07-21-2010, 10:26 PM | #1 |
Member#: 244242
South East
Vehicle:2009 Impreza Blue |
'09 2.5i Keyless Entry v. Does not work, HELP!
Hi!
I have an '09 Impreza that enjoys giving me headaches! I did not have any key fobs when I bought the car, so I bought a brand new one on Ebay (which didn't seem to work) and another used one on Ebay (same problem, go figure!). I programmed the Keyfob in many, many, many times and it still won't work. I've changed batteries, and still... doesn't work. I've gone so far as to program the same code in 4 times to clear any other codes (I dont know if that really did anything or not). The car was hit in the front, the main harness plug was disconnected (the clip that holds both ends together broke) but it looks like all the pins are straight and everything is together. The car doesn't have warranty either. Any suggestions? I've poured over hundreds of threads all over the place and I can't find anything that is similar or helpful. Any advice (wires to check, modules to look at, fuses/relays to inspect) would be greatly appreciated! Thanks -Dave
07-23-2010, 12:39 AM | #2 |
Member#: 205698
Best bet, go to the dealer, I know you hate hearing it but they can help you probably way more then we can
07-24-2010, 12:11 AM | #3 |
Member#: 244242
South East
Aye, I was hoping the dealer would be a last option :-(
Thanks for the advice though =) I'm sure I'll end up taking it there if I can't find something obvious over the weekend. |
07-25-2010, 01:33 PM | #4 |
Member#: 244242
South East
Problem solved: Patiently go through the programming sequence four times in a row and ensure that the all the numbers go in right!
Similar Threads | ||||
Interior light does not work... HELP? | Rookie84 | Electrical & Lighting | 12 | 08-25-2006 08:19 AM |
SPT exhaust does not work with 2006 2.5i Imprezas | BlackfeetVI | Normally Aspirated Powertrain | 2 | 03-11-2006 11:42 AM |
Factory Keyless/Security not working - Help! | kellie00 | Car Audio, Video & Security | 1 | 03-25-2005 08:57 AM |
Keyless Entry Flashing Lights Not Working - 04 STi | chorline | Car Audio, Video & Security | 0 | 05-10-2004 06:40 PM |
Keyless entry does not work when WRX is running?? | burton13 | Car Audio, Video & Security | 9 | 10-28-2002 11:51 AM |
