Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2024
Old 02-11-2009, 11:35 AM   #51
thewerxracing
Member#: 141498
Originally Posted by Rodwrx23 View Post
Did you ever swap a new cam sensor in there?
Nope, But I took it out yesterday. It looked to have some garbage (corrosion?) on the end of the sensor. I cleaned it with CRC Electrical Connection spray.
Then, I re-installed it. Immediately it idled better, ran stronger, and got rid of my hesitation from 2000-3000rpms.
Looks like I saved a few bucks.
thewerxracing is offline   Reply With Quote
Old 02-11-2009, 11:56 AM   #52
Rodwrx23
Member#: 170948
That's good. I tried that with mine but it didn't help. Try using some dialectric grease at the connections as well.
Rodwrx23 is offline   Reply With Quote
Old 02-11-2009, 03:47 PM   #53
thewerxracing
Member#: 141498
Well, as it turns out, the sensor is located directly underneath the Oil Fill Tube.
Great.
So, when the tech at the dealership impatiently pours oil, the excess can be more detrimental than we think.
Old 03-21-2009, 05:10 PM   #54
SmokescreenNH
Member#: 204528
1998 Impreza RS coup
Rally Blue Pearl
Hello!
I'm having a p0340 myself right now. Car just had the engine dropped back in and everything is snugged up. I replaced the cam sensor, next up is the crank sensor. getting a big gas smell and she's turning but not firing. any idea guys?
-Red
SmokescreenNH is offline   Reply With Quote
Old 05-07-2009, 07:55 PM   #55
sqc151
Member#: 51432
bump for a great thread. mine just went on yesterday...
pulled 2nd gear and there was the light. so ill be replacing the cam and crank sensor just for the hell of it. car was slow and even way slower with the a/c on. hopefully this helps.
sqc151 is offline   Reply With Quote
Old 05-11-2009, 08:31 PM   #56
NFJ79
Member#: 90750
2000 RS EJ207 Hybrid
2006 BMW K1200S
Great i'm getting the same CEL on my car. Just picked up a new CPS and i'm going to install it here in a few.
NFJ79 is offline   Reply With Quote
Old 06-06-2009, 05:10 PM   #57
NFJ79
Member#: 90750
2006 BMW K1200S
Update: I installed a new CPS last month and it ran fine. Yesterday i got it again. Replaced the CPS, cleared the CEL and it pops back up again. When i start my car it idles a little rough at first and then smooths out as i take off.
Old 04-28-2010, 07:23 PM   #58
the_virus
Member#: 104153
2011 ForesterXT
bringing this back from the dead.
I just had a new 2.0 put in and put around 3k miles on it and BAM!!!. CEL comes on and I get this code.
I replaced the CPS and cleared the code and it ran worse than it did before, barly even started. So I put the old one back in and it was gone. I drove around for a few miles with the old one and without getting on the gas and it was fine. Once I hit over 3500rpm on WOT, CEL flips back on.
I have no clue what is going on. Someone on here mentioned using a small washer as a shim for the sensor but there was never one on there.
Please HELP!!
the_virus is offline   Reply With Quote
Old 04-29-2010, 10:13 AM   #59
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
i had this same problem. cel one night, i ran to the auto store, replaced it, drove home. I took off for work the next day, the car died and wouldnt turn over again without sounding aweful. I troubleshot wires, sensors, and whatever else i could get in to. Turns out, the subaru dealership mechanics discovered the timing belt had jumped teeth on 2 of the cam pulleys. They said it was a miracle i didnt bend a valve. Id bet if you get a the timing looked at, you will save your motor. just my experience with this CEL.
jakedademon is offline   Reply With Quote
Old 04-30-2010, 12:27 PM   #60
the_virus
Member#: 104153
2011 ForesterXT
will have to try this.
Old 05-06-2010, 09:19 PM   #61
GiAANT
Member#: 184331
2002 EWG vf39'd wrx
Slammed WRB -_-
i got this code, and now hen i start my car it sounds like horrible knocking. bringing it to the mechanic tommoro for them to check it out. CAr wont even start now
GiAANT is offline   Reply With Quote
Old 05-07-2010, 02:47 AM   #62
NFJ79
Member#: 90750
2006 BMW K1200S
A bad alternator will also cause this CEL. This happened to me.
