08-15-2010, 10:40 PM | #1 |
Member#: 224069
Vehicle:2003 wrx blue |
boost backoff in 4th gear and cel code P0457
I have been getting the cel code P0457 which means evaporative emissions leak (loose fuel cap) for a few months now. I bought a oem subaru gas cap to solve the problem, but i still get the cel. I have read on nasioc about the cel code, and found possible problems could be the ecu needing reprogrammed or loose hoses?
I also just noticed today, i get full boost, but in 4th gear my boost backs off .05 mpa. My thought is maybe i need to reflash stage 2? I have a 2003 wrx with a catless up-pipe and tbe and an ebay turbo inlet.
08-16-2010, 12:53 PM | #2 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
you need to look around the front of intake right by inlet hose,
behind power steering pump & alternator. check for loose hoses.. |
08-16-2010, 12:56 PM | #3 |
Member#: 224069
just checked that before you wrote. I checked the evap solenoid and the t-piece that is known for this problem. They were both tight.
08-16-2010, 02:32 PM | #4 |
Sammo Hung
South East
also check charcole canister under gas filler door.
you can see it from under the car..rear bumper |
08-16-2010, 02:34 PM | #5 |
Member#: 224069
checked that after i wrote on here. Everything looks good but there is one nozzle that appears to be missing a hose.
08-16-2010, 02:43 PM | #6 |
Member#: 70395
..............and that would be the problem. No map disables the P0457 code unless you are deleting the evap system and that would be a custom tune.
08-16-2010, 03:27 PM | #7 |
Member#: 224069
So should i have a cap on that nozzle or where is it supposed to be connected?
08-16-2010, 09:56 PM | #8 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
remove the charcoal canister and have a look around. It's not supposed to be capped.
08-16-2010, 09:59 PM | #9 |
Member#: 224069
Edit, problem solved. Missing nipple has loose hose right next to it
Boost Fluctuation in 4th gear. | Rexwagon03 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 06-04-2007 04:11 AM |
Boost fluctuating in 4th and 5th gears | STIRS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 04-24-2006 09:28 PM |
Boosting Problems in 4th 5th and 6th | STipwrdwgn | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 10-31-2005 01:49 PM |
Stock Boost Levels in each gear and RPM | JoeTX | Newbies & FAQs | 11 | 06-13-2005 11:25 PM |
HELP, car stuck in 4th gear and won't roll with clutch in | silver arrow | Transmission (AT/MT) & Driveline | 10 | 12-22-2004 08:57 PM |
