Old 12-07-2003, 09:53 PM   #1
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default GTSpec headers make power? You sure?
Before the header.. would always be dead even with my friends WRX which has identical modifications as me.. so to see the "gain" from the GTSpec headers we went out tonight and ran a few times... each time he steadily pulled past me and kept pulling.. 1 car.. and if we went past 110 mph he'd have kept pulling hard.. The uppipe is wrapped.. but the header isn't.
So people who have this header or are thinking about buying one.. take my experience into thought. I'm waiting for the big header dyno comparison that Dylan is doing soon for some real life results compared to other headers.. and then I will decide to keep or sell this. I am impressed by the craftmanship of the GT Spec header.. but the claim of it making an upwards of 20 whp and 20+ wheel torque is anything but truth.
Jay
Diversion is offline   Reply With Quote
Old 12-07-2003, 10:01 PM   #2
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
did u go out and run right after install of the header.
if so, give the ECU a few days to relearn and then go and run ur friend again. it may be a diff outcome.
butt dynos are not very accurate and it would be unfair to say to people not to buy it.
there are too many variables to why u got pulled on like that anyways.
do a before/after dyno run.
stickman is offline   Reply With Quote
Old 12-07-2003, 10:06 PM   #3
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Me and my friend have raced each other plenty of times.. on different days, different temps, etc. etc. and we are always VERY close or even.. it's been about 3 weeks since i've had the header, so the ECU is "adjusted" (even though it doesn't need adjusting to a header anyways) ..
So the ONLY variable between his car and mine is the header.. and i'm slower now. Considerably at that.
Jay
Old 12-07-2003, 10:11 PM   #4
WRXMikeH
Member#: 30577
2003 WRX
Don't forget about my silicon IC hoses and polished TB. Also remember my midrange boost was 16.7psi in 4th, yours was likely lower. I bet on a different night results would be different.
WRXMikeH is offline   Reply With Quote
Old 12-07-2003, 10:13 PM   #5
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
But Mike, even with your tb and hoses we are MUCH more even than we were tonight..
Jay
Old 12-07-2003, 10:18 PM   #6
WRXMikeH
Member#: 30577
2003 WRX
That's why I think it's just "one of those nights". Look how mine did at g-ville, and it feels worlds better this week. What was your boost anyhow?
Old 12-07-2003, 10:22 PM   #7
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
I was holding a little over 16 that last run we had.. just seems like it tapers down a lot worse than the factory header though..
I suppose we will have to try it again so other day to confirm.
Jay
Old 12-07-2003, 10:26 PM   #8
WRXMikeH
Member#: 30577
2003 WRX
Gives us an excuse to race again.. BTW, we did this on a sanctioned race track, and there were no other cars within 5 miles.
Old 12-07-2003, 10:28 PM   #9
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Gotta love sanctioned race tracks within minutes of your home.
Jay
Old 12-07-2003, 10:58 PM   #10
AllSeven
Member#: 32798
i've seen dyno plots with gains.....................? weird
AllSeven is offline   Reply With Quote
Old 12-07-2003, 11:20 PM   #11
cronic
Member#: 9749
You sure you dont have a leak somewhere?
cronic is offline   Reply With Quote
Old 12-07-2003, 11:54 PM   #12
FJP
Member#: 43852
GC8 2.5RST
I always felt the up pipe was too big and that it would lose velocity.
FJP is offline   Reply With Quote
Old 12-07-2003, 11:56 PM   #13
Erudition
Member#: 7560
Default Re: GTSpec headers make power? You sure?
Well, I must pull off my exhaust manifold because of this undisputable scientific data.
Please don't badmouth a product if you do not have any solid statistical data or even some remote piece of hard evidence.
Erudition is offline   Reply With Quote
Old 12-08-2003, 01:04 AM   #14
blackie
Member#: 42979
03 wrx
blizzzack stage IV
what other mods do u have?
blackie is offline   Reply With Quote
Old 12-08-2003, 01:20 AM   #15
FJP
Member#: 43852
GC8 2.5RST
ironicly, I just pulled off a GT Spec header to find exhaust leaks at the heads instead of the up pipe.
Old 12-08-2003, 01:22 AM   #16
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Was there any sound to indicate you had a leak there?
garface is offline   Reply With Quote
Old 12-08-2003, 01:37 AM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I think this is to be expected with the headers... Since you guys raced from a roll, it is very likely that your headers had cooled down before you got on the gas.. This meant that with cooler gases, you would miss your taget boost...
Your boost should also fall off a little quicker too on the top end due to the fact that boost is a measure of resistance, and since the headers are freer flowing than stock, and the stock turbo doesn't do much on the top end... so boost falls off quicker...
You really need to wrap or coat those headers.... and get a bigger turbo than stock...
