Old 03-03-2004, 01:05 AM   #1
SSsleeper96
Member#: 50202
2006 STi
Question RPM spike
I've had my '04 Subie for 4 months and 4500 miles. I have a borla hush sysytem w/ high flow cat in last cat position, tbxs manual boost controller (set at 14 psi w/ boost gauge), forge blow off valve, and helix uppipe. The problem is that my RPM's keep on spiking 200-350 RPM b/t the 2-3 and 3-4 upshift. I know the engine runs rich with a 100% atm bov. Is this the reason or what? Thanx
SSsleeper96 is offline   Reply With Quote
Old 03-03-2004, 06:38 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It's normal, get used to it. There are 50,000 reasons why it does it, but the most commonly known one is the engine revs after shift to burn off extra fuel for lower emissions caused by the upshift.
Old 03-03-2004, 01:11 PM   #3
SSsleeper96
Member#: 50202
2006 STi
Thats all I needed to hear Thanx alot.
Old 03-03-2004, 02:01 PM   #4
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Any problem with Open/closed loop sensor?
Supposedly running a TBE and MBC will cause problems with 04, though it is fixable with reflash...
Gfunk720 is offline   Reply With Quote
Old 03-03-2004, 10:57 PM   #5
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Does it happen when you get it above 5k rpm at wot?
Turbo9000 is offline   Reply With Quote
Old 03-03-2004, 10:59 PM   #6
Double-R-WRX
Member#: 30825
2004 EVO V/// (8)
MIA sfVoltron MeMb3R
I have an 02 with a Borla Hush, a Bosal DP etc etc ..
Does the same thing .. Its common and in the 20+ Subaru's I've been in they all do it ... Dont need to fret ...
Double-R-WRX is offline   Reply With Quote
RPM spikes when shifting apak123 Newbies & FAQs 9 08-24-2005 02:15 PM
RPM spike SubyINdaBahamas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-03-2005 01:54 PM
Ok what's with the rpm spike when foot's off the gas? Undepelo General Community 38 02-02-2004 10:26 AM
RPMs spike when shifting? quynce Newbies & FAQs 15 06-21-2002 05:42 PM
200 rpm spike on fast shifts corbeil Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-03-2002 02:16 PM
