Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds
Old 01-27-2004, 02:26 PM   #1
Joncas
Member Sales Rating: (4)
Member#: 5349
Default Supercharger Kit For Sale - Complete
Sold! Thanks everyone!
Eaton M62 EJ25 Supercharger kit For Sale.
Price dropped - $2500
Full kit complete with everything you need to get it running.
Price: ~ $2500 (buyer pays shipping)
Hardware:
Eaton M62 Supercharger - new June of '03
2 piece nose drive system - new June '03
8-10psi pulley - new June '03
(can have a 5psi pulley made from my blueprints for a modest fee)
Modified Blower Exhaust housing with secondary injector bosses
Rimmer blower intake housing
Rimmer Throttle body IAC adapter
Bypass valve (for fuel economy when not in boost)
Reverse alternator pulley
Secondary Injector Fuel Line Hoses and T's
Intake with filter
Cold Airbox Shield
Hood with Bubble on it (Silverthorn Metallic)
Electronics:
SDS Extra Injector Controller (runs the secondary injectors and doesn't care about your ECU or anything)
2 x 480cc Secondary Injectors (good for 160hp on their own allowing you to run stock injectors and stock fuel pressures)
All nuts, bolts, clamps, fittings, and T's required.
Instructions (by yours truely)
*** Added for free - 3 inch custom high flow mandrel bent cat section. Will bolt up in stock locations depending on exhaust system. Look in thread for pictures.***
If I left anything out just ask.
Joncas is offline   Reply With Quote
Old 01-27-2004, 02:30 PM   #2
Joncas
Member#: 5349
I'm sad to see it go. I love my projects.
It's on my daily driver and it is rock solid reliable. I have driven it in conditions ranging from -30F to 110F degrees and on trips as long as 500 miles non-stop. The Supercharger is self contained. There are no oil lines or coolant lines to run. Power delivery is smooth. All of the rotating "rimmer kit" parts have been discarded. The new rotating assemblies have less than 15,000 miles on them (all by me). I worked directly with Eaton/Magnuson on the supercharger/drive design and it's totally custom and the only one like it. They say it should have an expected life of 100,000 miles.
Only recommendation would be a J&S safeguard if your going to run the 8-10psi of boost. You'll need to pull some timing out. No I won't guarantee you won't blow up your own car but 5psi won't need the timing control.
Bubble shot (because I feel people give it a bad name - i'm kinda fond of it). This thing turns heads nothing beats blower wine at high rpm.
Old 01-27-2004, 02:59 PM   #3
4npower
Member Sales Rating: (2)
Member#: 9018
02 WRBP WRX
Slvr 06.5 Jeep Grnd SRT8
VERY NOYCE! how much HP & TQ does your car make ?
4npower is offline   Reply With Quote
Old 01-27-2004, 03:10 PM   #4
HonduHunter
Member Sales Rating: (6)
Member#: 28408
2002 vf48ed WRX
that is cool.
HonduHunter is offline   Reply With Quote
Old 01-27-2004, 03:39 PM   #5
AdmireWantWillLove
Member#: 24146
2004 GTO
That is very nice! If I had a stock RS, I would consider that!
Good job!
I'm curious too how much HP & TQ?
AdmireWantWillLove is offline   Reply With Quote
Old 01-27-2004, 03:46 PM   #6
Joncas
Member#: 5349
Thanks!
To be honest I don't have solid numbers for anyone. I never dyno'd it. Madmax has a car with the same supercharger but it's intercooled - It put down 184hp and 204lb/ft at 6psi.
I know my kit makes more torque than hp I'm sure of that. The only numbers I have is that I used to run a 0-60 time of 9.3 seconds stock (remember its an automatic). I now run a 6.2 second 0-60. Thats with a car that weighs in at 3320lbs with my stereo system (porky), me (porky), full of gas, spare tire, and some stuff in the trunk. My tune is pretty conservative and my engine has ~100,000 miles on it (runs great though).
Here's a video of it so you can see and hear it run. It's in the video three separate times.
Old 01-27-2004, 09:27 PM   #7
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
Gotta know, why are you gettin rid of it?
ShadowIMg is offline   Reply With Quote
Old 01-27-2004, 09:29 PM   #8
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
wondering if this will work on a MAP sensor'd motor
Andrew Bacon is offline   Reply With Quote
Old 01-27-2004, 11:17 PM   #9
blaznc
Member Sales Rating: (3)
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
Does the engine require lifting to install the kit?
blaznc is offline   Reply With Quote
Old 01-28-2004, 12:09 AM   #10
Joncas
Member#: 5349
The popular answer - One I need money. Two, my brother (Joncas2 on the club) recently purchased a 1998 RS and we'd like to have similar setups to do track events together and compete with each other. We really can't afford to duplicate this supercharger setup in any cost effective manner (it costs too much). We thought about it but with our budgets we just can't swing it. So yea umm yea.