The stock turbo seems more biased towards producing lots of midrange punch, and the stock headers work by exaggerate this tendency also. By removing the stock headers, you remove some of this torque I think, for the expense of more power up top (which the stocker cannot give), It is this lost mid range that gives your friend the jump..
jigga is offline   Reply With Quote
Old 12-08-2003, 02:15 AM   #18
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
I agree with Jigga. I have seen a difference from .65 bar to .8 bar depending on temp of the pipes. They need a bit of heat thrown through them. Wrap the header and when you have the gaskets out spray them with RTV silicone gasket spray. This will help hinder any leaks. Do all header gaskets IMO.
IA Performance is offline   Reply With Quote
Old 12-08-2003, 02:16 AM   #19
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Wrap the headers. Mine are coated and wrapped. Turbos work off exhaust ENERGY which includes: heat, flow, and velocity.
Get a bigger turbo
And like FJP said check for leaks, mine had leaks at the head and uppipe before and never made noise. A simple gasket change fixed those.
mr2guru is offline   Reply With Quote
Old 12-08-2003, 02:35 AM   #20
FJP
Member#: 43852
GC8 2.5RST
The car is so loud it would be hard to tell. It uses a Ti 80mm non resonated exhaust and a PDE downpipe on a S202 STi motor. The car is freakin fast. At 7000 rpms, the tires totally break loose until the 8000 rpm redline. This happens in first and second gears. The motor was never run without the header, so there is no comparison data.
Old 12-08-2003, 02:36 AM   #21
IA Performance
Member#: 25194
Dark Gray
forgot, I had leaks at head to header gaskets.
Mine are coated and wrapped as well. At bare minimum spend the $40 on wrap and clamps and wrap them up.
I have a gen 1 set and finally broke down and just had the up pipe welded to the header. It all goes in as one piece with the mtor in the car. Tight fit, but it can be done. Gauaranteed to not have any more up pipe leaks
Old 12-08-2003, 03:10 AM   #22
SJwrx
Member#: 14970
1997 GF8
multi
Not worried about vibration?
Rich
SJwrx is offline   Reply With Quote
Old 12-08-2003, 08:13 AM   #23
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default Re: Re: GTSpec headers make power? You sure?
I never bad-mouthed this product, I actually praised it's high quality craftmanship. In fact, the GTSpec header is much more impressive to me than the $900 GPMoto.
I simply stated that I got slower from after the install of this product.
Jay
Old 12-08-2003, 08:15 AM   #24
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Following up to everyone elses post...
If I have an exhaust leak, it's not audible at all. Nor is it visible while inspecting the flanges. I'm dropping it this coming weekend to wrap it up. Would you think because it's freezing outside and not having the header wrapped be why it hurt my performance? Cold air blowing over it can't be good I guess.. Not sure really.
Anyways, I'm not giving up on it just yet.. I'll try a few things, make sure there are no leaks and wrap it up and I will post new results.
Jay
Old 12-08-2003, 08:15 AM   #25
Tuning Factory Inc.
Vendor
Member#: 3600
I have personally seen gains with these headers time and time again on the dyno so I have no doubt they work very well but tuning them is going to give you the most out of them and always tell people they are better suited for larger than stock turbos.
Tuning Factory Inc. is offline   Reply With Quote
Old 12-08-2003, 08:21 AM   #26
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Is it possible at all that during the building process of these headers that the diameter of the runners can be different from one another?
Jay
Old 12-08-2003, 09:51 AM   #27
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
when i put the gp-moto on my car with stock turbo i picked up a little bit of lag but it felt a lot stronger past 4.5k. The topend got a big boost in power, measured by the butt-dyno. Now with a bigger turbo it is multiplied i suppose, pulling hard all the way to redline in most cases. 1st gear builds 17psi at most, right at redline. The boost shoots up around 5k and builds up until i let off to shift. Anyhow heatwrapping did help spoolup i belive, but it all came apart from the pipes shifting and me not putting enough clamps on it. Took several hours to do, and thats with another person helping. Im going to get them coated instead, which is what i should have done in the first place.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 12-08-2003, 10:03 AM   #28
WRXMikeH
Member#: 30577
2003 WRX
Jeff, where are you going to get your GPMoto coated?
Old 12-08-2003, 12:48 PM   #29
IA Performance
Member#: 25194
Dark Gray
plus don't forget to pull your negative battery terminal. I.E. reset your ecu. I believe it takes roughly 50 miles to adapt after that.
Not worried about vibration. You figure they were bolted together from the get go so they were nearly a solid piece. If I had removed a flex joint then I would be worried of vibration
Old 12-08-2003, 02:19 PM   #30
Charged Performance
Vendor
Member#: 40645
I am not really sure why people expect almost to need to tune for almost every mod they perform up to and including grounding mods (j/k) but then think that a header should not be tuned for.
