12-07-2005, 03:42 PM | #1 |
Member#: 83571
TXIC
Vehicle:2014 Lexus IS 350F Silver/Red |
Boost/fuel cut-off CEL, Stage1 STi
I wanted to get local opinion on an issue I have been experiencing:
Here is my (rather lonely) thread on the 2.5L powertrain forum Thanks
12-07-2005, 04:04 PM | #2 |
Member#: 75821
TXIC
Vehicle:05 12s STi (Sold!) tuned 06 Jetta TDI |
Hmmmmmmmm, if you were catless, I'd say Ah-Ha! But since your stage 1, I say . Good luck. Maybe Mika or somebody all-knowing will chime in.
12-09-2005, 01:32 AM | #3 |
Member#: 83571
TXIC
I have an update:
http://forums.nasioc.com/forums/show...8#post11936678 In a nutshell, I updated to v1.10 of the stage1 93oct map and did not experience fuel cut-off or CELs. I hit 18.4psi (according to the AP) in 5th gear, somewhere around 5500rpm. shutterbug |
12-09-2005, 09:19 AM | #4 |
Member#: 12329
TXIC
Vehicle:2o15 WRX Ice Silver |
Sebastian - target boost for stage 1 map on STi is 16.5psi..... I think you're overboosting, which is not a good thing. May be a function of it suddenly getting cold and the computer not keeping up with the boost control, but I'd keep an eye out.
And get a boost gauge. |
12-09-2005, 10:40 AM | #5 | |
Member#: 83571
TXIC
Now, regarding the boost guage, I am finally convinced that I need one. Do you have any recommendations? I would prefer one that has PSI. |
12-09-2005, 10:42 AM | #6 |
Member#: 12329
TXIC
I've got the OEM one, which is fine. Doesn't read in PSI, but .1+1-tick would be target. You don't have to spring for the fancy ones, since, if it works, it works.
I didn't realize you were running the HWG map, in which case, yes, if you're overboosting, definitely go to the regular map. Oh, and I parked next to you. You should take a picture, it's cute |
12-09-2005, 10:47 AM | #7 | |
Member#: 83571
TXIC
One of these days, we need to get all the subies lined up in the carpark and take a few shots. |
12-09-2005, 10:48 AM | #8 | |
Member#: 12329
TXIC
12-09-2005, 11:12 AM | #9 | |
A. Moderator
Moderator Member#: 21095
TXIC
Vehicle:RIP KTH & LMFH '09 Crystal red Tintcoat |
Me, all-knowing? Now that'd be a sad world to live in! Try putting the stock airbox back on. That could be the cause of it overboosting. PO244 code present? Read your other thread. It could also be the hwg map that you flashed your car with. Try flashing a regular stage 1, 93 octane map on it first before you start yankin' intakes off and putting regular airboxes in. Mika |
12-09-2005, 12:09 PM | #10 | |
Member#: 6408
TXIC
Vehicle:2013 Porsche Carrera White |
12-09-2005, 12:33 PM | #11 | |
Member#: 12329
TXIC
12-09-2005, 12:37 PM | #12 |
NASIOC T-Shirt Crew
Member#: 35509
TXIC
Vehicle:2010 SuperChargedJag Pewter |
I have had the same problem at 23#'s in 5th on the track, turn your boost down quickly.
12-09-2005, 01:54 PM | #13 | |
Member#: 75821
TXIC
12-09-2005, 02:33 PM | #14 | |
Member#: 83571
TXIC
I suppose I can try the LWG map and see if that brings me back to the mid 16's. I am sure my intake may have something to do with it, but frankly I like the Typhoon over Cobb's intake. The Cobb intake doesnt appear to "sit" as well. I think the only reason Cobb say not to use other SR intakes is because they want to sell theirs. There, I put my $0.02... Seb |
12-09-2005, 02:55 PM | #15 |
Member#: 12329
TXIC
I'd just run the stock box. It's plenty great.
12-09-2005, 05:42 PM | #16 | |
Member#: 83571
TXIC
12-09-2005, 05:52 PM | #17 |
Member#: 75821
TXIC
It's not the Typhoon.
12-10-2005, 03:05 PM | #18 |
Member#: 81244
TXIC
Vehicle:2002 My old SN dyslexicwrx |
I have a stock WRX and I am hitting 19 and 20 PSI in 2 and 3 gear! What is going on? I think our Texas cars are not use to the cold! But I got a cell getting on the freeway so I'm sure that means I hit the fuel cut. I just saw this thread but I posted a new one too.
12-11-2005, 08:41 PM | #19 |
Member#: 83571
TXIC
I have an update on my high-boost "problem":
http://forums.nasioc.com/forums/show...8#post11960998 Any comments would be appreciated. If this is considered "cross-posting" let me know and I wont do it anymore. |
12-11-2005, 09:45 PM | #20 |
Member#: 75821
TXIC
see my post in the other thread.
12-11-2005, 09:49 PM | #21 |
Member#: 81244
TXIC
I'm sure people get mad about cross posting but sometimes that is the only way to get the info you are looking for.
If you look at my other post before I got the CEL, I was having the same noise. http://forums.nasioc.com/forums/show...ise+full+boost I think maybe you should replace the vacuum lines. It was only $2 a foot for the good stuff. It may or may not help but it seemed to fix my problem. Matt |
12-11-2005, 11:10 PM | #22 |
Member#: 83571
TXIC
I took out the Typhoon and put in the stock box. Results:
- Car is quiter, although there is still a feint "woosh" to be heard - Still hitting high 17's psi See other thread for details: http://forums.nasioc.com/forums/show...7#post11962217 BTW, I am going to offer my Typhoon for sale since I dont think my Cobb stg1 needs it. It has less than 10K mi on it and is mostly assembled. If you are interested (before I post it up FS, just PM me). Cheers Seb |
12-12-2005, 12:09 AM | #23 | |
Member#: 83571
TXIC
BTW, the Typhoon is on sale: Here is the link to the appropriate thread Last edited by shutterbug; 12-12-2005 at 09:42 AM. Reason: removed price |
12-12-2005, 09:11 AM | #24 |
Member#: 81244
TXIC
I don't have my camera with me today. I will take a pic of it when I get home. The line has a fabric on the outside that is braided and it is the same thickness as the stock. They also have a rubber inter coating. They also fit better or they feel like they do.
12-12-2005, 09:15 AM | #25 |
Member#: 75821
TXIC
Seb, edit the sale price off your post b4 the thread gets locked. I think the link to the sale is o.k. though. ?
Fuel cut off and cel came on | grundle | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 03-03-2007 12:01 AM |
Can the Boost/Fuel cut be turned off with any maps for the 06 STI? | smac | AccessPort | 18 | 10-12-2006 10:32 PM |
Speedometer/CEL = Fuel cut-off problem? (pretty long) | MrAceman | Transmission (AT/MT) & Driveline | 7 | 08-15-2002 02:06 AM |
Speedometer/CEL = Fuel cut-off problem? (Pretty long) | MrAceman | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 08-14-2002 08:31 PM |
