Old 05-27-2003, 08:10 PM   #1
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Default Axle Spline Count
Does anybody have the axle spline counts for the 2000-2001 2.5RS (front and rear), a 2000 Legacy (front), and a WRX( front and rear)? I asked the yard for axles for a 2000 2.5RS to go onto my WRX drivetrain, but I got a set of 2000 Legacy front axles and a set of 1995 Legacy rear axles instead. Since I don't have the drivetrain here yet, I can't count the splines to know if they will work or not. I have the WRX FSM, but I can't see a spline count in there, only axle length and diameter. Would it maybe be better to just send all the axles back and then wait until my drivetrain arrives? I am paranoid about having $180 worth of axles that may or may not work.
In looking up the axles on www.car-part.com I find that searching for the front 2.5L axles for a 2000 brings up Legacy and Impreza axles. However, searching for the rears brings up only 2000-2001 RS axles. The dealership says that the parts for the 2000 Legacy axles and the 2000 RS axles are different. She said that some axles come with 23 splines and some with 25 but she has no way of knowing except to count the splines...
-Jon
Old 05-28-2003, 02:59 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Here is a start:
inner spline (at diff)/outer spline (at hub), diameter
  • 2002 WRX front:
    25/27, 28mm
  • 2002 RS front:
    25/27, 26mm
  • 2000-2001 RS front:
    25/27, 26mm
  • 2000 Legacy front:
    25/27, 26mm
  • 2002 WRX rear:
    25/24, 24mm
  • 2002 RS rear:
    25/24, 23mm
  • 2000-2001 RS rear:
    25/24, 23mm
  • 2000 Legacy Outback rear:
    25/24, 20mm
  • 1999 Forester rear:
    25/24, 23mm
  • 1995 Legacy rear:
    22/24, 23mm ??
-Jon
Old 05-29-2003, 07:07 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Anybody?
-Jon
Old 05-30-2003, 04:42 PM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation
I just put '01 RS axles into the WRX rear hubs I got.......fit fine, nice & snug
no forcing & no play in the fit
Team ARG!
Scoobyslack1 is offline   Reply With Quote
Old 05-30-2003, 07:36 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
You put an LSD in? If you were merely swapping from drums to disks then your stock axles should have been fine. Or am I missing something here?
-Jon
Old 05-31-2003, 10:34 AM   #6
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
yes, '01 RS rear diff....needed the 4.11 for the JDM tranny
as far as splines.....just trying to help
Team ARG!
Old 05-31-2003, 11:02 AM   #7
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I have been able to deduce most of them. Since all front axles from like 1994 or something like that have been interchangable, the only differences will be the axle diameter. Also, the outer splines on the rear axles are all the same since I can put WRX awd hubs on my L without switching axles. So now the only thing I am missing is the inner spline count for the LSD and non-LSD axles.
Turns out the 1995 Legacy rear axles are all wrong and they sent me the wrong axles. I should have a set of 2000+ RS rear axles in about a week so I'll have almost everything.
-Jon
Old 09-23-2005, 01:34 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
bumping as i have had to deal with finding the correct splin count axels
fwiw
93 IMP L AWD
rear 22/24 , ???mm
Old 03-02-2006, 07:48 PM   #9
jsteele22
Member#: 107697
-Jon
Hi, Jack !
I've done a little archive reading, and I wanted to check something about axle compatibility. I'm interested in using a 1994 FWD tranny for a project (porsche 914). From what I've read, the differential is an "outie", right ? (i.e., it has splined shafts protruding.) Then the "green thing" (CV outer case ?) has a female splined opening that slips onto the outie and is held by a roll pin. Correct so far ? Okay, so my big question : are the splines on a 1994 FWD tranny compatible with the "green thing" off of any 1994-2000ish front axle ? I'm hoping to score a pair of those green things and make some hybrid drive shafts.
Thanks.
jsteele22 is offline   Reply With Quote
Old 10-07-2008, 10:28 PM   #10
toddvero
Member#: 191193
Default 2000 Legacy Outback Rear
The table above is incorrect with respect to the rear Legacy Outback 2000 axles. The outer (hub) spline is 25 and larger than the spline of an Impreza.
