Old 12-04-2003, 09:48 AM   #1
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Question TXS Stg 4+ w/UTEC - Engine stalls at speed with clutch in
Greetings all,
I'm trying to figure this out, maybe you can help. As the title says, as I'm driving at speed, put the clutch in, let off the throttle, and the car will stall. Car will idle properly once I restart it. I'm about out of ideas.
- NO check engine light to track down
- I've reset the ECU
- Base TXSstg4FMIC map
- Builds boost fine
- I've replaced the front O2 A/F sensor
- 26K miles
Check this out - This log is from a low boost pull (light throttle)
- any ideas?
Load Knock Mod Mod Mod
RPM MAP MAF TPS Site Count AFR Ign#1 Inj#1 Ign Fuel Boost MAF
psia V % deg duty deg % (CL) V
727 -10.2 1.2 0 00 00 13.8 +12.7 1.0 ECU. -4.1 ECU. 1.1
720 -10.2 1.2 0 00 00 13.8 +12.7 1.0 ECU. -4.1 ECU. 1.1
2134 -8.3 2.0 3 00 00 13.7 +38.8 5.0 ECU. -6.6 ECU. 1.9
2207 -7.7 2.0 3 00 00 14.2 +39.3 5.0 ECU. -6.6 ECU. 1.9
2300 -7.3 2.1 4 00 00 14.3 +39.2 6.0 ECU. -6.6 ECU. 2.0
2403 -6.9 2.2 6 00 00 14.4 +39.7 7.0 ECU. -6.6 ECU. 2.1
2491 -6.5 2.3 7 00 00 13.5 +39.3 7.0 ECU. -6.6 ECU. 2.1
2630 -6.3 2.4 8 00 00 13.8 +35.9 8.0 ECU. -6.6 ECU. 2.2
2710 -5.7 2.4 8 00 00 13.9 +35.2 9.0 ECU. -6.6 ECU. 2.2
2863 -5.3 2.6 12 00 00 14.1 +14.2 10.0 ECU. -6.6 ECU. 2.4
3030 -4.7 2.6 12 00 00 13.7 +32.8 11.0 ECU. -6.6 ECU. 2.5
3208 -4.0 2.7 15 00 00 14.5 +32.4 12.0 ECU. -6.6 ECU. 2.6
3384 -3.2 2.8 16 00 00 14.2 +32.5 14.0 ECU. -6.6 ECU. 2.6
3611 -2.6 2.9 17 00 00 14.3 +32.8 15.0 ECU. -6.6 ECU. 2.7
3853 -2.2 3.0 17 00 00 14.6 +32.3 16.0 ECU. -6.6 ECU. 2.8
4045 -1.8 3.1 17 00 00 13.8 +30.7 18.0 ECU. -6.6 ECU. 2.9
4198 -1.6 3.1 17 00 00 14.3 +31.0 19.0 ECU. -6.6 ECU. 2.9
4480 -1.2 3.2 16 00 00 14.9 +31.5 24.0 ECU. -6.6 ECU. 2.9
4714 -1.2 3.2 15 00 00 rich +32.0 26.0 ECU. -6.6 ECU. 2.9
4938 -1.4 3.1 14 00 00 rich +35.5 26.0 ECU. -6.6 ECU. 2.9
5035 -2.4 3.0 12 00 00 rich +38.4 22.0 ECU. -6.6 ECU. 2.7
4945 -4.5 1.5 0 00 00 rich +11.1 5.0 ECU. -6.6 ECU. 1.5
4623 -6.7 1.7 0 00 00 lean +11.2 5.0 ECU. -6.6 ECU. 1.7
4262 -8.9 1.8 0 00 00 24.2 +11.4 5.0 ECU. -6.6 ECU. 1.6
3926 -10.6 1.7 0 00 00 24.2 +11.3 5.0 ECU. -6.6 ECU. 1.6
3671 -10.8 2.3 7 00 00 20.4 +31.3 8.0 ECU. -6.6 ECU. 2.2
