Old 10-15-2003, 06:00 AM   #1
AMike
Member#: 40552
2004 wrx
Default Bucking on new '04 WRX?
Is it normal for a WRX to feel like it cuts the fuel off (hard buck) between 4.5-5krpm when I lift off the throttle? I'm not snapping off, just lifting for a fairly leisurely shift. It doesn't do that in any other rpm band. If I lift very slowly it will smooth out, but there seems to be a definite blip in the throttle mapping or something. The car also seems to surge when the boost is coming on (2.5-3krpm) at >1/2 throttle. I don't live particularly close to a dealer, so I thought I'd ask here first.
The cloth seats are also looking pretty worn already - kind of sad.
I followed the 1k mi break-in procedure exactly - broke 4krpm once when I passed a truck, so I don't think that's the problem...
AMike is offline   Reply With Quote
Old 10-15-2003, 06:46 AM   #2
loreley
Member#: 19905
what gear is this happening in?
if its first/second, its normal, thats what you want a manual car to do anyways when you lift off the gas, stop accelerating. it will feel like bucking if you do it too quickly.
also, what is "surge"?
loreley is offline   Reply With Quote
Old 10-15-2003, 07:38 AM   #3
NateSD
Member#: 44585
2004 WRX
Not sure if it is normal, but I have this same problem when blasting down the mountain roads. Only have had it happen in second gear at the same RPM range when accelerating out of a corner and lifting off for the next. It is irritating though because it does "buck" pretty hard sometimes. I've just altered my driving still a little to compensate for this problem. Let me know if you figure something out.
NateSD is offline   Reply With Quote
Old 10-15-2003, 07:53 AM   #4
AMike
Member#: 40552
2004 wrx
This happens in second and third gears. As I said, it only happens between 4.5-5krpm, otherwise I would assume I am just lifting off too fast. My last car, a BMW, did not buck unless I came off the gas too fast, and with the WRX I can pull off the gas fairly quickly at say 6krpm without any problems... I think I've even heard the tires chirp once when this bucking occured, and I was purposefully seeing how slowly I needed to lift to reduce the bucking.
Surging is when the acceleration is not constant. Think of it as lighter bucking.
NateSD, it sounds like you have the exact problem I have- very very annoying on mountain roads, which are found in abundance around here.
Old 10-15-2003, 11:59 AM   #5
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I am 96.3% sure this is normal. My car does it too. From what I read, it is the wastegate snapping shut. At 4-5 krpm, you should be at boost and when you lift your foot off the pedal, the wastegate on the turbo snaps shut. This in effect creates a "wall" for all the exhaust gases and your car will buck. I might be wrong, but I am pretty sure this is correct. Try a search, or repost your question in the 2.0 forum in a few days for probably better assistance.
Old 10-15-2003, 02:54 PM   #6
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Do you have a manual boost controller? It can cause some unnecessary roughness issues exactly like what you are describing. Is the car absolutely stock?
DrBiggly is offline   Reply With Quote
Old 10-15-2003, 03:05 PM   #7
AMike
Member#: 40552
2004 wrx
It is most definitely bone stock...
The feeling is like the faulty air flow meter in my old BMW ( or could it be a vacuum leak?)
Old 10-15-2003, 09:36 PM   #8
jin psu
Member#: 35547
2004 WRB WRX
I've noticed this on my car too. Today after work I was testing the waters after reading this thread. A couple of times it bucked real hard when I let off the throttle at high RPMs in 3rd gear. I'm not even lifting that fast but it seems like anytime I'm at WOT above 4k and lift all (or almost all) I get bucking. It's starting to scare me... anyone know if this has any negative effects on the car?
Justin.
jin psu is offline   Reply With Quote
Old 10-15-2003, 10:14 PM   #9
jin psu
Member#: 35547
2004 WRB WRX
Would a BOV relieve this pressure and effectively relieve the bucking?
Just a thought (so no anti bov flames ).
Justin.
Old 10-16-2003, 12:29 AM   #10
AMike
Member#: 40552
2004 wrx
Well, it's good to know I'm not alone with the problem. It kind of sounds to me that Subaru might have released a bad ECU map or something. As far as being caused by the wastegate slamming shut, doesn't the WRX have a diverter valve? I mean, it can never shut off the exhaust flow completely, just divert it to or away from the turbo? Even if the wastgate slammed shut, wouldn't you just see a boost spike? Kind of new to turbo cars though...
Old 10-16-2003, 02:32 AM   #11
razorlab
Member#: 43827
2005 Mitsu Evo MR
Silver and black
My car has this problem as well. It also has hesitation and pinging from 3k to 5k then at 5k all power is back.
I took it to the dealer today and they could not find any problem with it even after I took a tech for a test drive. (of course)
I am going to take it to another dealer and see if they can find something out. If not, I am going to get it dynoed and get the paper graphs to show the hesitation/knock to SOA and tell them to fix my brand new car.
razorlab is offline   Reply With Quote
Old 10-16-2003, 06:36 AM   #12
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Hey guys, I had the same problem but got it fixed. If you are getting bucking without completely letting off the gas, then it's most likely a bad MAS sensor. It felt like the fuel would cut off when just backing off the gas (but not completely letting go of the gas) at 4500-5000 rpms. Get your MAS sensor replcaed by your dealer. If they don't believe you, ask to drive another wrx to prove to them it's not normal. This is only true if you're not completely letting go of the gas though and it's a serious bucking.
ImportVenom is offline   Reply With Quote
Old 10-16-2003, 01:29 PM   #13
AMike
Member#: 40552
2004 wrx
Thanks for the reply. This is exactly what I'm feeling (forgot to mention that it happens only partially letting off the gas). The bucking was enough to make my wife scream once - she thought we hit something. I'll get it checked out at the dealer.
Great deal on an '04 WRX on eBay WRXislander General Community 0 04-03-2008 01:02 AM
Got my new '04 WRX tonight (Nor Cal) WRB_Rex Newbies & FAQs 28 12-04-2003 04:12 PM
FS: BRAND NEW! '04 WRX 16" wheels with Bridgestone Potenza RE92 loment11 Texas Impreza Club Forum -- TXIC 3 10-30-2003 05:35 PM
Brand New '04 WRX Wagon jford Newbies & FAQs 13 10-14-2003 06:01 PM
New '04 WRX . . . Hopefully new antenna qttrocpe Newbies & FAQs 8 11-28-2002 01:50 PM