That said I have not had a single customer experience any loss of performance with the internally and externally coated GT-Spec headers we sell whether additional tuning was performed or not. And every customer that has done further tuning after installation has come back raving about how pleased they were with the net results.
Unless you reset the ECU it doesn't matter how long you have driven it there are timing zones that may not adapt to the changed environment. At a minimum reset the ECU and advance the multiplier to properly get the ECU ready to fine adjust the timing over the next 100 miles accross the timing range.
You may have an exhaust leak but at most a minor one or you would notice it even from under the motor at the heads. One thing I do with headers since they rarely just pop right up there is after the initial install and torquing I run it for a couple minutes to let the metals shift their relationship to each other a little bit. Then I wait 5 minutes from there and go back and loosen the nuts just a turn or two (not to the point of being lose or seperating the parts) and then retorque them again - never had a head-header leak this way. Just a thought.
Definitely wrap them. Exhaust velocity in the header benefits greatly from heat retention which is why we started coating our headers inside and out before we even receive them - the benefits in exhaust velocity and underhood temps were too great not to make it available to our customers directly.
Ed.
Charged Performance is offline   Reply With Quote
Old 12-08-2003, 02:28 PM   #31
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
I have the coated GP moto header on my car and we tuned it with the GP MOTO unichip. I got 260 lb feet of torque and 220 WHP on the stock turbo. My header was a prototype from the first batch and needs to be welded up. I suggest that you weld yours up too Jeff. Testing has seen 15-20 HP increase after welding the earlier headers. All the new headers are now welded from the factory. The car feels awesome and most people think I have upgraded turbos when we go for a ride
Ashley
LargeOrangeFont is offline   Reply With Quote
Old 12-08-2003, 03:41 PM   #32
WRXMikeH
Member#: 30577
2003 WRX
Here's to hoping that my tight slip joints don't leak on my GP Moto. I fitted it together again last night, and the front cross bar joints are so tight I cannot get it apart without serious effort (using a foot).
Diversion did reset his ECU I think, not positive though.
Old 12-08-2003, 04:25 PM   #33
IA Performance
Member#: 25194
Dark Gray
hmm, so the slip joints aren't really needed? I wonder about pulling mine and zapping them shut. More info please.
Old 12-08-2003, 05:14 PM   #34
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
Yours sound fine mike
ECS- I'm not sure what zapping a GT spec header will cause. The GP MOTO header has enough tubing to expand safely when heated, which is why they are welded now from GP MOTO. I'm not sure if a similar situation would cause a GT spec to crack. On the other hand, look at the borla, it is all one piece. I believe the DC sports one is too.
Ashley
Old 12-08-2003, 06:39 PM   #35
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
I'll reset it once again.. Don't think it's going to change anything.
Jay
Old 12-08-2003, 09:10 PM   #36
0260B4U
Member#: 33249
2003 WRX
white
Well you know its just cuz 02's and 04's suck
03's are da best!!!
http://www.jet-hot.com/
Nuff said'
0260B4U is offline   Reply With Quote
Old 12-08-2003, 09:28 PM   #37
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Here's another bad thing i've gotten on the GTSpec..
This is from Deadbolt:
"Lost power and spoolup. I was running a Monster TD04 that was spooling 17PSI by 2750 RPM's and had put down 222WHP. I put the GTSpec headers on and I was only able to hit full spool by about 3400 RPM and only pulled a 217 WHP. My peak torque was pushed up to 4100 RPM from 2900 also. I took em off and am now running a highly ported stock manifold ceramic coated and am getting 18 PSI from my VF22 at 4100 RPM (I have seen 17.5 as early as 3600 RPM but that might have been a fluke.) "
Now Deadbolt is running a SSAutoChrome/Stone Racing headers (found on Ebay for $250 to $300) and actually GAINED horsepower over the GTSpec header.
Jay
Old 12-08-2003, 09:33 PM   #38
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
03's are da best!!!
Nuff said'
Well I have heard the 03 ECUs run leaner than the 02/04 which gives a little extra oomph...
Jay
Old 12-09-2003, 02:30 AM   #39
ChessMaster
Member#: 44305
2006 Hummer H2
Sold my 2.35L T67 WRX...
GT Spec GEN II headers
1) Well, it's been like one week since these headers have been on one of the two WRXs. The gain is not noticable and it seems as if I loss power. The car doesn't pull as hard and its not as loud. I was expecting power gains as they are advertised at 20whp and 20lbs-ft, etc. I really thinking about pulling the headers off and setting the stock manifold on and selling them.
2) On the other WRX, I have a set of Helix headers, and I definitely noticed a gain and a noise difference. I could hear the spool more and now my car feels as strong as it was on 17psi, and it's ONLY on 14.2 psi right now!! In car #2 with the Helix, I haven't been able to break in the Exedy Hyper single plate clutch yet so I haven't done a WOT run yet, but even without that, the power difference is noticable.
