Old 01-04-2004, 12:56 PM   #1
Aleksey
Member#: 23445
2007 STI
Default Forester XT. Wheels and tires upgrade.
Hi guys. I have an XT and wish to switch from 16" to 17" wheel diameter and also increase the width of the tire from 215 to 225. Have anybody already tried this? Is there a potential of rubbing problem with the following sizes:
1) 225/45/17
2) 225/50/17
3) 225/55/17
and yes, I am planning to stay withh the same 48 offset.
I know that Luk@TireRack did an awesome job here explaining here how to choose/calculate wheels and tires size but my concern is particularly about the new Forester XT. Any advice or link is gratefully appreciated.
Thanks,
Alex.
Aleksey is offline   Reply With Quote
Old 01-04-2004, 01:07 PM   #2
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
try this on tire diameter calculations...
http://www.subydude.com/tools/AutoTi...Calculator.htm
good luck!
SD
suby_dude is offline   Reply With Quote
Old 01-04-2004, 05:54 PM   #3
Aleksey
Member#: 23445
2007 STI
thanks a lot suby_dude, this calculator helped me to narrow my choice to 225/55/17.
However according to this calculator the OEM Overall Wheel diameter in Inches = 26.16 (215/60/16) and, again, according to this calculator, the new Overall Wheel diameter in Inches will be 26.74, which is slightly higher than the OEM one. Since I am planning to order wheels and tires over the internet (most likely from TireRack) the most concerning question is still the same: will this overall wheel diameter size increase cause any rubbing problems? IMHO the OEM Forester XT wheels look relatively small for this car but as we all know nothing is what it seems so I would really appreciate someone’s professional input on this matter. Thanks.
Alex
P.S. Is there any source in the internet that can tell me whether or not switching from 215 tire width to 225 will cause any rubbing problem on Forester XT.
Thanks
Old 01-05-2004, 08:46 AM   #4
rex n effect
Member#: 15289
02 wrx sedan PSM
& grey '11 TDi daddywagon
rex n effect is offline   Reply With Quote
Old 01-05-2004, 09:03 AM   #5
Aleksey
Member#: 23445
2007 STI
Originally posted by rex n effect
235/50 17
with the same +48mm offset?
what about wheel size? Can I get 235/50 17 on the stock 6.5 wide wheels or I have to swich to 7"? If I have to swich, do I have to go with another offset or 48 will still be OK?
Old 01-05-2004, 11:55 AM   #6
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I think if you went to 235/50/17 you might have to go a 7.5" wide wheel. I think 7.5" is minimum size required for 235's to work. I could be wrong???
dj_noose is offline   Reply With Quote
Old 01-05-2004, 12:20 PM   #7
rex n effect
Member#: 15289
02 wrx sedan PSM
Recommended width for those tires (from tire manufacturers) is 6.5"-8.5". I thought you said you were upgrading to 17"s? Why would you be concerned about the stock 6.5" wide wheels anyway? I've never seen wider tires on a forester, but I haven't looked, either. I'm sure somebody's done it.
Old 01-05-2004, 01:11 PM   #8
Aleksey
Member#: 23445
2007 STI
Are you saying that 17" wheels come only with 7" width? If so, I didn't know that. I thought if I want I can get 17"x 6.5".
Old 01-05-2004, 02:17 PM   #9
rex n effect
Member#: 15289
02 wrx sedan PSM
I've never seen any 17x6.5" wheels.
Old 01-05-2004, 03:31 PM   #10
tora
Member#: 5851
09 Forester XT
+ NA Miata
I'd get a 17x7.5 inch wheel ideally, and a 225/50 or 235/50 or going to give you the best fitment and neight of those should rub if you use a 47 or 48 offset.
tora is offline   Reply With Quote
Old 01-15-2004, 08:02 PM   #11
jamesbb
Member#: 52346
2004 Forester XT
Default Tire upgrade on stock wheels
I am thinking of upgrading to Goodyear HR-GT 235/55/HR16 tires on my stock F-XT's 16x6.5" wheels.
Has anyone done this? If so, what were the pros and cons of doing it?
Jamesbb
jamesbb is offline   Reply With Quote
Old 01-15-2004, 08:51 PM   #12
gellar
Member#: 31047
11 135i
Sedona Red
235's on a 6.5" wheel are probably not a very good idea... I'm not saying I'm sure they won't fit, I'm just saying they likely won't.
Sergi
gellar is online now   Reply With Quote
Old 01-16-2004, 09:16 AM   #13
rota wheels wrx
Member#: 13856
04/5 STI
white/WRB
I know of some foresters on 225 55 17 tires.
The wheels are 7.5x17 offset 48. No problems reported
rota wheels wrx is offline   Reply With Quote
Old 01-22-2004, 12:07 PM   #14
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I'm considering going to 235/50-17 tires on a 17 X 7" wheel with a 48 offset on my Forester XT, just checking if anyone has done this and were there any problems with rubbing.
(OZ Superleggs)
According to tire rack info:
235/50WR17 rim width range - 6.5-8.5"
that only gives a 0.4% too slow reading (60 reading is 60.2)
VS
225/50's 1.1 too fast (60 reading is 59.3)
Anyone?
TIA
Peaty
Peaty is offline   Reply With Quote
Old 01-22-2004, 10:04 PM   #15
XT6Wagon
Member#: 524
04 STi
225/40R18's fit great. 235's look like they will work. 245's will take the right rim selection IMO.
XT6Wagon is offline   Reply With Quote
2004 Forester XT wheels and tires willib Private 'For Sale' Classifieds 3 09-13-2004 05:26 PM
Brand New Forester XT wheels and tires SCutchins Private 'For Sale' Classifieds 0 04-27-2004 10:50 AM
New stock 2004 Forester XT wheels and tires wadejg Private 'For Sale' Classifieds 13 02-17-2004 01:04 PM
FS: Forester XT wheels and tires MyOtherCarIsASubaru Private 'For Sale' Classifieds 5 11-18-2003 09:46 PM
Local FS: 4 16" Forester XT wheels and tires MyOtherCarIsASubaru North West Impreza Club Forum -- NWIC 7 11-07-2003 07:41 PM
Message Board Statistics All times are GMT -4. The time now is 08:09 PM.
