05-06-2009, 07:41 PM | #1 |
Member Sales Rating: (9)
Member#: 129503
VIC
Vehicle:2002 It's resting 6 > 4? |
WTB: EJ251(2.5RS engine) - cheap!
Hey, I'm looking for a complete EJ251 - block, heads, intake manifold....for a mock up engine.....
if you have an RS engine you need to get rid of let me know....will take in any condition, but prefer one that isn't in working condition as i dont really want to spend more than a couple hundred.... but yeah, depending on condition, whats left on the engine, etc we can work out a price!... |
05-07-2009, 02:54 AM | #4 |
Member#: 129503
VIC
i have an ej255 shortblock..also a ej251 shortblock too for that matter....
but what i need is an ej251 block with heads, oil pan would be awesome, intake manifold would be awesomest..... the shape of the ej251 heads is quite a bit different, most wrx up-pipes hit the SOHC heads....basically i want to make a twin scroll header/up-pipe that will work with the SOHC heads (since none of the wrx ones will)....and i'd like to make a intake manifold as well.....accessories like alternator and ps pump would help too...see what i'm saying....so an engine with as much stuff as possible will help so yeah, and ej25d, ej22, etc, engine wont work....yaarrgg |
05-07-2009, 06:28 AM | #5 | |
Member#: 53455
Vehicle:2004 Forester XTI dark |
So 255 ($$$) or 22 (cheap) bottom and d heads = the robust OEM mix. Last edited by andys; 05-07-2009 at 06:33 AM. |
05-07-2009, 01:04 PM | #6 | |
Member#: 129503
VIC
go familiarize yourself with my car....thanks for trying to help but i'm a little bit ahead of where you think im at i paid 300$ for my first ej255 block...hardly $$$....and yes wrx stuff does not hit the DOHC heads....hence why i said they hit the SOHC heads....again....im not going to be using this engine for anything but mocking up parts for the engine that is already in my car... also the best route to be going for an RS-T route if you're looking to go cheap is to put sti internals in a 251 block....hydra, gt32 and you're good to go ...you want to stay away from ej22 heads as anything 96(i believe) and newer are almost all single port....the ej251 block is a better option as sti internals go for dirt dirt dirt cheap all day long...while finding internals for cheap for the ej22 is rather difficult (read expensive) just for ****s and giggles: http://www.rs25.com/forums/f7/t10622...o-your-rs.html |
05-07-2009, 06:58 PM | #7 |
Member Sales Rating: (24)
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) |
i believe andy is talking about using the DOHC heads because you can use stock exhaust and such to clear the heads. an ej22 is cheaper than a 251 no matter how you spin it. i got my entire engine with all accessories and harness for nothing... i had to pull it all myself and scrap the car but that's easy. and it was free...
if you use an n/a ej22 (dual port or single port) block and throw ej25 heads (dohc preferred) on there then you get a low compression ready to turbo engine. And running the DOHC heads you get all the oil lines and exhaust ready to go as it all fits with the DOHC heads. i know roughly what both of you are planning on doing and while it sounds similar on paper (n/a motor made turbo) you are going about it in completely different ways. |
05-07-2009, 07:07 PM | #8 | |
Member#: 129503
VIC
and yes you drop some compression....but you still have very weak internals....sure if you're running a little turbo and keeping boost pretty low you'll be fine...but whats the point....take an ej251 (even if you have to pay for it), drop in some sti internals, get some decent EM, a good sized turbo and run away with 300-400 whp no problem....with the stock SOHC heads and what im planning to do is completely different than what andys wants to do....his is like mine was 2 builds ago.....cheap... right now i'm leaning towards twinscroll s366/gt4088/etc....on the engine in the car now (PNP 251 heads, cams, ej257 block (stock internals)....18G, hydra, blah blah balh) theres lots of routes to go.....but i'd argue that the ej22 route isn't really any cheaper/hp...but it also depends on whats in the car to start....90% of people turboing N/A subarus have ej251s in them to start Last edited by Jeff54; 05-07-2009 at 07:14 PM. |
05-07-2009, 07:54 PM | #9 | |
Member#: 53455
The way I see it is that messing with cars is pretty entertaining - but it's a TOTAL waste of money - and you're always on the edge of spending way too much only to never be completely satisfied. I may argue you can build a 300hp EJ22 using 'unwanted' nasty EJ22 block, old D heads, and a slopy VF39 turbo. All OEM. All bolt up. An excerise in cheap-skatery and all part of the challenge. Cheap and dirty - but also likely the best $/hp value around. It depends on what you like: 1) wrenching on machines in the back yard on a weekend? 2) impressing men or perhaps even the ladies? 3) small unit compensatoin? 4) Ego boost / bragging rights 5) turbo woosh and driving more power than most cars on the road. 6) Pouring hard-earned after-tax dollars down a hole? 7) The biggest and bestest. 8) Near pointles technical challanges. I'm only interested in 1,8 5 (to a certain extent) and certainly not 6. You, obviously, have different interestes / motivations. |
05-07-2009, 08:32 PM | #10 | |
Member#: 129503
VIC
i have one goal for my car....to make a ****load of power without blowing the bank....i've had the 300hp that your cheap ej22 build could make...and it bores me to tears. Hence I'm going to spend some money to get me to a point where i'm happy (i think 450WHP is a good goal for now)....and when i get there i'm sure that goal will get boring too....and i'll be spending even more money.... I will always drive haggard ass looking subarus (like mine right now) that leak and smoke a bit....and will always try to make the most power for the least amount of money.....you can call that throwing money down a hole....but what the **** is money? you cant take it with you. I dont spend the money i spend on my car (which again is ****ing pennies compared to most people on here) for an ego boost, to impress people(lol my girlfriend hates my car cause it makes her sick) or for any of that other bull**** you assume....i spend it cause i love power.... if you'd actually met me, hung out with the group of guys that are always in my garage tearing something apart, true DIY style, etc you'd realize we're not that different....and you wouldn't have to pull out BS assumptions to try and prove a point.... |
05-07-2009, 07:15 PM | #12 |
Member#: 105104
VIC
That's why I said your builds, while on paper the same, are completely different. Your build cost probably 2g's if not more..? Ej22 hybrid cheap cost like 700 if not less.
Completely different builds costing totally different amounts making different power levels. |
05-07-2009, 07:24 PM | #13 | |
Member#: 129503
VIC
after that i've sort of lost track of how much i've spent lol..... but yeah i agree.....different completely..... if you want to go extra cheap best route is just to turbo the N/A block low boost.....decent power...retarded cheap and reliable if your tune is solid wooot free bumps....somebody has to have one sitting in their subaru graveyard....or some heads and an IM |
Similar Threads | ||||
entire 98 2.5RS dash cheap $400 | rs4buddy | 1993 - 2001 Impreza Specific Parts | 12 | 12-21-2010 03:48 AM |
wtb 98-01 2.5RS or cheap Bugeye WRX | Brock | NWIC Private Classifieds | 17 | 08-18-2008 02:42 PM |
AZ: perfect swap 2000 2.5rs sedan cheap | JohnBlaze74 | Private Vehicle 'For Sale' Classifieds | 0 | 05-24-2008 08:07 PM |
garage sale WRX and 2.5RS parts cheap help me get rid of this stuff | SlaminSuby25RS | Private 'For Sale' Classifieds | 21 | 11-06-2005 02:52 PM |
2000 2.5rs motor cheap!!! | 00rs03rs | Private 'For Sale' Classifieds | 5 | 04-17-2005 10:26 PM |
