Old 10-19-2003, 10:26 AM   #1
eclone
Member#: 31567
Default Jdm Ej25?
I'm trying to look for info on this engine. I currently have a 98 Legacy GT with a blown engine, but can't afford to do a swap due to current money problem.
I had an USDM EJ25 donor engine and was planning on rebuilding my current one, but ran into a few problems, so that idea is scrapped. My mechanic came across a JDM 2.5L with apprx. 40k and can have it installed for $1500C. It sounds like a great deal, but want to find more info on this.
Can someone provide info for this engine? I've done a search, but couldn't find much info other than someone stating it produces about 167hp(edit), and 170lb torque @ 2800rpm w/avcs. Can someone confirm?
Thanks
eclone is offline   Reply With Quote
Old 10-19-2003, 03:34 PM   #2
Jejunum
Member#: 15773
2011 Impreza WRX
is there such a thing as a jdm 2.5...i thought the n/a 2.5 was for north america only (ha n/a for na!)
Jejunum is offline   Reply With Quote
Old 10-19-2003, 04:27 PM   #3
SlowMotion
Member#: 42455
hi there, from wat i understand....the engine is the EJ25 DOHC with variable valve system...ya?
SlowMotion is offline   Reply With Quote
Old 10-19-2003, 04:58 PM   #4
LA
Member#: 7119
2000 impreza rs
blue ridge pearl
i believe there is a jdm 2.5, it is used in the forester and has 170hp i believe and has avcs
LA is offline   Reply With Quote
Old 10-19-2003, 06:42 PM   #5
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
eclone,
I have a 2.5 that came from Japan installed in my '98 2.5RS. I used the original intake manifold and ECU, as the JDM engines have different emission systems/sensors. The JDM has no EGR system at all, so it was necessary to plug the journal in the intake manifold. I do get the occasional P0400 code (EGR Flow Malfunction), but it only seems to happen when cruising at a certain RPM range so I try not to cruise at 2400-2500. I have an OBD-II scanner, and erase the code and CEL. I have no idea what vehicle the JDM was in originally, but it's stronger than the original in top end with no plateau up to redline. Also way worse mileage. The JDM also has hydraulic lifters as opposed to the original engines mechanicals. The JDM camshafts and lifters were also visibly beefier in width; I didn't measure the cam profile, unfortunately. I'd be interested in knowing about the avcs, and how the valve timing is controlled. The characteristics of the new engine seem to be consistent with what avcs does, but if it's controlled by the ECU, then I doubt that the original ECU would have it programmed in. Sorry to not give you many answers, but maybe we can get some more input from the board.
hossak8 is offline   Reply With Quote
Old 10-19-2003, 06:57 PM   #6
eclone
Member#: 31567
hossak,
How long have you had this engine in for? Any problems other than the CEL? Also, will the sensors affect emissions testing? How does it compare to the US 2.5? More low-end torque? Overall?
Also, when you say bad mileage, how bad? What do you get out of a full tank? Also, are they made for higher octane? Maybe that could be a problem. We only have 94 here.
Sorry for all the questions. I still a n00b at all this.
One more thing, spark plugs should be the same right? cuz I had Denso iridium installed just before it blew.
Old 10-19-2003, 07:37 PM   #7
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
7,000 miles.
No other problems.
Don't know about emissions testing.
No more low end discernable, but the original always seemed to go flat at around 5,500 RPM. JDM keeps pulling at high RPM.
23-24 MPG, mix of highway and mountain roads. Haven't taken any long trips. 320 miles per tank. Been running Mobil 93.
Plugs the same, wires different. The seal end on the valve cover side was a different shape. Come to think of it I'm pretty sure that the wires that fit were Forester spec.
Old 10-20-2003, 03:01 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
What year is the engine? The AVCS JDM EJ25's are rather new. Heres a site for example that sells the JDM EJ25. We have had a few posts in here talking about that engine, but it has been awhile...
http://www.xcceleration.com/engine-p...s-engines.html
Old 10-20-2003, 09:36 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
hosssak8 has it pegged.
ss
subysouth is offline   Reply With Quote
Old 10-20-2003, 04:13 PM   #10
MannySoobia
Member#: 22139
2008 FXT Sport
Gee-Are-Pee
Post
I too have a JDM 2.5 in my ride, it was from a 98', or at least thats what the engine dealer told me. As for the EGR code,...Well it's kinda long story..... The engine I had B4 was the 2.2, and the 2.2 engine doesn't need the EGR componant (so the dealer told me),Soooo, when I put in the 2.5, It not only didn't come with the EGR stuff, but I didn't have it from my last engine. Now comes time to SMOG and I register as a GROSS POLLUTER!! I take it to the dealer and they tell me it's gonna cost $600 bucks for the complete setup, and about $800 bucks for all the Labor....ARRRGGHHH!!!
OH, Well,....to late now, I gotta pay.
Hope that sheds some light on something, I don't know about your smog laws but Cali Sux for smog. As for performance, I LOVE IT!!
-- Manny S.
MannySoobia is offline   Reply With Quote
JDM EJ25 vs USDM EJ25, pros & cons ? qtr_wrx Subaru Conversions 9 05-25-2009 12:10 AM
JDM EJ25 vs USDM EJ25 (Both MY98) AWDrifterz Subaru Conversions 15 11-14-2008 02:02 PM
JDM EJ25 vr USDM EJ25 trinistyles Newbies & FAQs 8 02-16-2007 05:26 AM
USDM EJ25 Replaced with JDM EJ25 Mounday Legacy Forum 19 03-01-2006 01:49 PM
USDM EJ25 replaced with JDM EJ25 Mounday Subaru Conversions 0 02-22-2006 04:42 PM
