Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds
Old 09-12-2003, 10:55 PM   #1
Aspen_2.5RS
Member Sales Rating: (473)
Member#: 3310
Smile FS: 02 WRX parts from salvage car 10/2/03
UPDATED and sorted on 12/3/04. Please do not ask for sensors, engine wiring harness, bulkhead harness, body parts other than what is listed, or wrx engine parts. I will not even respond. Please read through the list thoroughly before asking, thanks! I do have some miscellaneous connectors. The rest of this stuff is going to go for cheap. I need the space in the garage.
Alright, this stuff has to go. The shell is sold/gone!
AVAILABLE ITEMS:
- 02 wrx brand new water temp sensor, still in plastic
- 02 wrx miscellaneous wiring connectors (ask me, I might have it)
- 02 wrx cruise control unit
- 95L fuel pump
- 02 wrx windshield wiper motor/arms
- 02 wrx plastic shroud for front windshield (covers wiper motor and arms)
- 02 wrx emissions evaporator black box
- 02 wrx parking brake (e-brake, emergency brake) cables
- 02 wrx rear brake parts (springs, shoes, clips, etc.)
- 02 wrx air conditioning lines minus (condensor to compressor 73421)
- 02 wrx interior switches - power door locks and power windows
- no floormats
- 95L wagon most rear lateral arms (2)
- 95L rear axles (one needs to be rethreaded)
- 95L 5 speed tranny (crunchy 2nd, unless double clutched, will come with cable and used clutch/pressure plate if you want them) CHEAP
- 02 wrx dome light assembly
- 02 wrx glass - 3 doors (driver rear not available)
- 02 wrx weatherstripping from all 4 doors (just the doors, not the shell)
- 95L fans with brackets
- 95L radiator
- 02 wrx weatherstripping from trunk
- 02 wrx center rear brake light
- 02 wrx 3 power window motors (pass. front no longer available)
- 02 wrx 4 power lock motors
- 02 wrx blower motor for heater/ac
- 02 wrx gas tank
- 02 wrx abs unit
- 02 rear lines/rotors
- 02 wrx brake proportioning valve
- 95L front calipers and rotors
SOLD ITEMS:
- 02 wrx a/c line firewall to compress 73422 SOLD
- 02 wrx a/c line cond. to compress 73421 SOLD
- 02 wrx driver side front control arm SOLD
- 02 wrx 5 speed trans, bad 2nd gear sync. SOLD
- 95L 5 speed open rear diff SOLD
- 02 wrx used clutch and pressure plate SOLD
- 02 wrx 4 exterior wrb handles SOLD
- 02 wrx cruise control int. wiring connector SOLD
- 02 wrx fender sidemarker harnesses SOLD
- 02 wrx head light harnesses/plugs SOLD
- 02 wrx front pass. interior handle assembly SOLD
- 02 wrx ashtray SOLD
- 02 wrx front passenger pwr window switch SOLD
- 02 wrx front passenger window motorSOLD
- 02 wrx clutch fluid reservoir assembly (whole deal)SOLD
- 02 wrx passenger front control arm SOLD
- 02 wrx fog light wiring harness SOLD
- 02 wrx center A/C vents SOLD
- 02 wrx e-brake handle/assembly SOLD
- 02 wrx clutch slave cylinder SOLD
- 02 wrx remote fuel latch SOLD
- 02 wrx remote fuel door cable SOLD
- 95L starter SOLD
- 95L shift linkage SOLD
- 95L tranny crossmember SOLD
- 95L tranny mount SOLD
- 95L driveshaft CHEAP SOLD
- 02 wrx springs/struts with tophats SOLD
- 02 wrx driver rear window switch SOLD
- 02 wrx fan/subfan relays/fuses SOLD
- 02 wrx Climate controls with cablesSOLD
- 02 wrx sideskirts SOLD
- all 02 wrx hubs SOLD
- 95L engine and ecu SOLD
- 02 wrx horns SOLD
- 02 wrx axleback with no muffler SOLD
- 02 wrx driver rear seatbelt SOLD
- 95L grill SOLD
- 95L driver side headlight SOLD
- 99RS busted headlight SOLD
- 22b replica hood vents SOLD
- 02 wrx wheels/tires SOLD
- 02 wrx driver rear glass SOLD
- 02 wrx integrated module SOLD
- 02 wrx rear seat SOLD
- 02 wrx clock harness SOLD
- 02 wrx a/c compressorSOLD
-02 wrx windshield wiper/turn signal stalksassemblySOLD
- 02 wrx stock uppipeSOLD
- 02 wrx sunvisorsSOLD
- 02 wrx gauge clusterSOLD
- 02 wrx rear calipers SOLD
- 02 wrx rear glass window SOLD
- 02 wrx rear lateral links (all) SOLD
- steering wheel (no center section/airbag)SOLD
- kartboy foglight brackets SOLD
- 02 wrx rad. fan motors/fans SOLD
all rear lateral links SOLD
- 02 wrx rear subframe SOLD
- 02 wrx steering rackSOLD
- 02 wrx crossmember SOLD
- 02 wrx driver cntrll/pass. rear window switch SOLD
- 02 wrx master lock/win. switch SOLD
- 02 wrx stock downpipe SOLD
- 3" stromung midpipe SOLD
- rear trailing arms SOLD
- interior piece -handbrake comes through SOLD
- all interior door panels SOLD
- all exterior door panels SOLD
- 95L master cylinder and brake booster SOLD
- 02 wrx center diff from spare tranny SOLD
- wrx front axles - SOLD
- wrx rear axles- SOLD
- 02 wrx glovebox- SOLD
- hoodscoop - SOLD
- antenna assembly SOLD
- armrest extension SOLD
- clock pod - SOLD
- map light assembly SOLD
- retractable cupholder (center of dash) - paint rubbed off on one corner SOLD
-wrx cd player and speakers SOLD
-lower driver side dash panel SOLD
-parking brake dust boot SOLD
-passenger side fender SOLD
-silver trim around center vents SOLD
-1 driver side wrb side mirror - SOLD
-1 passenger side wrb side mirror- SOLD
-1 driver side headlight - damaged SOLD
If you have something in mind let me know.
