Old 08-19-2003, 10:13 PM   #1
downeyer
Member#: 10784
Platinum Silver Metallic
Default FYI...Where to apply grease during brake pad install
Hopefully this will resolve some of the noise issues seen after brake pad installs.
10/14/04 - Update on the grease I used for my install: When installing my last set of brake pads, I used Squeak Relief Caliper Grease. The Subaru Service maunal calls for Molykote Grease, which I couldn't find anywhere. Squeak Relief Caliper Grease contains Molybdenum Disulfide, which is rumored to be the main lubricant in the Molykote Grease. Either way, I have yet to get any squeaks out of my brakes for the last 5,000 miles.
URL=http://www.autobarn.net/squeakrelcal.html
Regards,
Eric
downeyer is offline   Reply With Quote
Old 08-19-2003, 11:12 PM   #2
driver8
Member#: 6997
Thanks. I'm installing some Hawk pads this weekend, so I don't have the Subaru kit .
I was intending to use the "blue stuff" and didn't know about applying grease to the shim/back of the pad. Should I use grease, and if yes, what type?
driver8 is offline   Reply With Quote
Old 08-20-2003, 07:28 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
You should apply anti-squeal compound which is sold at most parts store about 50 cents / pack.
tmat3 is offline   Reply With Quote
Old 08-21-2003, 04:03 AM   #4
MIQ_WRX
Member#: 11382
2002 WRX Wagon
Blue Pearl
Default Permatex Caliper Grease
I used the Permatex caliper grease (dark green, says safe for anti squeal shims on back of package) sold at Checker - $4. Do not get grease on surface of the pad that presses against the rotor. I used a very small amount at the points shown in the diagram.
That picture is an even better representation than the one in the service manual. Nice! Thanks for the post downeyer.
-MIQ
MIQ_WRX is offline   Reply With Quote
Old 08-24-2003, 05:20 PM   #5
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
someone should clean up that diagram and make it a sticky.
Steppin Razor is offline   Reply With Quote
Old 09-25-2003, 08:29 AM   #6
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
That "rubber" shim between the metal plate and back of pad: What if it's not rubber anymore? Like it's just metal?! Uhhh cuz that's what mine looks like. Should I just coat it or something or what?
WRX34
WRX34 is offline   Reply With Quote
Old 09-25-2003, 08:50 AM   #7
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I don't use those stupid shims.....they cause more noise then they help......at least that's what I've found
I do use the clips though, and put anti-squeal giz on the back of the pad and grease stuff in the clips.
Legacy777 is offline   Reply With Quote
Old 10-02-2004, 08:32 AM   #8
Johnzim63
Member#: 33330
2002 WRX 5spd sedan
Amen ta dat! Never used shims and never had a problem.
Johnzim63 is offline   Reply With Quote
Old 10-02-2004, 11:18 AM   #9
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I never had a rubber-coated shim. Just the metal one that goes on the backside of the brake pad...
Hank3 is offline   Reply With Quote
Old 05-04-2006, 07:11 PM   #10
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm
So, don't use the shins even on the STI Brembo when using aftermarket pads such as Hawk HPS?
chuglobal is offline   Reply With Quote
Old 07-22-2006, 07:03 PM   #11
MoJack
Member#: 90276
'05 Sti:Crystal Met
is my drug of choice.
Bump for this question.
MoJack is offline   Reply With Quote
Old 07-22-2006, 07:14 PM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hey Richard -
You don't need the shims.
Old 07-22-2006, 07:15 PM   #13
boofer
Member#: 73949
2008 Evolution X GSR
Octane Blue
^^ Interested in that as well.
boofer is offline   Reply With Quote
Old 07-22-2006, 10:44 PM   #14
tcspeer
Member#: 113319
1997 Subaru Legacy
Green
My Legacy wagon has been used on a mail rt. now for 10 years, I put around two sets of pads a year on it and have not used those silly shims in around 9 years, away with them.
tcspeer is offline   Reply With Quote
Old 06-28-2007, 01:46 AM   #15
Airborne Guy
Member#: 68516
2015 YAMAHA R1 RAVEN
R.I.P. MasterTuned©
Originally Posted by chuglobal View Post
So, don't use the shims even on the STI Brembo when using aftermarket pads such as Hawk HPS?
What about using the stock shims plus the grease? Thanx
Airborne Guy is offline   Reply With Quote
Old 06-28-2007, 12:58 PM   #16
MT_WRX
Member#: 24409
'03 Comatose WRX
Wagon. Parked.
Some pads, like the Hawks, have the shims built into the pad. Therefore they recommend that you don't re-use the stock shims.
The stock pads have the shim kits because there are no built in shims.
MT
MT_WRX is offline   Reply With Quote
Old 06-28-2007, 02:01 PM   #17
WebMasterP
Member#: 121062
2006 STi [STU Trim]
World Rally Blue
While we're FYI'ing it up:
FYI, EBC pads don't come with grease, so if you're installing them at say, 12 in the morning to get ready for AutoX the next day, you get squeeky pads because all the stores are closed, good game. Even the premium but far less expensive street pads I bought for my girlfriend's Civic came with anti-squeel grease.
WebMasterP is offline   Reply With Quote
Old 07-16-2010, 11:06 PM   #18
demoncamber
Member#: 252268
Glad I bought that synthetic brake grease a month ago!
demoncamber is offline   Reply With Quote
Old 03-28-2014, 01:25 PM   #19
playford
Member#: 386019
ta-da, your wish is my command
https://www.flickr.com/photos/davidp.../photostream// (it's not linking to the right picture, just go left one and it should be there)
don't know how to add the pictures from my flickr. so maybe you can re-link it from somewhere
playford is offline   Reply With Quote
Where to buy OEM rear brake pads? 1BadEJ20 Brakes, Steering & Suspension 4 03-15-2007 11:01 PM
Tampa: where to buy some autox brake pads mofugga South East Region Forum 2 08-18-2006 09:39 PM
Where to break in new brake pads in Dallas? javanaut Texas Impreza Club Forum -- TXIC 6 05-01-2006 10:22 AM
Where to find Axxis Ultimate brake pads. jayan357 Mid Atlantic Impreza Club -- MAIC 6 01-21-2006 01:31 AM
Where can I find decent brake pads locally? Robmat South East Region Forum 1 07-02-2002 09:29 PM
