Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-24-2004, 12:42 PM   #1
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Default 2.2 Legacy block into a 2002 WRX
I have a 2002 WRX and am going to do some engine work on it. Will a 2.2 litre 1994 Legacy Turbo AWD block be a direct replacement for my stock block? If it is then I am going to look into them, since it will be cheaper to bore a 2.2 to 2.5 than it would to take a 2.0 to 2.5.
Nick
Rizzo314 is offline   Reply With Quote
Old 02-24-2004, 03:15 PM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
The 2.2 legacy block is the strongest block subaru made. You dont need to bore it anymore its already a 2.0 bored to 2.2. You can have it worked so it uses a phase 2 ej25 crank and then get yourself a 2.4. But realy the block is as strong as you will ever need. check out this thread. I have posted links too all the 2.2 leg block info you will ever need.
http://forums.nasioc.com/forums/show...hreadid=505723
Old 02-24-2004, 05:26 PM   #3
Rizzo314
Member#: 42215
Ok, that helps a lot. When I get it built should I have it sleeved, or is it strong enough as is?
I saw that Axis has a 2.35 that looks fairly decent. There is a place in town that when all is done it would cost me about 3500 to have my stock 2.0 bored and sleeved to a 2.5 (I think, I need to re-add it). I might look into the Axis block.
Will my ej20 heads bolt directly up to the ej22?
Nick
Old 02-24-2004, 05:37 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Nick
Ya, the wrx heads will bolt up... you dont need to get this block sleved check out this thread.
http://forums.nasioc.com/forums/show...ght=ej22T+ej22 The C/R ratio and what gasket to use should be covered in one of the other threads in my first link.
How much power do you want? Say above 400 you might want to pick up a block from axis, cobb, or ispeed... But the 2.2 is more then enough for most set ups.
Old 02-24-2004, 05:46 PM   #5
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
The 2.2 is an awesome case. Here are some pics I took comparing the stock sleeve liners of a JDM 2.0 STi, a US legacy turbo, and a US 2.5 STi
http://axispowerracing.net/blockcomparo/
-Mike
MJU1983 is offline   Reply With Quote
Old 02-24-2004, 05:49 PM   #6
totoherbs
Member#: 7321
.... 122 IggPoints
-Mike
Thanks.... thats a sad looking liner on the 2.5.
Old 02-25-2004, 12:49 AM   #7
Rizzo314
Member#: 42215
Yea, I am looking into Axis blocks now. It would be worth my time and money to go with one of theirs.
I sent you a PM Mike.
Yea, the 2.5 looks dwarfed next to the 2.2
Nick
Old 02-25-2004, 02:56 PM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
Nick
How much power are you looking to make, and how much do you want to spend?
Old 02-25-2004, 05:04 PM   #9
Rizzo314
Member#: 42215
I am wanting to make around 400-450 at the wheels. I am looking at getting the Stage 4 from Axis, so around 3500 on the block.
Mike, I sent you another PM last night, did you get it?
Nick
Old 02-25-2004, 05:20 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Cool, good luck. Dont forget the heads, and other goodies to put that block to use. Have you figured out how much this will all cost yet?
Old 02-25-2004, 05:27 PM   #11
Rizzo314
Member#: 42215
I am looking into getting valves, porting, and cams right now. And I have figured it to cost a lot, but I would rather spend a little extra now and have a really well built engine, than to have to have it done when it blows up.
Nick
Old 02-25-2004, 05:47 PM   #12
totoherbs
Member#: 7321
.... 122 IggPoints
Nick
I agree with you there. The only cams worth it are the juns.... the rewelds I wouldnt trust in the heads I just paied $2k for.
Version 5 or 6 WRX or STi into a 2002 WRX? duece_bugeye Pre-2002 Factory Turbo Powertrain 6 03-24-2007 12:05 PM
Version 3 ,4 ,5, 6 JDM WRX or STi motor into a 2002 WRX? duece_bugeye Subaru Conversions 3 03-24-2007 10:07 AM
2004 WRX clutch going into a 2002 WRX Hallywood Transmission (AT/MT) & Driveline 1 06-19-2006 02:48 PM
2.2 block into a 2002 wrx? linus011 Subaru Conversions 3 02-16-2005 11:20 PM
ej22 block into stg 4 wrx wrxtuner02 Subaru Conversions 6 05-31-2004 08:41 PM