3274 -10.0 2.5 9 00 00 14.5 +40.7 10.0 ECU. -6.6 ECU. 2.3
2949 -8.3 2.5 11 00 00 12.7 +34.0 10.0 ECU. -6.6 ECU. 2.4
3027 -6.3 2.7 15 00 00 13.7 +32.7 13.0 ECU. -6.6 ECU. 2.6
3103 -4.3 2.9 19 00 00 13.2 +32.6 15.0 ECU. -6.6 ECU. 2.7
3202 -2.2 3.0 25 00 00 13.8 +31.7 17.0 ECU. -6.6 ECU. 2.8
3326 -0.6 3.1 29 00 00 13.5 +31.0 19.0 ECU. -6.6 ECU. 3.0
3415 +1.1 3.2 35 00 00 13.2 +29.0 20.0 ECU. -6.6 ECU. 3.0
3561 +2.5 3.3 36 00 00 13.2 +27.9 22.0 ECU. -6.6 ECU. 3.1
3667 +3.9 3.5 37 00 00 13.4 +25.1 25.0 ECU. -6.6 ECU. 3.2
3796 +5.3 3.5 37 00 00 13.3 +23.8 26.0 ECU. -6.6 ECU. 3.2
4001 +5.9 3.5 36 00 00 14.1 +24.7 28.0 ECU. -6.6 ECU. 3.3
4140 +7.0 3.6 35 00 00 13.4 +24.8 30.0 ECU. -6.6 ECU. 3.3
4312 +7.0 3.6 34 00 00 13.6 +22.9 32.0 ECU. -6.6 ECU. 3.4
4403 +6.8 3.7 34 00 00 12.2 +20.2 47.0 ECU. -6.6 ECU. 3.4
4553 +7.2 3.8 34 00 00 rich +19.6 51.0 ECU. -6.6 ECU. 3.5
4681 +7.0 3.8 34 00 00 rich +20.7 54.0 ECU. -6.6 ECU. 3.6
4837 +7.2 3.9 34 00 00 rich +21.6 57.0 ECU. -6.6 ECU. 3.6
5058 +7.2 3.9 34 00 00 rich +22.7 59.0 ECU. -6.6 ECU. 3.6
5120 +6.8 4.0 33 00 00 rich +23.1 63.0 ECU. -6.6 ECU. 3.7
5376 +6.8 4.0 33 00 00 rich +24.4 64.0 ECU. -6.6 ECU. 3.7
5376 +6.6 4.0 33 00 00 rich +24.6 66.0 ECU. -6.6 ECU. 3.7
5555 +6.2 4.0 26 00 00 rich +26.1 62.0 ECU. -6.6 ECU. 3.6
5678 +5.9 3.9 28 00 00 rich +28.9 57.0 ECU. -6.6 ECU. 3.6
5797 +4.7 3.9 26 00 00 rich +30.8 54.0 ECU. -6.6 ECU. 3.6
5889 +4.1 3.8 26 00 00 rich +31.6 54.0 ECU. -6.6 ECU. 3.6
6006 +3.3 3.9 26 00 00 rich +31.8 56.0 ECU. -6.6 ECU. 3.6
6127 +2.7 3.9 27 00 00 rich +33.0 56.0 ECU. -6.6 ECU. 3.6
6172 +2.9 3.9 26 00 00 rich +34.6 56.0 ECU. -6.6 ECU. 3.6
6301 +2.5 3.8 25 00 00 rich +38.6 54.0 ECU. -6.6 ECU. 3.5
6207 +1.1 3.1 5 00 00 rich +41.9 30.0 ECU. -6.6 ECU. 1.4
5995 -1.8 1.2 0 00 00 13.7 +11.0 6.0 ECU. -6.6 ECU. 1.4
5411 -5.3 1.7 0 00 00 lean +11.0 6.0 ECU. -6.6 ECU. 1.6
5136 -8.3 1.9 0 00 00 24.2 +11.2 6.0 ECU. -6.6 ECU. 1.8
4728 -10.4 1.9 0 00 00 24.2 +11.3 6.0 ECU. -6.6 ECU. 1.6
4363 -10.6 1.7 0 00 00 24.2 +11.3 6.0 ECU. -6.6 ECU. 1.4
4045 -10.8 1.5 0 00 00 24.5 +11.3 6.0 ECU. -6.6 ECU. 1.4
3741 -11.2 1.2 0 00 00 24.2 +11.3 6.0 ECU. -6.6 ECU. 1.6
3461 -11.4 1.4 0 00 00 24.5 +11.3 6.0 ECU. -6.6 ECU. 1.3