Complete Drivetrain is not available (this means wrx engine, trans, driveshaft, rear diff, factory boost solenoid, fuel pump controller). If you are looking for exterior body pieces: front/rear bumpers, grill, foglights, trunk, were destroyed. Thanks,
Cam
Aspen_2.5RS is offline   Reply With Quote
Old 09-12-2003, 11:02 PM   #2
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
passenger fender????
mine is smushed. silver would be a bonus!
ZoomnWRX is offline   Reply With Quote
Old 09-12-2003, 11:15 PM   #3
Kwyjibo
Member Sales Rating: (8)
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
i would like the dash piece around the stereo. Not the silver trim...but the grey vinyl covered area under the cup holder and above the ash tray.
let me know.
Kwyjibo is offline   Reply With Quote
Old 09-12-2003, 11:15 PM   #4
Aspen_2.5RS
Member#: 3310
Post
Hey,
The car is wrb. The fender is probably usable, but it's not perfect. There is some paint worn off of the bottom section where the bottom of the headlight is. Also there is a slight indentation above the lip of the fender.
Also I have not decided if I'm going to part out exterior pieces or sell it as a race car shell (as I have been made an offer for). So at this time other than the mirrors, no exterior body panels are being sold.
Thanks,
Cam
Old 09-12-2003, 11:23 PM   #5
Aspen_2.5RS
Member#: 3310
Kwyjibo,
That shouldn't be a problem. You're wanting the actual exterior housing for the radio and cupholders, right?
Cam
Old 09-12-2003, 11:31 PM   #6
Tex-WReX
Member Sales Rating: (4)
Member#: 7107
2014 Mustang GT
Armrest extension perhaps?
Tex-WReX is offline   Reply With Quote
Old 09-12-2003, 11:40 PM   #7
Aspen_2.5RS
Member#: 3310
Post
The arm rest extension is there, but it has a slight dimple in it. The dimple is smaller than the circumference of an pencil eraser.
Cam
Old 09-12-2003, 11:48 PM   #8
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Originally posted by Aspen_2.5RS
Kwyjibo,
Cam
actually i think the peice starts below where the cup holder is and above the ashtray.
i'm not exactly sure how else to describe it, but it looks like a piece that will come out on its own....basically the piece that the sivler stereo trim goes into....
maybe i can take a pic if you are still confused...
Old 09-13-2003, 12:15 AM   #9
Aspen_2.5RS
Member#: 3310
Post
I'll take a look at it tomorrow sometime.
For anyone who wants to discuss parts or price I can be reached on aim as well: Aspenrs01.
Thanks,
Cam
Old 09-13-2003, 01:33 AM   #10
WRX_Aaron
Member#: 23446
Do you have the two little things that hold down the cover for the factory boost solenoid...(near the passenger firewall)
WRX_Aaron is offline   Reply With Quote
Old 09-13-2003, 01:44 AM   #11
Aspen_2.5RS
Member#: 3310
I only have one of them. Who knows what happened to the other one.
Cam
Old 09-13-2003, 01:57 AM   #12
driftnawrx
Member#: 37140
Midnight Black
Default Front Bumper Cover
Do you have a front bumper cover? If so, please pm with details -
Thanks
Tan
driftnawrx is offline   Reply With Quote
Old 09-13-2003, 02:11 AM   #13
gtwagon941
Member Sales Rating: (10)
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
do you have the front seats?
gtwagon941 is offline   Reply With Quote
Old 09-13-2003, 02:29 AM   #14
cmaj7
Member Sales Rating: (1)
Member#: 12677
2002 Subaru WRX
WR Blue
Default Foglight switch + connector
I'd like the foglight switch and the connector with a few inches of wires attached....if it's available!
cmaj7 is offline   Reply With Quote
Old 09-13-2003, 02:37 AM   #15
wrx112
Member Sales Rating: (2)
Member#: 35048
do you have the oil pan and also i need bolts where are you located up at? thanx
mike
wrx112 is offline   Reply With Quote
Old 09-13-2003, 08:59 AM   #16
shields102
Member#: 9598
02 wrx
white
i am interested in the dark gray plastic shifter surround, the piece that goes from under the ashtray, to just past the shiftboot.
shields102 is offline   Reply With Quote
Old 09-13-2003, 11:13 AM   #17
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
SubFrame Front?.. The U shaped tubing under the engine an front frame box...
