushing. The bushings will fit, but you need special tools to press them in and out. The WRX wagon control arm is the same as a RS control arm, just with a wider bushing, therefor a different part number.
yamarocket630 is offline   Reply With Quote
Old 05-06-2003, 03:21 PM   #15
subtnr
Member#: 36406
Here is another thought for you. Instead of switching out control arms or using shims. Go out and get a 2.2 Legacy turbo cross member.
This is the ticket, fits perfectlly without shims, and you can drop in any EJ20 motor from USDM or JDM.
my 2 cents
subtnr is offline   Reply With Quote
Old 05-06-2003, 03:30 PM   #16
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
And for what its worth, to change the crossmember, the control arms are all but out of the car anyway.
-Jon
Old 05-06-2003, 03:57 PM   #17
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Interestingly, the FSM gives procedures for removing the front bushing so it definitely comes out with the right tools. I'm not quite sure why they would allow the removal if you can't do anything but replace the entire control arm.
I can, however, source the control arms at $50 each.
-Jon
Old 05-06-2003, 04:41 PM   #18
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
jon .. just to complicate your world a little more ..
i bought STi hardened a-arm bushings from VT sports car for ~35 each
i plan to put them in when i swap my cross member out
Old 05-06-2003, 05:20 PM   #19
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Excellent. That is the front control arm bushing and not the rear one, right? Are you just going to have the Subaru dealership press those bushings in?Have you compared these bushings to your current ones to confirm that they are, in fact, a little wider?
[edit] Son of a gun:
RST-2021 -- Front Control Arm, Front Bushing Pair-- $41 from www.rallispec.com
-Jon
Old 05-06-2003, 08:14 PM   #20
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i actually bought both front a-arm mounts and rear (same location as an alk)...
when i am done there will not be any rubber in the front suspension of my car...
sorry i haven't compaired them
Old 05-07-2003, 06:23 PM   #21
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
How were you pressing those bushings in?
Also, when do you think you would be able to compare the bushings to confirm they are correct for the USDM crossmember?
-Jon
Old 05-08-2003, 02:26 AM   #22
dunk
Member#: 15359
I don't suppose that anyone has any information about how the USDM crossmember would fit on a forester?
-Duncan
dunk is offline   Reply With Quote
Old 05-13-2003, 06:02 PM   #23
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I believe the crossmember is the same since the Forester is supposedly based on the Impreza chassis. Should bolt up fine.
The bushings have almost completely fallen through. As per Wayne at AV Sport, neither SOA nor SOJ sell the front control arm, front bushings seperate from the control arms. Rallispec is looking into Powerflex for me. Aside from that, it's shims, Legacy crossmember, or WRX wagon control arms.
-Jon
Old 05-13-2003, 07:11 PM   #24
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
I have a crossmember from a GDA STI 7 in a 98 RS. The fitment was fine, no cutting the tabs off, but I did have to shim it to get the "slop" outta the front end.
Frank
luvmyrs is offline   Reply With Quote
Old 05-16-2003, 02:31 AM   #25
suberboy
Member#: 1531
2008 GRB
Red
Jon,
The dealer may not mind you ordering a set, or just one, control arm to take a look at and make a comparison... If you want to check into it call Chad at Mark Miller Subaru and he may be able to help you. 268 3734
Worth a try any way.
suberboy is offline   Reply With Quote
Quick Shoot- 3 Revisions of the USDM WRX Gfunk720 Member's Car Gallery 15 09-01-2006 11:28 AM
any difference between the jdm ver. 7 intake mani wiring harness and the usdm wrx? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-22-2006 04:51 PM
So for those who used a USDM WRX X-Member in their swaps jamesfacts Subaru Conversions 5 05-17-2005 09:09 AM
Which "older" JDM tranny will fit the USDM WRX? Kwyjibo Transmission (AT/MT) & Driveline 1 03-19-2003 10:34 AM
When will SWRT use the new WRX body style? Verist Motorsports 5 01-07-2003 10:41 AM