3106 -11.4 1.6 1 00 00 24.2 +25.5 3.0 ECU. -6.6 ECU. 1.5
2403 -10.8 1.8 2 00 00 24.2 +27.9 3.0 ECU. -6.6 ECU. 1.6
2370 -9.8 2.1 5 00 00 24.0 +33.9 5.0 ECU. -6.6 ECU. 2.0
2294 -8.3 2.1 6 00 00 14.6 +38.2 6.0 ECU. -6.6 ECU. 1.9
2290 -7.1 2.3 9 00 00 15.6 +39.7 9.0 ECU. -6.6 ECU. 2.2
2313 -5.7 2.4 11 00 00 12.3 +36.5 9.0 ECU. -6.6 ECU. 2.2
2308 -4.5 2.4 11 00 00 12.1 +36.5 9.0 ECU. -6.6 ECU. 2.3
2297 -3.4 2.5 12 00 00 12.6 +36.1 9.0 ECU. -6.6 ECU. 2.3
2331 -2.6 2.5 12 00 00 12.8 +35.0 10.0 ECU. -6.6 ECU. 2.3
2310 -2.0 2.5 13 00 00 13.3 +34.6 10.0 ECU. -6.6 ECU. 2.4
2327 -1.6 2.6 15 00 00 13.2 +33.6 10.0 ECU. -6.6 ECU. 2.3
2332 -1.2 2.6 14 00 00 13.4 +32.6 11.0 ECU. -6.6 ECU. 2.4
2337 -0.8 2.6 15 00 00 13.3 +32.2 11.0 ECU. -6.6 ECU. 2.4
2342 -0.6 2.6 12 00 00 13.1 +32.9 10.0 ECU. -6.6 ECU. 2.2
2334 -1.8 1.9 0 00 00 rich +34.5 5.0 ECU. -6.6 ECU. 1.0
2332 -4.3 1.0 0 00 00 rich +17.5 2.0 ECU. -6.6 ECU. 0.8
2075 -7.1 0.8 0 00 00 16.0 +13.3 2.0 ECU. -6.6 ECU. 0.8
1850 -10.2 0.8 0 00 00 lean +12.2 2.0 ECU. -6.6 ECU. 0.7
1616 -11.8 0.9 0 00 00 24.5 +12.7 2.0 ECU. -4.8 ECU. 0.8
1387 -12.0 0.9 0 00 00 24.2 +12.7 2.0 ECU. -4.1 ECU. 0.8
1256 -12.0 0.9 0 00 00 24.2 +20.4 1.0 ECU. -4.1 ECU. 0.9
1134 -11.8 0.9 0 00 00 24.2 +21.3 1.0 ECU. -4.1 ECU. 0.9
911 -11.4 1.0 0 00 00 23.7 +21.4 1.0 ECU. -4.1 ECU. 1.0
689 -10.8 1.1 0 00 00 24.0 +22.5 0.0 ECU. -4.1 ECU. 1.1
459 -10.0 1.1 0 00 00 23.7 +23.9 0.0 ECU. -4.1 ECU. 1.4
00 -8.3 1.3 0 00 00 24.0 +30.0 0.0 ECU. -4.1 ECU. 1.1
00 -6.1 1.4 1 00 00 14.6 +30.0 58.0 ECU. -4.1 ECU. 1.1
00 -3.6 1.0 5 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.9
00 -1.6 1.0 0 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 1.0
00 -0.4 0.9 0 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.9
00 +0.0 0.8 1 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.8
00 +0.0 0.9 0 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.8
00 +0.0 0.8 6 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.7
00 +0.0 0.9 3 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.8
00 -0.2 0.8 0 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.8
00 -0.2 0.8 0 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.7
