Old 10-08-2003, 05:30 PM   #1
AllSubaru.com
Vendor
Member#: 19819
Default WRX Oil Filter Part Numbers - 060 vs 080 - New Details!
Hey gang...
after our lengthy discussion on the "new" 080 2004
oil filters, we were prompted to give Subaru a ring
and find out exactly what oil filter is to go where...
and possibly eliminate this confusion.
see: http://forums.nasioc.com/forums/show...hreadid=430542
Our dealership spoke at length with 2 of the
higher - uppers at Subaru
and have the final low down
on this oil filter confusion...
and yes.... they've changed their mind again
As of today, 10/8/03 - we were told the following:
all Subaru Turbo's from 2002 - on
should begin to use the 15208AA080 (black)
as a replacement oil filter.
yes, all 2.0 and 2.5L TURBO's
but....
if you have used or
have purchased the AA060 (white) oil filter -
that is okay!!
You will NOT hurt your car. It's perfectly fine to use the 060
so please, do not panic. Your car will function just fine
with the 060 in place - NO WORRIES
Reason for the change??? ....drumroll please....
.....a manufacturing change.....
yep. different manufacturer <---that is all....
so to keep it simple - Subaru is stating
that ALL MY2002 and newer -
turbo models only - should use AA080
and all NA (non turbo'd) should continue
to use the AA060 (with the exception of the H6, SVX, Loyale...)
hope this helps....
any questions just ask....
Jamie
www.allsubaru.com || aka Carter Subaru, Seattle WA
AllSubaru.com is offline   Reply With Quote
Old 10-08-2003, 06:21 PM   #2
Coati
Member#: 9106
2002 WRX Wagon - PSM
2008 STI - Aspen White
So it's not Purolator making the filters anymore?
Coati is offline   Reply With Quote
Old 10-08-2003, 07:17 PM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS/70 Van
02 WRX Rally Stud
no idea.... who the new vendor may be or not be
that information was not disclosed.
i was told this is basically to keep it simple.
non turbo = AA060
turbo = AA080
that way there is not more confusion
no "production break" to deal with... etc.
Jamie
Old 10-08-2003, 09:40 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Default Re: WRX Oil Filter Part Numbers - 060 vs 080 - New Details!
Thanks for the clarification!
Guess I'll be using the 060's for a while (have a bunch of them in the garage) - then will transition to the tiny filter.
Old 10-09-2003, 12:01 AM   #5
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Default Re: Re: WRX Oil Filter Part Numbers - 060 vs 080 - New Details!
Me too - I just bought an entire case of 12
Hank3 is offline   Reply With Quote
Old 10-09-2003, 09:52 AM   #6
Hank3
Member#: 16157
'03 Mazda P5 <><
How about making this thread a "sticky" for a little while?
Old 10-09-2003, 10:43 AM   #7
vile
Member#: 32371
'02 t-rex wagon
platinum
so if i understand this correctly, the new 080 filter is going be used because they are switching manuf., not because it was too big and was too close to the headers?
and if they are switching manuf., how come they did still going to get the 060?
personally, i think i'm going to stick w/the old part, the filter is bigger(from what's been posted), which will hold the recommend capacity, not sure how much less the new filter will be.....wonder if it's even goign to be an issue
vile is offline   Reply With Quote
Old 10-09-2003, 11:18 AM   #8
AllSubaru.com
Vendor
Member#: 19819
The AA060 is THE oil filter for all of the NA engines.
the 2.5 Legacy and RS (non turbo'd), the non Turbo Baja....
all of these cars use the AA060, thus they still need them.
perhaps they had a company make the AA080 for the STi...
and got a good deal/cost savings...
then decided it would be easier, more effective to simply
use it on ALL of their late turbo models???
makes sense to me....
and sure... i can get this stickied for a bit.
thanks gang
Jamie
Old 10-09-2003, 01:50 PM   #9
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
Thanks for the clarification, but I still can't find the 080 parts on your web site : ) Any help?
Thanks,
-st
singletrack is offline   Reply With Quote
Old 10-09-2003, 03:48 PM   #10
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Which filter is recommended for 1991-1994 Legacy Turbos?
Is there any chance we could find out who the new manufacturer is?
vrg3 is offline   Reply With Quote
Old 10-09-2003, 04:12 PM   #11
AllSubaru.com
Vendor
Member#: 19819
Thanks,
-st
Available on line now:
http://secure.cartsvr.net/catalogs/c...showprevnext=1
and NO THIS IS NOT RECOMMENDED (will not fit) FOR THE OLDER TURBOS... ONLY 2002 AND NEWER
Jamie
Old 10-11-2003, 01:46 PM   #12
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
The 080 filter most definitely *will fit* on 91-94 Legacy turbos.
