Old 12-25-2003, 09:17 PM   #1
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
Default COBB stage 2 question
i bought my wrx about a year ago. Quickly i began to notice its performance or lack thereof. the reason why: the bastards that sold me the car didnt include a complete stock boost soleniod, the car was pushing default 5 psi!! so i got a greddy ebc and problem fixed. so now ive done a few mods and want cobb stage 2. but cobb stage 2 isnt designed for an ebc. can i stil run the ebc? what problems may i encour...does anyone know. help please
thanks, Dan
thewhitewrx is offline   Reply With Quote
Old 12-25-2003, 09:39 PM   #2
rossscarbro
Member#: 34627
2006 Evo IX GSR
Graphite Grey
You don't want to use, nor do you need a EBC with Cobb Stage 2. Just go to their site (cobbtuning.com) for more info.
I have Stage 2 and love it!
rossscarbro is offline   Reply With Quote
Old 12-25-2003, 10:12 PM   #3
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
Default bump
but i dont have a stock boost solenoid, i need it (the ebc) ! help me out guys
-Daniel
Old 12-25-2003, 11:54 PM   #4
WorldRallyYellow
Member#: 50215
well since a reflash uses the factory boost solenoid to control boost, it probably wont work in that respect. i would think that the only reason the reflash wouldnt work otherwise is if the ecu rely's on the factory boost solenoids' readings to function correctly.
so honestly, i dont have an answer for ya. contact COBB Tuning, perhaps they can help.
WorldRallyYellow is offline   Reply With Quote
Old 12-26-2003, 01:32 PM   #5
camz911
Member#: 16041
'02 SCRAP METAL
ZERO whp.... :(
i'm pretty sure it will still work, just set your ebc to the boost levels of the cobb stg 2 and you should be fine.
camz911 is offline   Reply With Quote
Old 12-26-2003, 04:17 PM   #6
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
Email cobb or give them a call. They could answer your question.
datwrx is offline   Reply With Quote
Old 12-26-2003, 07:15 PM   #7
clamdip
Member#: 18709
couldn't you just go to the dealer and have them change the stock boost solenoid? is your car still under warranty? yeah, i'd get the stock boost solenoid and get that stage 2 upgrade from cobb. you won't regret it. the cobb stage 2 doesn't work good with an EBC mainly because with an EBC or aftermarket boost controller, since weather conditions vary, the EBC doesn't use any of the sensor inputs to calculate air volume, what it actually does is trick the ECU into allowing more air flow into the engine. the stock boost control works in conjunction with the ECU, therefore, safer results with more power. with the stage 2, a/f ratios are rather lean to begin with, hence more power and better fuel economy and this is with the ECU calibrating proper a/f ratios giving you the best result in safer conditions and may i add, SOOOOOO SMOOOTH!
clamdip is offline   Reply With Quote
Old 12-26-2003, 09:27 PM   #8
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
im not under warranty, does anyone know how much a new stock solenoid would cost?
-dan
Old 12-26-2003, 10:34 PM   #9
hitman912
Member#: 38811
2002 WRX Sedan
Platinum Silver
why arent you under warranty!
hitman912 is offline   Reply With Quote
Old 12-26-2003, 10:48 PM   #10
Hurk
Member#: 40920
04 impreza sedan
blue
I have cobb stg 2 with a mbc
Hurk is offline   Reply With Quote
Old 12-27-2003, 02:34 AM   #11
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
its called a fatty salvage title, bought my car for 14k out the door
-Dan
Old 12-27-2003, 03:22 AM   #12
clamdip
Member#: 18709
-Dan
wow, great price. as for the boost solenoid, you could probably source one from your local subaru dealership. not sure how much it will cost.
Old 12-27-2003, 02:19 PM   #13
thewhitewrx
Member#: 36007
1992 Galant VR-4
Darkness
yeah i know it was a good price, and that was almost a year ago!
anyone know the cost of the stock boost solenoid?
-Dan
Bushur racing stage 1/cobb stage 2 questions boostdog Newbies & FAQs 9 06-07-2007 03:45 PM
cobb stage 2 questions. kuks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-23-2004 06:14 PM
Cobb Stage 2 questions thedude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-29-2004 10:31 AM
cobb stage 2 question thewhitewrx Engine Management & Tuning 4 12-31-2003 03:30 PM
cobb stage 2 questions wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-02-2003 05:35 PM