00 -0.2 0.7 0 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.7
00 -0.2 0.7 0 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.7
00 -0.2 0.7 0 00 00 14.6 +30.0 0.0 ECU. -4.1 ECU. 0.6
00 -0.2 0.7 0 00 00 14.7 +30.0 0.0 ECU. -4.1 ECU. 0.6
00 -0.2 0.7 0 00 00 14.8 +30.0 0.0 ECU. -4.1 ECU. 0.6
00 -0.2 0.7 0 00 00 14.8 +30.0 0.0 ECU. -4.1 ECU. 0.7
00 -0.2 0.7 0 00 00 14.8 +30.0 0.0 ECU. -4.1 ECU. 0.8
00 -0.2 0.9 0 00 00 14.8 +30.0 0.0 ECU. -4.1 ECU. 1.1
00 -0.2 1.1 0 00 00 14.8 +0.0 0.0 ECU. -4.1 ECU. 1.0
00 -0.8 1.2 0 00 00 14.8 +9.6 18.0 ECU. -4.1 ECU. 1.2
00 -2.4 1.2 0 00 00 rich +12.1 3.0 ECU. -4.1 ECU. 1.0
00 -4.9 1.2 0 00 00 rich +12.6 1.0 ECU. -4.1 ECU. 1.0
00 -7.5 1.0 0 00 00 15.6 +13.1 1.0 ECU. -4.1 ECU. 1.0
1014 -9.6 1.2 0 00 00 22.7 +13.5 1.0 ECU. -4.1 ECU. 1.7
1266 -8.9 2.2 10 00 00 23.2 +2.2 5.0 ECU. -4.1 ECU. 1.9
1876 -7.9 1.3 0 00 00 12.2 +25.8 4.0 ECU. -6.6 ECU. 1.1
1937 -7.3 1.9 6 00 00 rich +2.8 4.0 ECU. -6.6 ECU. 1.9
2031 -6.5 1.5 0 00 00 15.2 +24.0 3.0 ECU. -6.6 ECU. 1.3
1957 -8.1 1.1 0 00 00 13.1 +16.4 2.0 ECU. -6.6 ECU. 1.0
1705 -9.8 1.1 0 00 00 18.8 +12.7 2.0 ECU. -5.6 ECU. 1.0
1436 -10.6 1.1 0 00 00 23.4 +12.8 1.0 ECU. -4.1 ECU. 1.0
1192 -11.6 1.1 0 00 00 23.4 +21.4 1.0 ECU. -4.1 ECU. 1.1
931 -11.6 1.1 0 00 00 23.4 +21.8 1.0 ECU. -4.1 ECU. 1.1
694 -11.2 1.2 0 00 00 23.4 +23.3 0.0 ECU. -4.1 ECU. 1.2
535 -10.2 1.3 0 00 00 23.7 +23.1 0.0 ECU. -4.1 ECU. 1.3
515 -8.3 1.8 6 00 00 23.4 +20.7 1.0 ECU. -4.1 ECU. 1.7
1249 -5.9 1.7 2 00 00 22.9 +4.0 27.0 ECU. -4.1 ECU. 1.1
1819 -5.1 1.4 0 00 00 rich +19.6 3.0 ECU. -6.6 ECU. 1.2
2117 -5.7 1.5 0 00 00 14.3 +22.7 3.0 ECU. -6.6 ECU. 1.5
2095 -6.9 1.6 1 00 00 17.5 +22.4 3.0 ECU. -6.6 ECU. 1.5
2129 -8.9 1.9 4 00 00 17.6 +26.2 7.0 ECU. -6.6 ECU. 1.9
2071 -8.9 2.1 6 00 00 13.1 +37.5 6.0 ECU. -6.6 ECU. 2.0
jetskizero is offline   Reply With Quote
Old 12-04-2003, 11:30 AM   #2
Division By Zero
Member#: 7555
The first thing I notice is that it never changes load sites. The load site is "00" all the way through that log even up to 7psi. This is the reason that it never gets out of the 0% TPS column, which goes -4.1 and then switches to -6.6 fuel correction and stays there until you let off the gas and then went back to -4.1 and then stalled.