Yes. You will need a Map sensor voltage clamp. I think they are inexpensive. I know the J&S safeguard I mentioned has one built in too (but its like $450 and does way more than just voltage clamping).
No lifting - no cutting. Except of course the hood - which comes with it.
Old 01-28-2004, 12:41 AM   #11
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
Are you running a full exhuast?
t.rod is offline   Reply With Quote
Old 01-28-2004, 01:18 AM   #12
Andrew Bacon
Member#: 2267
00RS
Do you have a closer pic of the hood? I'm trippin on it
Old 01-28-2004, 02:42 AM   #13
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Can you post pictures of your exhaust? You have a TrustDD rite?
Derk1127 is offline   Reply With Quote
Old 01-28-2004, 04:51 AM   #14
THAWA
Member Sales Rating: (15)
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
omg, you get props from me joncas, your car sounds so nice, good ride you've got there.
THAWA is offline   Reply With Quote
Old 01-28-2004, 05:10 AM   #15
15secWRX
Member#: 52088
07 limited
URBAN GRAY
do you think you could make a kit for the WRX so i could be supercharged and turbocharged haha?
15secWRX is offline   Reply With Quote
Old 01-28-2004, 10:39 AM   #16
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Originally posted by Joncas
Thanks!
Remember thats at the wheels
MadMax
MadMax is offline   Reply With Quote
Old 01-28-2004, 10:46 AM   #17
blaznc
Member#: 41862
0000 99L 2.2T, dead
You think this will fit on a 99 L model with an EJ22?
Old 01-28-2004, 10:59 AM   #18
getek20
Member#: 43560
2009 Lancer Ralliart
I PM'ed you on RS25.com.
getek20 is offline   Reply With Quote
Old 01-28-2004, 10:25 PM   #19
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Bump for the bro.
Joncas2 is offline   Reply With Quote
Old 01-28-2004, 11:24 PM   #20
linux>windows
Member#: 49517
What kinda bumper does that car have?
linux>windows is offline   Reply With Quote
Old 01-28-2004, 11:31 PM   #21
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Thats an isotta (chargespeed in US?) front lip ver 2
Old 01-29-2004, 12:10 AM   #22
Joncas
Member#: 5349
Thanks for the props. It's been hard work and dedication to make it what it is. Now for the questions:
Yes, Borla headers, 3 inch custom mandrel high flow cat section I made, 3 inch greddy dd exhaust.
Best I have from side. Check the Greddy website. They have another.
I don't know to be honest. I mean the engine bay is the same size but there are a few key pieces that must be the same as the EJ25. The bolt pattern on the throttle body must be the same. The distance and angle of the throttle body to the crank pulley must be the same. The crank pulley must be the same size as on the EJ25 if you don't want to have one made (but thats not a real big deal). If those variables are the same I don't see why it wouldn't fit but I'm not going to claim anything. PM me with your email and I'd be happy to send you some more pictures if you want.
Old 01-29-2004, 12:19 AM   #23
sidewayz
Member#: 5810
2001 S366 2.5RS
holy hell...I just shat myself! Dude I saw that pig at Carlisle last year and this is the first time I heard it run....I am impresed!
fatty bump for you!
sidewayz is offline   Reply With Quote
Old 01-29-2004, 02:57 AM   #24
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Any interest in selling the exhaust? or a trade? Probably not huh?
Can you answer me a question about it.. does it come with silencers?
Old 01-29-2004, 01:13 PM   #25
Joncas
Member#: 5349
No trade on the exhaust unless its for a brullen 3 inch quiet dual tip or $650 so I'm almost able to get one (It was new 8 months ago). Supposedly it does come with silencers. I didn't get any. Talked to Greddy - they denied they existed. Talked to a Japan importer... $95 later... we have Greddy DD silencers... amazing. Took 8 weeks. That's really why I would want so much for it. It was a pain to get it and expensive.
Complete Subwoofer/Amp kit For Sale! JokerDMX RMIC Private Classifieds 5 05-29-2008 06:01 PM
CA: Supercharger Kit for Sale - Complete sbrcr267 Engine/Power/Exhaust 5 08-09-2007 11:46 PM
complete stage 4 kit for sale! everything for 300 whp jrlandsman Private 'For Sale' Classifieds 10 03-07-2006 10:24 AM
Used supercharger kit for sale (testing waters) HamFist Private 'For Sale' Classifieds 1 12-19-2005 03:02 PM
Guess who's making a Supercharger kit for Civics now (Subaru related content)...... MPREZYA General Forum Archive 5 11-23-2000 06:42 AM