Which brings me back to my concern over the GT Spec headers, I'm wondering why it's not performing, and the quality on this thing is excellent, better than the Helix. The performance just isn't there, or it isn't what I was expecting. With this GT Spec, it uses a 3-bolt flange for the Gt Spec uppipe that is REQUIRED for the header use as any other aftermarket 2-bolt flange type will not fit. The uppipe is huge, and also great quality.
Is there anything wrong with these headers? Is anyone else experiencing this? Any gains that I'm missing?
I haven't reset the ECU as of yet, but I will when I get car #1 from home.
From this I would say the Helix is a better choice, but does it really outperform the GT Spec?
ChessMaster is offline   Reply With Quote
Old 12-09-2003, 02:47 AM   #40
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
I feel the same way you do.. the quality of the GTSpec header is superb.. but where's the performance? The only true gains i've seen from the GTSpec header was on a car equipped with a PE1820 at high boost levels.. which says to me, that the runners on the header are MUCH too large for the stock turbo.. so gains won't be had until you have a turbo pushing enough CFM to make positive use of this header.
Me and a friend compared the pipe diameters between the GTSpec and the GPMoto.. GPMoto's are slightly smaller..
Jay
Old 12-09-2003, 02:59 AM   #41
mlambert
Member#: 13831
h00ray for buttdynos!!
mlambert is offline   Reply With Quote
Old 12-09-2003, 03:04 AM   #42
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Heh, hence why I raced a car that's been 95% even with me in the hundred races i've had against this person. Now things turned crazy unexpected.
Jay
Old 12-09-2003, 03:06 AM   #43
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
-buttdyno
Old 12-09-2003, 04:00 AM   #44
FJP
Member#: 43852
GC8 2.5RST
nice
on topic, I think the huge up pipe causes it to loose velocity and cause turbulance at the turbo'e entrance. I know they call it a velocity pipe, but in realitly it just creates large pocket for the air to slow down in, twice! I have a different brand of header on my car that also had a "velocity pipe". I thought the up pipe was leaking, so I swapped it with a PDE flex pipe. The car is much quicker now! I can also hear the turbo spool up more now.
Old 12-09-2003, 06:24 AM   #45
ChessMaster
Member#: 44305
2006 Hummer H2
Butt dyno as you call it, for now, as I will have both cars dyno tuned in the near future. I'm trying to set up an appointment now.
Old 12-09-2003, 06:25 AM   #46
ChessMaster
Member#: 44305
2006 Hummer H2
If that's true with the PE1820, then I'm going to have switch the headers on both cars, and put the GT SPec with the PE1820 and the Helix with the VF22.
Hopefully, this solves everything
Old 12-09-2003, 07:59 AM   #47
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Without dyno runs before and after the headers and not having them wrapped or coated, I call ignorance on your claims. No matter how many times you and Billy-Bob have run together (Sanctioned Track) it just doesn't hold water. You can't rate a product by slapping it on (possibly wrong), and go race your friend.
BTW: If you were on a sanctioned track why does it matter if noone was closer than 5 miles?
zombiedog is offline   Reply With Quote
Old 12-09-2003, 01:47 PM   #48
WRXMikeH
Member#: 30577
2003 WRX
Nobody said it was a scientific study. There are too many variables to reach a good conclusion...this post was made simply to say the GT Spec headers did not perform as expected. My feelings are, if you can't install a header from a company AS IS (no coating, wrapping) and not get good gains, then the headers are not right for your application. Let's wait for downshift1's header comparison to see some numbers.
The sanctioned track/5 mile thing was a joke. I call ignorance on your question.
Old 12-09-2003, 02:37 PM   #49
zombiedog
Member#: 25138
85 e30
PRIMERZ!
Oh haha, I get it, ha, haha
Old 12-09-2003, 02:37 PM   #50
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Exactly, if I can't bolt up these headers and get results, they have been advertised WRONGLY. GTSpec doesn't say you HAVE to wrap/coat them to get a gain. I got NEGATIVE gains. A dyno would be a waste of money proving me right.. proving I lost power. Something I *already* know.
Jay
You Can't Make Power The Way You Think You Can williaty Normally Aspirated Powertrain 99 05-08-2012 12:20 PM
DriveShaftShop, and Carbonetic in stock! If your Making Power, this is what you NEED! RallySport Direct Drivetrain 28 09-16-2008 01:30 PM
MEGAN GTSPEC POWERSLOT. Make it handle, make it stop! Defiant Autospeed Suspension/Brakes/Handling 15 11-08-2007 03:52 AM
At what stage do you stop trying to make power? reddevil Built Motor Discussion 18 07-04-2007 01:13 PM
Who's Installed GEN2 GTSPEC header fc3swrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-12-2003 03:00 PM