Have you changed anything in the special constants menu? Which version firmware are you running?I think I'd make sure that it's flashed with v3.1 and also make sure all of the UTEC special constant settings are at default first. Then trouble shoot from there.
Division By Zero is offline   Reply With Quote
Old 12-04-2003, 02:02 PM   #3
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Excellent observation. It definately helps having some more eyeballs looking at the log.
I believe I have the latest firmware, but will certainly double check. I went back through the open loop to closed loop steps to check them and they seemed okay. I was thinking about putting the factory TMIC back, and dropping back to an open loop Stg4TMIC map, to try and rule out a cut hose on the FMIC piping somewhere that I can't see.
Here's another log run, this time with a Full throttle pull 1st & 2nd gear.
737 -10.0 1.2 0 00 00 14.7 +13.2 1.0 ECU. -4.1 ECU. 1.1
733 -10.0 1.2 0 00 00 14.7 +13.3 1.0 ECU. -4.1 ECU. 1.2
727 -10.0 1.2 0 00 00 14.7 +13.3 1.0 ECU. -4.1 ECU. 1.2
1657 -10.4 1.6 0 00 00 14.3 +21.8 2.0 ECU. -5.6 ECU. 1.5
1677 -10.4 1.6 0 00 00 14.5 +21.8 2.0 ECU. -5.6 ECU. 1.5
1686 -10.4 1.8 3 00 00 14.7 +24.2 5.0 ECU. -6.1 ECU. 1.9
1768 -9.6 2.0 4 00 00 rich +35.1 4.0 ECU. -6.6 ECU. 1.9
1854 -8.3 2.1 7 00 00 15.3 +33.1 5.0 ECU. -6.6 ECU. 2.1
1999 -6.7 2.3 12 00 00 15.5 +34.3 8.0 ECU. -6.6 ECU. 2.2
2234 -4.3 2.6 41 00 00 14.4 +33.2 24.0 ECU. -6.6 ECU. 2.4
2364 -2.4 2.6 61 10 00 14.1 +27.5 17.0 ECU. -6.6 200.00 2.5
2639 -0.6 2.7 90 10 00 12.0 +32.2 13.0 ECU. -6.7 268.00 2.6
3008 +0.6 2.9 100 10 00 rich +31.7 20.0 ECU. -6.4 280.00 2.8
3186 +1.5 3.1 99 20 00 rich +29.4 22.0 ECU. -6.9 280.00 2.9
3572 +2.3 3.2 99 20 00 rich +30.7 27.0 ECU. -6.0 280.00 3.1
3912 +3.3 3.5 99 30 00 rich +24.8 35.0 ECU. -6.4 280.00 3.4
4273 +5.1 3.9 99 40 00 rich +17.0 62.0 ECU. -5.4 280.00 3.8
4728 +7.6 4.3 98 50 00 rich +15.1 93.0 +22.0 -5.5 280.00 4.1
5005 +10.6 4.3 98 70 00 rich +17.5 99.0 +20.0 -5.5 280.00 4.1
5583 +13.5 4.5 97 80 00 rich +21.6 100.0 +21.4 -5.5 280.00 4.2
6230 +15.5 4.6 82 80 00 rich +23.2 100.0 +22.0 -5.4 272.00 4.3
6626 +16.6 4.6 82 80 00 rich +26.4 100.0 +23.0 -5.4 272.00 4.4
7062 +16.8 4.6 64 80 00 rich +28.7 96.0 +23.0 -5.4 238.00 3.3
6587 +10.8 1.7 0 00 00 rich +10.8 33.0 ECU. -6.6 ECU. 1.5
6093 +4.1 1.1 0 00 00 lean +11.1 33.0 ECU. -6.6 ECU. 1.2
5659 -2.4 2.2 15 00 00 24.5 +17.9 19.0 ECU. -6.6 ECU. 3.2
4578 -5.9 3.9 73 10 00 rich +21.1 54.0 ECU. -7.3 256.00 3.6
4273 -2.0 3.6 98 30 00 rich +18.8 54.0 ECU. -6.4 280.00 3.7
4156 +3.3 4.3 98 50 00 rich +14.2 82.0 +18.0 -5.0 280.00 4.1
4409 +9.8 4.4 98 70 00 rich +14.0 98.0 +18.6 -5.1 280.00 4.1
4636 +13.7 4.3 98 80 00 rich +14.8 96.0 +18.5 -5.2 280.00 4.1
4866 +16.1 4.3 98 90 00 rich +15.5 98.0 +18.0 -5.3 280.00 4.1
4938 +17.8 4.4 98 90 00 rich +17.4 99.0 +18.3 -5.1 280.00 4.1