I'm trying to build a rear out of Subaru parts for a custom application. I can confirm by hands-on experience that the 2000+ Legacy, Legacy Outback and Baja have 25 spline hubs and the axles are incompatible with an Impreza.
toddvero is offline   Reply With Quote
Old 12-13-2008, 11:58 AM   #11
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Sorry for the old thread bump, but does anyone know if the '02 WRX rear diff spline count is the same for 5MT and 4EAT?
beaviscih is offline   Reply With Quote
Old 10-13-2009, 02:04 PM   #12
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
BUMP this thread answers questions but needs an update.... Request for interchangibility between wrx and sti axles early 04 wrx rear axles and what inner outer cv joint compatibility can you build to fit an R180???
srREXed is offline   Reply With Quote
Old 12-06-2011, 01:32 AM   #13
sti4lifer
Member#: 206328
bump! trying to fit a 98 legacy axle in 2001 RS LSD diff. will it work?
sti4lifer is offline   Reply With Quote
Old 12-06-2011, 10:52 AM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If you have it there... fit it together.
Yes it will work.
FuJi K is online now   Reply With Quote
Old 12-06-2011, 03:53 PM   #15
sti4lifer
Member#: 206328
thank you!
Old 01-08-2012, 01:30 PM   #16
Driveshaft shop
Member#: 306253
great info
Driveshaft shop is offline   Reply With Quote
Old 07-17-2012, 10:40 PM   #17
drowsyd3m0n1c
Member#: 326484
1999 impreza/foreste
silver/silver
Unhappy lost without my preza
but what about the rear diff? can i plug my 99 impreza axels into that or am i looking at the end of my preza, the legacy that i'm looking at tearing apart is technically a perfect car BUT its not my preza, blew the auto trans in mine and want to do a swap to 5speed, the donor car is currently looken to be a 2000 legacy 2.5L 5speed with 4.11 gears have to check the engine make sure is just out of time, before i even began taking aprt this to stick in my pretza will it work? as far as i know the subframes are no good from the legacy for in it sounds like the axels wont fit the hub, any one have a clue? cause i cant seem to find one
drowsyd3m0n1c is offline   Reply With Quote
Old 07-14-2013, 09:22 PM   #18
blckbooster
Member#: 271786
GCcoupe-GDwagon-STIhatch
back from the dead.
Does anyone know 06-07 wrx rear axle spline count? I've acquired 07 wrx rear hub spindle/knuckle with 2pot caliper and I want to see if I can install it to my 01 RS.
blckbooster is offline   Reply With Quote
Old 07-15-2013, 05:41 PM   #19
blckbooster
Member#: 271786
Originally Posted by blckbooster View Post
back from the dead.
Anyone??
Old 02-04-2016, 12:29 PM   #20
codermyers
Member#: 382196
1994 Impreza L
green
Can't believe this is the most complete axle thread out there...
2001 Legacy Outback - 25/25 26mm
1994 Impreza L wagon - 22/24 25mm
as I just found out the hard way. Old GC/GF axles are also equal length, whereas most of the others are offset by 0.3".
Looks like I have to do a rear disc brake conversion with axles, plus modify the diff mounts to get this 4.44 LSD to work on the GF.
codermyers is offline   Reply With Quote
Old 02-04-2016, 02:32 PM   #21
codermyers
Member#: 382196
1994 Impreza L
green
I just looked at rear hubs on a parts interchange site and all these:
2002 WRX rear:
25/24, 24mm
2002 RS rear:
25/24, 23mm
2000-2001 RS rear:
25/24, 23mm
1999 Forester rear:
25/24, 23mm
1995 Legacy rear:
22/24, 23mm ??
plus the 94 impreza I measured at 25mm,
all have the same rear hub part #. So, that means all the 24 spline outer hubs and shafts are interchangeable, and I can just get rear driveshafts from any of these vehicles. I hope.
axle question - spline count z Transmission (AT/MT) & Driveline 5 07-12-2011 08:57 PM
wrx front drive axle spline count??? tranny mounts! brodie.gordon Transmission (AT/MT) & Driveline 0 08-12-2009 05:59 PM
spline count pilfflip 'Old School' Subaru Forum 2 11-01-2004 11:43 PM
Ring and Pinion and Spline Count RockRaceScooby Transmission (AT/MT) & Driveline 0 03-29-2004 11:29 AM
Axle spline count RedBrighton96 Transmission (AT/MT) & Driveline 4 10-25-2002 05:03 PM
