03-17-2014, 02:38 PM | #5126 |
Member#: 324361
Vehicle:2012 Impreza Sport ICM 5MT |
At 1 qt per 2000 miles (normal per Subaru) , that will be about 3 qt of 5w40 by 6000 miles before the 7500 OCI, almost 5qt anyway assuming consumption rate is the same
03-17-2014, 06:22 PM | #5127 |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
Warranty for starters. Yes the manual states you can "top off" if needed, but running 2, 3, or 5 OCIs of a weight not recommended would definitely be grounds to void a warranty. If you're dead set on 5w30 or 5w40, why not at LEAST use a synthetic instead of conventional?
03-18-2014, 02:33 AM | #5128 |
Member#: 310435
Vehicle:'12 Sport Limited Black - 255,685 miles |
I wonder where did Subaru pull that one from. Who makes a conventional 5W-40? Maybe they have it in Japan but I haven't seen any over here. They also don't mention 5W-20, which is what I use, but 5W-30 is the highest I would go to top off or fill the crankcase with.
03-18-2014, 08:32 AM | #5129 | |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
03-18-2014, 09:23 AM | #5130 | |
Member#: 259587
NESIC
Vehicle:2014 Impreza White |
03-18-2014, 11:00 AM | #5131 |
Member#: 302570
Vehicle:2013 XV DGM! |
03-18-2014, 11:10 AM | #5132 | |
Member#: 302570
If you dig around on international subaru forums, some australian dealers have been using heavier oils and no warranties are voided. Someone on XV forum has said over there that their ocis are giing to 6k officially and that using the heavier oils is factory ok'ed. The aussies are much more observant and much more vocal about defects than americans and many are demanding some sort of resolution. Good folks, those Aussies. I'll link any info I can dig up later. Its all out there via google. The forester forum and outback owners are also leaving oil burning comme.ts all over the web. Its definitely a much much bigger problem than just "a few unique individuals". And they definitely arent all nasioc members. Remember one users comment that "surely they would register with nasioc and complain if they had an oil burner". |
03-18-2014, 11:13 AM | #5133 |
Member#: 315353
NESIC
Vehicle:2012 Impreza Sp Prem 5MT OBP/DGM |
I only just started topping off with the 5w30 but I'm not really expecting much of a drop in fuel economy, if any at all. Remember, I'm not running my engine full of 5w-30, just replenishing the oil that's being consumed in between my 5000 mile OCIs.
Actually, my fuel economy has been getting better over the past few weeks but that's most likely a result of slightly warmer temperatures. Last edited by jr0bb5; 03-18-2014 at 11:19 AM. |
03-18-2014, 11:50 AM | #5134 | |
Member#: 329271
South East
As to how they would know you're using a thicker oil? A simple oil analysis would show that plain as day! I'd bet money with an engine failure warranty claim they would do one before approving a new engine! |
03-18-2014, 11:54 AM | #5135 |
Member#: 302570
So just dont take it to them full of 5w30. Any residual 5w30 would be from "top offs when 0w20 wasnt available".
03-18-2014, 12:21 PM | #5136 | |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Consumption of 0w20 is a nuisance, but it won't hurt your engine. Switching to 5w40 may reduce consumption, and with it your engine's lifespan. You're going after the most visible issue (consumption) at the expense the important one (wear). |
03-18-2014, 01:25 PM | #5137 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
jr0bb5 - Before using 5W-30, I would try an entire fill of 5W-20. 5W-20's sometimes have less volatility (oil loss through evaporation) than a 0W-20 of the same brand. Check Amsoil as an example since all manufactures do not post their volatility results. All Amsoil 5W-20's have less volatility than the 0W-20's. IIRC, Amsoil 5W-20's have less volatility than the 5W-30's. Definitely don't go with a 5W-40 unless you know that your mixture will provide you with adequate cold cranking properties (a small amount of 0W-40 might be fine). I would use a High Mileage 5W-20 over adding any 5W-40. -Dennis Last edited by bluesubie; 03-18-2014 at 01:34 PM. |
03-18-2014, 01:37 PM | #5138 | |
Member#: 319157
03-18-2014, 02:09 PM | #5139 |
Member#: 319157
Those of you with high consumption who are worried about your catalysts and not opposed to running 5w30, might be interested in this:
http://www.mobiloil.com/USA-English/...ula_5W-30.aspx The low phosphorus content is supposed to be less harmful to the converters. |
03-18-2014, 06:38 PM | #5140 |
Member#: 329271
South East
Thankfully, I am one of the few who have not experienced any oil consumption issues so far in my 40k miles. It also appears as though subaru's "fix" isn't solving most people's problem they're experiencing. I came across this today, and was very impressed. Granted, the price tag is much higher per vehicle, and there's less of them on the road, but THIS is the kind of exceptional "above and beyond" customer service that keeps customers brand loyal!
