06-01-2008, 11:41 PM | #1 |
Member#: 73737
South East
Vehicle:I've travled 500 mil es to give you my seed |
04STi: BB's in a can sound, slow boost, no power
Was passing in 4th and then I heard a rattle can sound comming from the turbo area. Now under accel I hear it. No power. Sometimes makes boost, even then still no power. I think the turbo took a crap. Idles fine. Rattles a little durring reving, out of gear. A buddy told me a puff of white smoke came out of my exhaust when it happened, but I haven't seen any since. Any thoughts? Time for a green....
06-02-2008, 09:23 AM | #2 |
Member#: 73737
South East
Also, the rattling doesn't get any louder or faster at higher rpms.
06-02-2008, 10:05 AM | #3 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
BBS in a can is how people always describe detonation. Any chance you got some bad gas? How much boost do you run? Mods?
The fact that it doesnt get any louder and comes from the turbo area tells me it may not be det though. |
06-02-2008, 10:44 AM | #4 | |
Member#: 58251
Tri-State
Vehicle:2004 Sti GT35R 530whp @ 27psi |
Sounds like a fried turbo bearing if the car will not make boost. |
06-02-2008, 10:54 AM | #5 |
Member#: 67199
MWSOC
Vehicle:07 8.8@171mph STI 97 RS 8.3@165mph |
....Or a rod bearing.
I wouldn't keep doing that until you find out for SURE. -Jorge |
06-02-2008, 12:52 PM | #6 |
Member#: 167272
MAIC
Vehicle:2004 STi Aspen White |
maybe the flex joint under the turbo blew out and making the up-pipe heat shield rattle even more .... of course if you wastegate arm comes off you won't have any boost
06-02-2008, 09:44 PM | #7 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
the early 04s pinged like a mother .. you on the stock engine managment?
06-03-2008, 03:07 AM | #8 |
Member#: 73737
South East
It's offical, I'm the only NA STi in Florida! On my way to work the car would make a little boost, then, smoke real bad durring shifts. On the way home tonight, more of the same then no more noise and no more sound. I have a 255 pump, FMIC, short intake, halman mbc and a tune. Regular maint. including oil changes and all that stuff. Time for the 07 turbo and ewg.
06-03-2008, 10:23 AM | #9 |
Member#: 140163
MAIC
Vehicle:03 STi hellaflunctional |
how many miles on the turbo when it let go?
06-03-2008, 10:01 PM | #10 |
Member#: 87950
Vehicle:2005 STI Gone....Somewhere in MS |
Be sure and flush out any turbo parts that might have found their way into the intercooler and especially before they find their way into the engine. A turbo is one thing, turbo parts in the cylinders is another.
You've determined that this is the turbo and not the rings or pistons from pre-detonation? While the turbo does have oil going to it I'm not sure what to make of the smoke during shifts except that you usually close the throttle on a shift and that creates more vacuum at the piston which could be sucking up oil if a damaged piston or rings. What ever, Hope you get it running better and faster than ever soon. Hwy61 |
06-04-2008, 02:45 AM | #11 | |
Member#: 73737
South East
06-04-2008, 02:42 AM | #12 |
Member#: 73737
South East
06-04-2008, 12:49 PM | #13 |
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
Did you check everything make sure it's all hooked up?
06-04-2008, 01:20 PM | #14 |
Member#: 60142
Vehicle:2011 WRX Grey |
It's pretty unusual for a street turbo to lock up without any prior warning (i.e., oil smoke in the exhaust). You're getting zero boost? That's pretty odd, amigo. I'm not saying the turbo isn't dead, but have you checked all your pre-turbo (manifold, up-pipe) and post-turbo charge-pipe connections?
06-04-2008, 09:18 PM | #15 | |
Member#: 73737
South East
06-04-2008, 09:37 PM | #16 |
Member#: 94070
South East
Vehicle:05 LGT PSM |
You may want to pull the TI off the turbo and check the impeller shaft nut. My friend described the same noise and we was checking his car and found the nut was only on by one thread. I took it off by hand.
We tried replacing the nut, but the damage was already done and the turbo was changed. Oh yeah, the dealer had serviced his turbo about a year before that. They told him they replaced the turbo, Jay-R |
Similar Threads | ||||
low boost no power | 07UGM_TR | Newbies & FAQs | 8 | 02-18-2010 07:11 PM |
hAlp! No power, no boost | ein86 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-15-2008 07:16 PM |
I'm living in a refugee camp, no power, no hot water, and no love from the man. | Mud Pig | Off-Topic | 16 | 04-17-2007 10:17 AM |
uppipe install, now low and slow boost with cold engine - no audible leaks | cartervt2k | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 22 | 10-14-2004 04:52 PM |
marble in tin can sound? | stink | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 27 | 08-15-2004 03:20 PM |
