Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Closed Thread
Old 11-13-2003, 10:39 PM   #1
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Default So subaru claims it's cast pistons in the STi are stronger than forged...
"NOTE: Our 40 yrs. experience has shown us that these pistons should never be used with Nitrous, super charger or turbo's. A forged piston is recommended in these applications, remember hypereurectic pistons are still cast pistons. "
LOL
verc is offline
Old 11-13-2003, 10:59 PM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Where is your cut and paste from?
What material piston are they talking about?
Have they tested the UAC12H piston material?
ANZAC_1915 is offline
Old 11-13-2003, 11:24 PM   #3
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
eh I just cut and pasted this on a whim.
They are from KB racing's site.
I actually don't know jack about the 2.5l block except that they use hypereurectic cast pistons. And from my understanding of what hypereurectic means, the STi pistons are nevertheless high in silicon content. And My expertise is in forging and machining, so I don't know jack about casting parts and methods for making them strong what not either
Curious, What is this UAC12H piston material we have?
verc is offline
Old 11-14-2003, 01:01 AM   #4
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
T6
Wombat North is offline
Old 11-14-2003, 01:08 AM   #5
Wombat North
Member#: 21267
STI, EWG 8cm Green
Poor Supra's have cast pistons. 1000HP they musn't be any good.
Old 11-14-2003, 01:48 AM   #6
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
... :wl sounds:: ....
verc is offline
Old 11-14-2003, 09:21 AM   #7
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
It means they are stiffer, and stronger (than the normal sti forged ones) at low operating temps. At high temps, things aren't as good though.
Paul
Pavlo is offline
Old 11-14-2003, 09:44 AM   #8
strangerq
Member#: 13095
Subaru's loling too. Early this year some WRC commentators were suggesting that Subaru made a mistake by switching to cast pistons for their rally car. That was before they won 4 of the last eight rallies of course.
"This latest STi piston is a departure from previous years in that it is a cast aluminum design. However, we believe this to be a special hypereutectic material and STi claims a 120% increase in strength over their previous forged pistons. "
http://www.rallispec.com/product-eng_1.htm
strangerq is offline
Old 11-14-2003, 09:55 AM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You should do a search, this is like the 3rd time for this conversation. You'll also notice there aren't a bunch of STi's with melted pistons either.
Old 11-14-2003, 10:07 AM   #10
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Many ford/chevrolet guys out there run hypereurectic pistons with 100-150 shot of nitrous and have make hundreds of passes with out issue.
FWIK Hypereurectic have come a long way. Subaru most likely chose to use them over forged as the production process is cheaper, there is less waste and production failure (% bad off the line) on hypereurectic pistons is much less them forged. They are also stonger then the WRX cast pistons which when properly tuned have held up to more power then I will ever put down.
roybfr is offline
Old 11-14-2003, 10:10 AM   #11
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Eutectic is a material science term that means that the elements combined (Say AL-Zn-NI-Mg-Cu ) are combined in proportions to give the lowest possible melting point. It also means that the mixture behaves as a single element. The mixture has a sharp melting point, and the melting point is the same as the freezing point, there's no hysterisis there.
If the STi engine can hold as much torque/HP as 6-speed, no need to worry IMO. How many of us are ever going to see torque/HP levels above 450/450?
Corn-Picker is offline
Old 11-14-2003, 10:24 AM   #12
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Hypereurectic cast pistons will also expand less, since they are typically less dense than forged pistons. That means that the engine can be set up with tighter (cold) piston/cylinder clearances. With forged pistons, they typically slap a bit when cold, while warming up, and that can potentially reduce the life of the engine, especially in the hands of "consumers" who may not be as diligent as they could be when warming up the engine at initial startup, especially in cold climates. My 2 cents worth.
bcblues is offline
Old 11-14-2003, 10:55 AM   #13
Syck_Driven_STi
Member#: 46274
2004 German
Blue Pearl
Default well. almost
when the right forgeed pistons are properly sleeved and matchedto the cylinders, this is not an issue with 5 minute cold weather warm up.
Syck_Driven_STi is offline
Old 11-14-2003, 11:09 AM   #14
XT6Wagon
Member#: 524
04 STi
And when they are sized so that they do not slap when cold... they tend to expand and seise to the bore when running high HP for a long time... like road racing with a decent sized turbo.
XT6Wagon is offline
Old 11-14-2003, 12:34 PM   #15
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
sorry for openning this can of worms.
I was kind of high one night made a random post.
Now We're getting into a lot of redundant beat over info.
Mod please lock this thread.
verc is offline
Old 11-14-2003, 01:42 PM   #16
nathansvt
Member#: 28650
well, some of the n00bs havent seen this before (like me) and it's not something I would ordinarily search for. Of course, now I'm off to hit the search function ...
nathansvt is offline
Closed Thread
What gear does subaru claim it's factory torque numbers in? legav05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-15-2009 01:34 AM
proof that Hella 500 mounts are stronger than FF1000's. tooocool49723 Electrical & Lighting 25 01-03-2006 02:20 AM
Factory forged pistons in 2006 STI 04STiguy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 08-27-2005 12:31 AM
Anyone have detailed info about how the GT and XT 5-speeds are stronger than WRX 5sp? Conduit Transmission (AT/MT) & Driveline 14 08-15-2004 04:52 PM
Forged Pistons in the STI Conduit Warranty Issues & SOA Problems 6 02-24-2004 06:40 PM