In fact, the exhuast manifolds, the exhaust manifold cross pipe, the turbo joint pipe (up-pipe) and down pipe from a newer ej205 (wrx) will all fit an older ej22t - except that the oem uppipe on the ej22t is catless. Except for the fact that the coolant nipples point in different directions, the oil/coolant oil coolers are interchangeable also.
So, given the reasons stated in the tech TIPS for the change to the new smaller filter, the new 080 should be used on older ej22t's as well.
No that it really matters, though... they'll both fit and work well.
Austin is offline   Reply With Quote
Old 10-13-2003, 11:07 AM   #13
AllSubaru.com
Vendor
Member#: 19819
Thumbs up
THANKS Austin!
Old 10-16-2003, 09:43 AM   #14
subarurabbit
Member#: 4083
2006 OBS SE
regal blue
I e-mailed SOA and they said use 060.
1991 Legacy Sport Sedan was the only year to have an oil cooler.
subarurabbit is offline   Reply With Quote
Old 10-16-2003, 11:17 AM   #15
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Thanks!
Old 10-20-2003, 10:12 PM   #16
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
A subaru mechanic told me the new filter has a check valve inside that keeps the oil from draining from the turbo cooling lines and engine internals after the car is shut off.
dropmech is offline   Reply With Quote
Old 12-01-2003, 01:54 PM   #17
method2madness
Member#: 49115
2002 Subaru impreza
black
Exhaust plumbing and coolant has no relivation to a oil filter fitting properly on a car
method2madness is offline   Reply With Quote
Old 12-01-2003, 04:14 PM   #18
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
I believe the word you were looking for is "relevance."
You're right, exhaust and coolant plumbing are not normally relevant. Exhaust piping location does, however, become relevant to the discussion when Subaru cites it as the reason to use a new smaller oil filter on their turbo models.
Here's page 8 from their August 2003 TechTIPS:
Old 01-12-2004, 12:48 AM   #19
JDMSubaru
Visiting NASIOC Timeout
Member#: 40546
does anyone know this for sure?
can anyone substantiate it?
JDMSubaru is offline   Reply With Quote
Old 01-16-2004, 11:26 PM   #20
demi
Member#: 41976
2004 WRX wagon
WR Blue
What is the dealer retail price for the 080 filter?
demi is offline   Reply With Quote
Old 01-19-2004, 11:22 AM   #21
AllSubaru.com
Vendor
Member#: 19819
Dealers are free to set RETAIL to whatever they please.
Suggested MSRP from Subaru is $7.87 per filter.
Jamie
www.allsubaru.com
Old 01-23-2004, 06:34 PM   #22
JDMSubaru
Member#: 40546
so much for answering my question
Old 02-12-2004, 10:45 AM   #23
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I'm curious too. I just bought a bunch of the new ones from Carter and they are both much smaller than the PurOne and more expensive. If they really are better, great, but if not I'll go back to PurOne.
Mike Wevrick is offline   Reply With Quote
Old 04-04-2004, 11:49 PM   #24
RRRR1
Member#: 51329
2002 WRX SEDAN
WHITE
Any difference between the factory purolator made filter and the purolator pureone ? besides $.
RRRR1 is offline   Reply With Quote
Old 04-27-2004, 06:03 PM   #25
RayO
Member#: 42329
2002 WRX sedan
I was at the dealer getting crush washers, and the parts guy told me I should be using AA080.
All this talk about overheating filters, check valves, new supplier, etc. is confusing, though plausible.
Personally, I have always liked the thought of using the largest possible filter (holdover from my SB Chevy days), and I have a stockpile of Purolater L11460's to use up.
Unless someone can confirm any real good reason not to.
RayO is offline   Reply With Quote
OEM oil filter part number for 2007 WRX? perret318 Newbies & FAQs 1 01-25-2007 10:32 AM
New Oil Filter Part Number For Turbo Wrx? obxtoy Service & Maintenance 2 09-26-2005 11:03 AM
04 oil filter part number awdboxer Factory 2.0L Turbo Powertrain 2 10-06-2003 11:15 PM
Here is the Oil Filter Part Number blue-adept Factory 2.0L Turbo Powertrain 3 03-21-2001 06:26 PM
Message Board Statistics All times are GMT -4. The time now is 12:34 PM.
