09-15-2010, 02:14 PM | #1 |
Member#: 211094
Vehicle:03 WRX Wagon rotated holset Hx35!!! |
ej20g block with ej205 heads
I was doing some looking around and saw that the ej20g blocks are closed deck which gives me another alternative to the ej22t block. If i used the ej20g block with ej205 heads and all other ej205 parts, ej205 headgaskets cams, rods, pistons, etc etc, would that work? If my assumption is wrong could some one give me some info to correct that?
Thanks Travis
09-15-2010, 02:41 PM | #2 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
Crankshaft, needs to be phase1. Make sure it's well.. or new if you want. Check bearing clearances if polished crank. That block isn't really that much different from an EJ205. Just use the newer tensioner, etc on the block.
It's kind of like me running the EJ22T block with most everything '06 WRX stuff on top. |
09-15-2010, 02:54 PM | #3 |
Member#: 159682
Vehicle:1995 WRX 2015 F150 |
Most of the EJ20Gs are open deck. Only the very early ones and RAs are closed deck. I'm sure somebody else will reply with more specifics.
You need to use the EJ20G crank, the thrust bearing is in a different spot. Otherwise, yes you can use everything else from an EJ205 and it will work. |
09-15-2010, 05:02 PM | #4 |
Member#: 211094
oh gotcha yea i didnt know that not all ej20g were closed my assumption was all from what i read. Thanks for the info guys. I always love the fact that within 1hr i will more then likely have a answer to my threads. Nasioc is the S**t!
09-16-2010, 06:43 PM | #5 |
Member#: 232940
Do you really need a closed deck?
Similar Threads | ||||
EJ20G Block VS EJ205 | jesterjames | Built Motor Discussion | 16 | 08-02-2010 06:50 PM |
how well does an EJ20G block work with EJ205 heads? | Import03WRX | Subaru Conversions | 3 | 09-26-2009 08:21 PM |
ej257 short block with ej205 heads - Hybrid Setup | 007WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 20 | 01-27-2009 02:53 PM |
Early Legacy RS/GT EJ20G Block + EJ25 DOHC Heads? | DSM_Outback | Subaru Conversions | 11 | 11-21-2007 01:16 PM |
jdm ej20g block with 02 head and manifolds | Otaku64 | Subaru Conversions | 10 | 03-09-2007 02:47 AM |
