Old 07-23-2003, 06:58 AM   #1
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Default Tranny Cocktail
First off, I have never experienced any grinding at all. But I am not a fan of the notchy gearchanges in our cars. Due to the many problems people have encountered I have avoided the switch to synthetic gear oil. I have changed fluid every 15-20k at my dealer. They use Agip lubricants. Last week I had my fluid changed and decided to add a quart of Red Line MT-90 to the tranny. No grinding at all and all notchiness has disappeared. I highly recommend this cocktail to all of you who are caught between "synthetic or non-synthetic" for your gearbox.
Barry is offline   Reply With Quote
Old 09-24-2003, 05:08 PM   #2
03WRXMA
Member#: 35081
2012 WRX
Hows this been going for you?
-dave
03WRXMA is offline   Reply With Quote
Old 09-25-2003, 01:45 AM   #3
wolf8314
Member#: 9185
2012 Toyota Tundra
I just changed my gear oil. I used Molbil 1 synthetic, awesome, completely changed the way my car shifted.
wolf8314 is offline   Reply With Quote
Old 10-10-2003, 04:48 PM   #4
zoomfactor
Member#: 30440
03 WRX
WR Blue
Since we're talking cocktails...
I just topped off my fluid with Lucas oil additive at the suggestion of an old racer. It seems to "stick" to the gears and it has dramatically improved the feel of the shifter.
zoomfactor is offline   Reply With Quote
Old 10-11-2003, 12:54 AM   #5
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
I heard the MT-90 is a GL4 which will corrode the copper syncros. Our boxes need GL5's...
04EJ20 is offline   Reply With Quote
Old 10-11-2003, 09:58 AM   #6
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
-dave
8.2k miles with no problems
over 59k miles on the car........yup, I love to drive..........
Old 10-11-2003, 11:56 PM   #7
AdmireWantWillLove
Member#: 24146
2004 GTO
This could be all in my head but my car is coming up on 10,000 miles and the shifter does not seem as smooth as it used to be.
I have the OEM short shift. Is there anything I can do now to help with it feeling a little more smooth? Should I get new bushings? Is it too early to change my fluid?
Thanks
AdmireWantWillLove is offline   Reply With Quote
Old 10-12-2003, 10:00 AM   #8
SidneyWRX
Member#: 36099
'02 rex
I had stock tranny fluid in my rex for about 27K miles. Switched to Mobil1 for about 4K miles and my 4th gear synchro started to slip. I switched to Redline lightweight shockproof and had it in for almost 5K miles and haven't had any problems. Slip is gone, all is good! I have the OEM short shifter and changed to kartboy shifter bushings and love it. Go for it.
SidneyWRX is offline   Reply With Quote
Old 10-12-2003, 11:29 PM   #9
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Here's the real story on tranny fluids.
GL4 fluids have been used for ages in manual trannies. Why? Because they work great with synchros!
GL5 fluid on the other hand was once known as a fluid which would eat the brass/copper in synchros. Why? Because of the extra EP (Extreme Protection) additives required to gain GL5 status.
However, modern GL5 fluids are much better in this regard and are no longer as bad for synchros as they used to be, especially synthetics.
drees is offline   Reply With Quote
Old 10-12-2003, 11:51 PM   #10
04EJ20
Member#: 44057
2004 WRX STi
WR Blue Pearl
Oh hell! I'm going back to ShockProof like I used in my Jetta. It was the best stuff I've ever used and this grinding in my Rex has got to go!!!
Thanks for the info Drees!
Old 01-21-2004, 09:28 PM   #11
03WRXMA
Member#: 35081
2012 WRX
Bump^ for the great info.
And I want another review... since its cooooooold out now...
Old 01-22-2004, 03:43 AM   #12
Barry
Member#: 11554
2016 STI
Ice Silver Metallic
Dave- Still working just fine.......14k miles. Cold weather shifting continues to be better than OE fluid only........might actually go 2 qts. MT-90/ 1.7 OE on next change. Read where some folks have gone straight MT-90 and love it
Old 01-22-2004, 07:42 PM   #13
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Conduit is offline   Reply With Quote
Old 01-22-2004, 10:59 PM   #14
Aspen_2.5RS
Member#: 3310
I'm getting a grinding in 2nd. I just changed from Coastal 75W90 to Redline 75W90NS and it's still doing it.
I've heard one bad thing about Lucas oil stabilizer and one good thing. One guy said it eliminated his grinding all together and the other guy said "if you want to f up your tranny go right ahead".
Also when I drained the fluid there was a chunk of metal on the plug. So I guess I just wasted $40 on new fluid for it.
Cam
Aspen_2.5RS is offline   Reply With Quote
Spencer's Tranny Cocktail smh0101 Transmission (AT/MT) & Driveline 0 03-06-2008 11:23 AM
Uncle Scotty's Tranny Cocktail? gryffinwings Transmission (AT/MT) & Driveline 35 12-30-2007 09:03 PM
Tranny Cocktail Question for MT's Not All There Transmission (AT/MT) & Driveline 3 11-14-2007 10:56 PM
US tranny cocktail? wrxisthebest Transmission (AT/MT) & Driveline 10 07-15-2007 11:38 PM
(Houston:) Uncle Scottys Tranny Cocktail.....need the last ingredient !! HELP KnightWRX Texas Impreza Club Forum -- TXIC 16 12-20-2006 12:11 AM