5144 +18.4 4.4 98 90 00 rich +18.0 99.0 +18.5 -5.1 280.00 4.2
5333 +18.2 4.5 98 90 00 rich +19.5 99.0 +19.1 -5.0 280.00 4.2
5518 +18.0 4.5 98 80 00 rich +21.0 99.0 +21.1 -5.5 280.00 4.3
5659 +17.8 4.6 98 80 00 rich +21.2 99.0 +21.6 -5.4 280.00 4.3
5910 +17.4 4.6 98 80 00 rich +22.3 99.0 +22.0 -5.4 280.00 4.4
6161 +17.2 4.6 98 80 00 rich +22.9 99.0 +22.0 -5.4 280.00 4.4
6289 +17.2 4.6 98 80 00 rich +25.5 99.0 +22.0 -5.4 280.00 4.4
6472 +17.0 4.7 93 80 00 rich +26.5 99.0 +22.7 -5.4 280.00 4.4
6680 +16.6 4.6 37 00 00 rich +30.8 31.0 ECU. -6.6 ECU. 2.9
6289 +10.4 1.8 0 00 00 12.4 +10.8 27.0 ECU. -6.6 ECU. 1.4
5868 +3.7 1.1 0 00 00 lean +11.0 27.0 ECU. -6.6 ECU. 1.3
5359 -3.2 1.6 0 00 00 lean +10.9 27.0 ECU. -6.6 ECU. 1.6
5012 -9.8 1.9 0 00 00 24.5 +11.2 27.0 ECU. -6.6 ECU. 1.7
4655 -10.8 1.9 0 00 00 24.2 +11.2 27.0 ECU. -6.6 ECU. 1.8
4340 -11.0 1.8 0 00 00 24.2 +11.2 27.0 ECU. -6.6 ECU. 1.6
3949 -11.0 1.3 0 00 00 lean +11.1 27.0 ECU. -6.6 ECU. 1.5
3699 -11.0 1.6 0 00 00 24.5 +11.3 27.0 ECU. -6.6 ECU. 1.5
3422 -10.8 1.6 0 00 00 24.2 +11.5 27.0 ECU. -6.6 ECU. 1.3
3150 -10.8 1.3 0 00 00 24.5 +11.7 27.0 ECU. -6.6 ECU. 1.2
2886 -10.8 1.3 0 00 00 lean +11.8 27.0 ECU. -6.6 ECU. 1.2
2624 -11.0 1.4 0 00 00 24.2 +11.8 27.0 ECU. -6.6 ECU. 1.2
2403 -11.2 1.2 0 00 00 24.5 +11.9 27.0 ECU. -6.6 ECU. 1.1
2185 -11.4 1.2 0 00 00 24.2 +12.0 27.0 ECU. -6.6 ECU. 1.0
1959 -11.8 1.1 0 00 00 lean +12.3 27.0 ECU. -6.6 ECU. 0.9
1743 -12.0 1.0 0 00 00 24.2 +12.4 27.0 ECU. -6.6 ECU. 0.9
1518 -12.0 1.0 0 00 00 24.5 +12.5 27.0 ECU. -6.3 ECU. 0.9
1315 -12.0 0.9 0 00 00 24.2 +12.8 7.0 ECU. -4.1 ECU. 0.9
1264 -11.8 1.0 0 00 00 24.2 +20.7 1.0 ECU. -4.1 ECU. 0.9
1056 -11.6 1.0 0 00 00 24.2 +21.3 1.0 ECU. -4.1 ECU. 0.9
859 -11.2 1.1 0 00 00 24.0 +21.5 0.0 ECU. -4.1 ECU. 1.0
658 -10.6 1.1 0 00 00 24.0 +22.5 0.0 ECU. -4.1 ECU. 1.2
446 -9.6 1.4 0 00 00 24.2 +23.0 0.0 ECU. -4.1 ECU. 1.2
00 -7.7 1.3 0 00 00 24.2 +30.0 0.0 ECU. -4.1 ECU. 1.2
00 -5.7 1.2 0 00 00 24.5 -67.9 1.0 ECU. -4.1 ECU. 1.2
00 -4.0 1.2 0 00 00 24.2 +6.3 0.0 ECU. -4.1 ECU. 1.3
00 -3.0 1.3 0 00 00 24.2 +7.3 0.0 ECU. -4.1 ECU. 1.2
00 -2.4 1.3 0 00 00 24.0 +6.1 1.0 ECU. -4.1 ECU. 1.2
00 -2.4 1.3 0 00 00 23.7 +6.8 1.0 ECU. -4.1 ECU. 1.2
00 -2.4 1.3 0 00 00 23.7 +4.7 1.0 ECU. -4.1 ECU. 1.3
Old 12-04-2003, 02:20 PM   #4
Division By Zero
Member#: 7555
Oh, that's interesting. You didn't mention the FMIC the first time (yes I know, I saw that you're using that base map).
Go back through all of the connection points on the FMIC plumbing and make sure that they are all sealed well. Actually, a friend showed me recently to use hairspray on the connecting points for vac and boost hoses. It makes it stick and seal really good. Having a leak would cause a problem I would think.
