Old 07-11-2003, 02:50 PM   #1
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Wink Psssssstt.............. (TXS A/F rumors)
... anyone heard when TXS is supposed to release the UTEC wideband A/F feature?
jpmarotta is offline   Reply With Quote
Old 07-12-2003, 02:51 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
nope...
you would have to buy a wideband sensor as well, and those are really expensive...
rhdude is offline   Reply With Quote
Old 07-12-2003, 03:15 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Sensor expense would depend on which wideband sensor was required. If they opted to support the Bosch LSU4, a planar wideband sensor, then that sensor can be purchased for $28.99 plus shipping.
Jon [in CT] is offline   Reply With Quote
Old 07-12-2003, 05:30 PM   #4
Strng1dah
Member#: 7053
[email protected]
nope...
Actually they are. I'd hold off on buying a wbo2 until the end of summer
Depends on the sensor. from what Nathan has hinted at it should probably use the cheapo lsu4 sensor, and not the expensice l1h1 that is used on most wbo2 sensors ont he market.
Techedge is also coming out with v2.0 of their sensor which will use the same cheap lsu4 sensor.
Strng1dah is offline   Reply With Quote
Old 07-12-2003, 06:45 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Depends on the sensor. from what Nathan has hinted at it should probably use the cheapo lsu6 sensor, and not the expensice l1h1 that is used on most wbo2 sensors ont he market.
Techedge is also coming out with v2.0 of their sensor which will use the same cheap lsu6 sensor.
The TechEdge V2.0 meter can be ordered now (see http://wbo2.com) and it uses the inexpensive Bosch LSU4 planar wideband sensor. There is actually a cheaper meter available ($350) now that can read/control either a Bosch LSU4 or an NTK L1H1 wideband sensor and its price includes a sensor.
BTW, I hope nobody reading this expects/hopes that their existing UTEC will be able to directly read/control a wideband A/F sensor with just a software change. That won't happen. It is conceivable, though, that a black box (essentially, a wideband meter) could be interposed between a wideband sensor and existing UTECs.
Old 07-12-2003, 06:53 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Where can you get the $350 meter including the sensor?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 07-12-2003, 09:04 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
-- Ed
http://www.innovatemotorsports.com/
Old 07-13-2003, 01:16 AM   #8
Strng1dah
Member#: 7053
[email protected]
Brain fart on the sensor number, thanks for the correction.
I signed up for notification when the TechEdge 2.0 was supposed to be available and apparently they never emailed me.