http://blog.caranddriver.com/porsche...l-be-replaced/ |
03-18-2014, 07:21 PM | #5141 |
Member#: 106330
Vehicle:14 ISP 5MT Silver |
Apologies if this has been posted before
I came across a tear down of FB20 engine to replace rings - http://www.reddit.com/r/subaru/comme...the_fb20_tear/ Following the thread is a little challenging, Subaru seems to spec oil consumption to 10.7 oz per 1200 miles, reference Subaru TSB for ring replacement Someone posted Goggle Docs Subaru FB25 ring TSB Last edited by suiram; 03-18-2014 at 08:05 PM. |
03-18-2014, 08:34 PM | #5142 | |
Member#: 315643
South East
03-18-2014, 08:34 PM | #5143 |
Member#: 233374
Vehicle:2009 Suzuki SX4 2012 Impreza |
Another oil light issue.
The oil light on my wife's '12 Impreza has been coming on quite a bit over the last year. I top it off w/the recommended weight, and it disappears. She drives it to the dealer ... no issues found. The car is never abused, and she keeps her miles low. She was finally able to bring it in with the light still on. And, since there's absolutely no sign of leakage ... we are working with them to run a consumption test. We shall see what they find... rob |
03-18-2014, 08:34 PM | #5144 | |
Member#: 310435
03-18-2014, 09:05 PM | #5145 |
Member#: 329271
South East
I believe I mentioned the price difference in the two cars. And yes, you're right, one is more of an inconvenience and one is safety related, however the basic principal of the matter is the same! One company has come up with a "fix" that is not fixing the problem for MANY of the people who have had it done. The other company is going above and beyond what is required of them under a recall or warranty. They could very easily do tear downs on all of those engines and rebuild them to specs with the new hardware. Instead, they decided to give their customers brand new engines! The point I was making is Subaru is doing the bare minimum and Porsche is doing way more than what a normal person would consider fair. Price point is irrelevant to my point!
03-18-2014, 09:37 PM | #5146 | |
Member#: 319157
Subaru blames the rings, but from this thread, it looks like the short block replacements have done harm more often than good. How can they be sure the heads aren't at fault? |
03-18-2014, 09:39 PM | #5147 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
Sorry, but I can't agree with this. Part of what you're buying when you fork over $150k for a car is a level of customer service that can't be matched when buying a $21k car (although I must say that I've been very happy with my Subaru dealership).
Case in point: Volkswagen (which also owns Porsche) does not provide excellent customer satisfaction at its dealerships. VW dealerships have a reputation of generating customer frustration. So you see, even though the same parent company owns both VW and Porsche, the way they treat their customers is completely different. I would guess that Audi treats its customers better than VW, but worse than Porsche, since they are priced in the middle. Price is very relevant! Last edited by sgoldste01; 03-18-2014 at 09:45 PM. |
03-18-2014, 09:43 PM | #5148 | |
Member#: 767
http://www.mobiloil.com/USA-English/...duct_Guide.pdf -Dennis |
03-18-2014, 09:47 PM | #5149 | |
Member#: 319157
03-18-2014, 09:47 PM | #5150 |
Member#: 319157
[edit]
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? | JDMSTA | Electrical & Lighting | 59 | 07-21-2013 08:04 AM |
2012 Impreza 2.0i Mobil1 oil filter model # | jr0bb5 | Service & Maintenance | 27 | 01-04-2013 05:18 PM |
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 | Oceanguy | Impreza Forum | 80 | 11-18-2012 12:56 PM |
My Oil Light is Flickering and I have No Leak??? | kakarotoni | Newbies & FAQs | 39 | 08-16-2012 10:36 AM |
('11-'14) 2012 Impreza High beams = Low beams lighting | Jmzda | Impreza Forum | 28 | 06-01-2012 12:14 PM |