Also, make sure that the defaults are loaded in the special constants as I said before (other than the CLB setting). Also look in the manual and set your TPS to a 100% (it may be a little higher).
Old 12-04-2003, 02:29 PM   #5
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
You probably will not like this answer but you just can't clutch in at high speed and let the rpms drop down to idle levels with a front mount intercooler.
If this happens you will need to clear your ecu codes or reset your ecu as you will get a "system too lean code." This code will make your car run leaner than intended.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 12-04-2003, 02:39 PM   #6
Casperwrx
Member#: 26179
2002 2.5 hybrid--aps
Phil is right,
reset your ecu and it should be fine (it fixed mine)
Casperwrx is offline   Reply With Quote
Old 12-04-2003, 02:40 PM   #7
Division By Zero
Member#: 7555
If this happens you will need to clear your ecu codes or reset your ecu as you will get a "system too lean code." This code will make your car run leaner than inteded.
Thanks,
Phil
TurboXS
Wow! That sucks. I didn't know that a FMIC will cause that.
Old 12-04-2003, 03:34 PM   #8
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Phil -
Actually, that's okay - at least I have an idea as to what's going on. I never tripped that CEL code, so I thought it was either the MAF sensor, the idle control solenoid, front o2 sensor or something. (none of which are cheap to replace.)
Out of a quest for knowledge, why does this happen?
Thanks a ton!
Old 12-04-2003, 03:41 PM   #9
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
definately curious here... I don't know if I want a FMIC as bad now knowing that.
MustGoFast is offline   Reply With Quote
Old 12-05-2003, 09:03 AM   #10
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
I would have to say, other than this issue (which it took 2 months to notice) their products have been excellent.
I wonder if there is a way to "tune" around it?
Old 12-05-2003, 09:44 AM   #11
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Question Stage 5?
-Jason
jpmarotta is offline   Reply With Quote
Old 12-05-2003, 12:22 PM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Default Re: Stage 5?
Originally posted by jpmarotta
-Jason
hehe... I'm surprised your the first person to notice that.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 12-05-2003, 01:42 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Tuna, mebbe....?
Old 12-06-2003, 03:19 PM   #14
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Well hopefully it's good for a few more eyeballs on this problem.
To set the record straight it's a "Stage 4 Kit with the Txs FMI option." (As if you didn't know that from the map name.) So, I guess that would be a Stage 4+, technically speaking. Except it's a VF34, so technically it's not really even a stage 4 kit which would come with the vf30. sheesh... semantics.