How Much? Where are you?
for obvious reasons I'd rather not ship this.... (but likely will if the $ are right)...
nick
LyveWRX is offline   Reply With Quote
Old 09-13-2003, 12:00 PM   #18
0260B4U
Member#: 33249
2003 WRX
white
That silver trim piece around the stereo if its in mint condition I got a couple scratches on mine. Wish the outer peice was spoken for i need that one too.
Dont suppose it has the OEM boost gauge?
0260B4U is offline   Reply With Quote
Old 09-13-2003, 12:09 PM   #19
cypha25
Member#: 18291
02 2.5rs
midnight
what about the steering wheel?
cypha25 is offline   Reply With Quote
Old 09-13-2003, 12:51 PM   #20
Silverscoob
Member#: 14930
2006 Evolution
Graphite gray
what do you want for the passenger side front door panel? Id also like to know if you have the glove box and maybe the black plastic seat belt cover for the passenger side. Thanks
Silverscoob is offline   Reply With Quote
Old 09-13-2003, 01:04 PM   #21
okiedude
Member Sales Rating: (55)
Member#: 37736
2003 WRX Race Wagon
Hi Aspen-I am looking for the lower dash panel/drivers side. This is the panel that goes from the center console over to the door and has the fog light switches and fuse panel cover in it. I do not need the switches or fuse panel cover, just the large panel. Let me know here or send me a PM.
Thanx, OKD
okiedude is offline   Reply With Quote
Old 09-13-2003, 01:09 PM   #22
StiDreams
Member Sales Rating: (3)
Member#: 26315
07 Outback
Silver/Silver
How about the turbo inlet pipe?
StiDreams is offline   Reply With Quote
Old 09-13-2003, 01:42 PM   #23
Porkchop-WRX
Member Sales Rating: (6)
Member#: 33293
2011 4-door STi
Plasma Blue
I need this weird piece inside the door panel.I'm going to try and describe it to you. When you take off the door panel there are those triangle things that hold the door in place up top. I think it was pink but not 100% sure. If you have that piece that would be great. I would actually like more then one if you can. Let me know.
Porkchop-WRX is offline   Reply With Quote
Old 09-13-2003, 08:10 PM   #24
Aspen_2.5RS
Member#: 3310
Post
Kwyjibo, I still can't figure out what part you are wanting. It looks like the insides of the radio surround are all molded to the outside piece...could be wrong though (may not even be what you're talking about).
driftnawrx, the front bumper cover was destroyed in the accident.
gtwagon941, the front seats are currently in my wagon and I have not decided if I'm going to sell them or keep them. If I do sell them "pleaides" has dibs on them.
cmaj7, I have the foglight switch. Not sure what is fair on that, let me know what you think.
wrx112, the oil pan is classified as a drivetrain component = not for sale.
shields102, I have that piece.
LyveWRX, I think the stuff you're talking about are things I'm going to use in my swap.
0260B4U, I have that and it's in mint condition. No factory boost gauge, sorry.
cypha25, the airbag deployed so all I have is just the rim itself. But I need to keep it b/c I still need to manuever the car around. I'll probably post it up for sale later.
Silverscoob, I have all those parts. I'm not sure what door panels usually go for. I'm thinking about $80 plus shipping, though.
okiedude, I have that lower dash panel. That is a big single piece.
StiDreams, that's classified as a drivetrain component = not for sale.
Porkchop-WRX, I have those pink things (saw them when I pulled the speakers out). Do you need just enough for one door panel?
Some of this stuff I'm sure from subaru isn't cheap, but I guess either email me, post here, pm me, im me or something and we can work out a price.
Thanks,
Cam
Old 09-13-2003, 08:35 PM   #25
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Hey man, what about the passenger side ABS Unit?
latinskllz is offline   Reply With Quote
FS: 02 WRX Parts Leftover Car Sold handfulopeter MAIC Private Classifieds 29 03-08-2009 08:53 AM
02 WRX part out Complete car 80K miles! JDM Importers SWIC Vendor Classifieds 4 06-14-2006 09:39 PM
FS: Stock WRX parts From a 2.5RS kit pimpomtic Private 'For Sale' Classifieds 2 06-24-2004 06:57 PM
FS: OEM WRX parts from 02 WRX WRXVII Private 'For Sale' Classifieds 6 04-09-2004 07:32 PM
FS: lots of parts from my car! pbnj9786 Private 'For Sale' Classifieds 20 09-24-2003 09:46 PM
