08-08-2008, 03:07 PM | #1 |
Member#: 120985
South East
Vehicle:2002 Impreza WRX Midnight Black Pearl |
So, I mixed up my buckets/shims whatever you call them.
So when i took off my cam caps, the 'shimless buckets' fell out and i lost which one goes where.
what can i do to get the heads back together? |
08-08-2008, 03:24 PM | #2 |
Member#: 106909
Vehicle:2002 V7 STi Prodrive Edition... Black! |
First off, the head MUST be torqued down for you to be able to set your clearances properly. This is due to the head twisting as it torques down.
Start with one cam at a time and put in any 4 buckets. Write down which thickness bucket you have put in each valve. Measure the clearance you have with each bucket and write that down. Add you clearance measured to the bucket size fitted. This will give you your total clearance betwen the cam and the valve stem tip. From this figure you must subtract the actual clearance youre trying to achieve. This will then give you the size of the required bucket to fit. Ie (Fictional sizes) Bucket fitted 3.5mm Clearance measured 0.5mm Add them together - Total clearance is 4mm Actual clearance you want say 0.75mm (4mm) subtract desired clearance (0.75mm) = 3.25mm (required bucket size for correct clearance) Hope that helps |
08-08-2008, 03:30 PM | #3 | |
Member#: 120985
South East
08-08-2008, 03:32 PM | #4 |
Member#: 106909
Yes mate. they cant be setup on a bench as when you torque the head down your clearances will all change.
08-08-2008, 04:03 PM | #5 |
Member#: 120985
South East
08-08-2008, 04:04 PM | #6 |
Member#: 106909
Yes mate more than likely
08-08-2008, 04:17 PM | #7 |
Member#: 120985
South East
08-08-2008, 07:10 PM | #8 |
Member#: 125304
To me it is a little easier to find the thinest or lowest bucket and use that one on each valve and with a feeler measure the thickness, add that to the bucket thickness and subtract the clearance you want to get the right bucket for that valve. I try to get the minimium clearance if I can. Be sure to check the cam manufacturers specs cause sometimes it's different than stock.
If you change cams bets are you will need to shorten valves to use some of your buckets you already have and also buy a few new ones. I would also grind the valves before you start so everythings new. You will have to do the buckets everytime you change cams or valve height. Somewhere there is a bucket chart that shows the part number that coincides with it's thickness |
08-09-2008, 12:53 AM | #9 |
Member#: 106909
08-09-2008, 10:44 AM | #10 | |
Member#: 120985
South East
that chart would be VERY helpful |
08-09-2008, 08:09 PM | #11 |
Member#: 36652
NESIC
it's in the manual. this link might work but it's been finicky lately....
http://www.auto-epc.ru/2004%20STI/index.htm |
08-09-2008, 08:11 PM | #12 |
Member#: 36652
NESIC
08-09-2008, 08:34 PM | #13 | |
Member#: 14364
MWSOC
Vehicle:2003 WRX, '06 Armada 05 Vette & 05 STi (sold) |
If yes, you will most likely needs new buckets anyway as your clearances will change. Just measure everything with a feeler gauge and reference the Subaru manual - it lists the buckets by #. |
08-10-2008, 08:30 PM | #14 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
How do you look at the buckets and know what size it is? Or can you not do that and need a micrometer?
08-10-2008, 08:46 PM | #15 |
Member#: 33971
South East
Vehicle:2006 WRX |
gotta mic them man
08-10-2008, 10:13 PM | #16 |
Member#: 111556
Tri-State
Vehicle:2006 STI Black |
08-10-2008, 10:35 PM | #17 | |
Member#: 33971
South East
Vehicle:2006 WRX |
taken from cosworth installation manual Last edited by nicad; 08-10-2008 at 10:43 PM. |
08-11-2008, 11:57 AM | #18 |
Member#: 120985
South East
08-11-2008, 11:33 AM | #19 |
Member#: 85813
South East
Thanks....I'm reading up before doing my cam swap
08-11-2008, 05:44 PM | #20 |
Member#: 125304
Some of ours were marked and some were not. You need to mike them to be sure as someone already posted. I have bought extras from nasioc guys for around 12.00 ea. Thats what I would try but you need to know what ones you need first. I will buy whats left over if they don't look worn.
08-20-2008, 02:59 PM | #21 |
Member#: 120579
International
Vehicle:1995 STi V2 Wagon Silver |
Hi there,
Just have a question about this procedure... My mechanic recently sent my cylinders heads to get the shim and bucket sizes checked again... however they are noisy as hell, my $12k conversion sounds like a diesel. The cylinder head guys assures me that the clearances are correct... Does it matter whether the cams are apparantly cut? Should'nt the cylinder head guy have used the procedure above to ensure the gaps are correct? What else could cause a like tappet noises from these shims and buckets, the heads are from a Legacy 2004 B4 twin turbo? Many thanks, San not meaning to hijack, thought it might bear relevance to the current issues. |
08-21-2008, 12:26 AM | #22 |
Member#: 125304
I don't remember if we ever tried to do the buckets before the heads were torqued on the block or not. The best way would be to check the clearances after the heads are torqued. If the noises are coming from the heads it is the clearances on the buckets. I not sure what the cut cam statement means.
08-21-2008, 07:49 AM | #23 |
Member#: 120579
International
cut cams = ground cams maybe about 268 or so' the car does have an idle problem and that is with the default maps of a link ecu.
I do get piston slap from the wiseco's till he warms up... thereafter is just sounds like my diesel truck. |
08-23-2008, 11:50 PM | #24 |
Member#: 125304
If you mean reground cams then I imagine the base circle of the cams is smaller as that is the only way to get more rise at the lobe unless the cams were built up and then ground which is unlikely. If the base is cut .020 say to give .020 more lift then all the valve gap clearances will be .020 looser and all the buckets will need to be .020 thicker to make up the difference.
Similar Threads | ||||
Soccer shoes/boots/whatever you call them | CWG08STI | NWIC Private Classifieds | 0 | 02-24-2010 05:16 PM |
Tea parties, tea baggers, whatever you call them... | RastaMon | Political Playground - Chaotic Neutral Edition | 428 | 02-16-2010 10:53 AM |
JDM Rear Spats/Aprons/Whatever You Call Them | Keep-It-Clean | Exterior/Styling | 14 | 05-30-2007 10:26 AM |
So, OT laptop experts/whatever you call yourselves. | Zand | Off-Topic | 4 | 11-19-2005 02:58 AM |
Headlight Lids...or whatever you call them | sleptoor | Interior & Exterior Modification | 9 | 04-12-2003 01:36 AM |