Old 12-07-2003, 10:04 AM   #15
motoxphil
Member#: 5094
Phil -
It has to do with the length of pipe work involved and the dramatic temp change at high speeds while using a front mount.
As with many performance modifications, it is a give and take situation. So just like if you install an upgraded rear swaybar on a WRX, you cannot expect to maintain control if you slam your brakes on mid-turn and with FMI you just can't clutch in to idle at over 50 mph
Thanks,
Phil
TurboXS
Old 12-09-2003, 10:46 AM   #16
MustGoFast
Member#: 33370
2002 Impreza WRX
Phil,
Why does this occur.. and I"m assuming it's not 50mph but a certain RPM rather? Maybe not but could you explain to me what's actually occurring.. my curiosity has defiatelly gotten the best of me now.
Chuck
Old 12-29-2003, 09:27 AM   #17
mixup52
Member#: 39691
2002 WRX Wagon
Me Too!
mixup52 is offline   Reply With Quote
Old 12-30-2003, 09:46 PM   #18
MustGoFast
Member#: 33370
2002 Impreza WRX
come on phil tell us please
Old 12-31-2003, 02:58 PM   #19
jetskizero
Member#: 13833
2002 Impreza WRX
Silver - Sold :(
Maybe we could figure this out - let's think about what's happening -
On boost, turbo spooled, some load on the motor, hot compressed air being sent through about 3 feet of I/C piping, cooled 100 deg, another 3 feet of piping, then sent into the intake manifold.
Now, clutch in, no load on the motor, turbo winding down, throttle body closed, RPM's dropping, A/F gauge shows dead lean (lotsa air/little fuel). The timing seems to jump a bit as ECU/UTEC should go into idle (0 load) fueling values.
So we've got lots of air due to the length of FMIC piping, and not much fuel based on engine load, engine stumbles, the UTEC log shows a Injector duty cycle of 0! (i.e., no fuel) And with no fuel the engine cuts off.
I still don't know why.
Old 12-31-2003, 03:43 PM   #20
MustGoFast
Member#: 33370
2002 Impreza WRX
really not a timing issues as I have timing in 0 load.
Old 12-31-2003, 03:47 PM   #21
MustGoFast
Member#: 33370
2002 Impreza WRX
I figure gas off the blow off will open releasing some pressure.. and the engine speed will determine the amount of air entering the engine...
W/ out the front mount the same fueling occurs of throttle as with it... so the fuel amount here is static.. extra air will not hinder combustion of the given fuel amount in any way.. therefore I would assume that it is not an issue with the engine recieveing extra air as you seemed to be thinking...
but is there an issue where because of the longer piping or and extra cooling the engine is being starved of air? This will obviously stop combustion and thus could trigger a stall/kill.
Seems to be logic but I could not say exactly why it would occur so I really can't support or disprove my own theory.
Hey TXS give me some info please ...
Old 01-02-2004, 10:56 AM   #22
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
...think about the volume in the intake system between the maf and the intake valve.
hth
ken
Old 01-18-2004, 09:15 PM   #23
WrxSlvrWgn
Member#: 51799
03 wrx wagon
Maybe cause its MAP not MAF Pressure drops to zero? I donno had to sound like the newbie i am i guess.
WrxSlvrWgn is offline   Reply With Quote
Old 01-21-2004, 09:17 AM   #24
MustGoFast
Member#: 33370
2002 Impreza WRX
come on phil give me a little something to run w/ here.
Old 01-21-2004, 11:15 AM   #25
motoxphil
Member#: 5094
ok, ok, ok
One hint:
I suspect it has a lot to do with the deceleration fuel map of the factory ecu.
Phil
TurboXS
Warm engine stalling at start-up?? jsavage Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-17-2008 01:39 PM
Engine Stall At High Speed? Sp00L Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 02-15-2008 11:37 AM
Car problems.. Stall at light with p1544 consume Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-09-2007 11:26 PM
Engine continues to rev with clutch in... klauxa Newbies & FAQs 12 05-16-2006 08:38 PM
engine stall at about 3500 rpm yukonm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-29-2003 01:20 PM