Old 05-07-2010, 12:20 PM   #63
HQuakers
Member#: 233454
1984 Shoe Leather
Sounds like the timing belt? Don't try and drive it...flatbed it to the mechanic.
HQuakers is offline   Reply With Quote
Old 05-07-2010, 03:36 PM   #64
GiAANT
Member#: 184331
2002 EWG vf39'd wrx
Slammed WRB -_-
i just had my timing belt replcaed, it might have snapped- 4k miles ago, did the gates timing belt kit and water pump
Old 08-10-2010, 05:13 PM   #65
HKS_WRX_STI
Member#: 174941
2015 WRX
WRBP
^^ any updates on your car??
i had the p0340 pop up the other day after camshaft and timing belt install on my car and i got a ridiculous knocking noise as well
HKS_WRX_STI is offline   Reply With Quote
Old 04-29-2013, 01:24 AM   #66
subaruwrx91
Member#: 353290
I recently got a CE light code and it threw me the code P0340 and it says camshaft position sensor A circuit bank 1 or single sensor. I have a 02 Subaru wrx impreza. I recently ordered a new sensor, but I would like to know what the problem could be. Also, I'm having a hard time identifying where the camshaft position sensor is at. Can someone please pinpoint the location for me? Any help will be appreciated. Thanks!
subaruwrx91 is offline   Reply With Quote
Old 05-05-2013, 09:33 PM   #67
Mcgregordm
Member#: 354691
Help
I am also having problems with my car it was running fine as I was driving back to my house I shifted from first to second in between gears I lost engine power and couldn't get it to start again at idle with the throttle down and 3ooo rims I could get it to run but had a little Dark smoke coming out started throwing misfire codes on all four and a running rich code. After I got it home I couldn't get it started at all I disconnected the mass air flow sensor and it will run first turn of the key but back fires I replaced MAS and still nothing. I need help I also replaced plugs with no difference and put fuel cleaner in. Everyone keeps saying ins my ignition coils or cam sensors. Would like to get some more input before I start replacing other pointless stuff.
Mcgregordm is offline   Reply With Quote
Old 05-21-2013, 02:06 PM   #68
ibyu4dola
Member#: 194732
Has anybody gotten this code with a backfire? I recently took my 04 sti to the subaru place to put in a new clutch. When I got it back, my ac wasn't working and the engine would bog down then backfire and throw the cam position sensor code. Car seems to run fine other than random bog/backfire combo. 85k miles on it.
ibyu4dola is offline   Reply With Quote
Old 05-22-2013, 12:10 AM   #69
Derek23
Member#: 328250
2006 STi
I've had this problem so I reflashed the ECU and it went away for like 2 months up until I changed the sensor completely
Derek23 is offline   Reply With Quote
Old 05-22-2013, 12:42 AM   #70
mickey .e
Member#: 262275
I've heard that it seems to happen when the timing belt stretches.
Change timing your belt to pink sti type
mickey .e is offline   Reply With Quote
Old 05-22-2013, 08:00 AM   #71
rapa
Member#: 230077
I have this cel some times... maybe once or twice a month...
just changed the timing belt.. and nothing changed...
last week i cleaned the plug contacts.. still testing if it's gone
rapa is offline   Reply With Quote
Old 09-30-2013, 05:25 PM   #72
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I got the P0340 about two months ago on my 08 LGT. Pulled the connector off and found a corroded terminal that had broken off. Replaced the sensor and clean coneector. Car was fine for two weeks then tripped the light again. I cleared the light and it stayed off for 3 weeks. Last week the light tripped again and I couldn't refire the car till a hard code set and car was in limp mode. I again cleaned terminals and inspected the wiring and sensor, cleared code and was fine for a week, today light tripped and comes right back on after clearing. Like most car will not start, smells like fuel, knocks, backfires and such till a hard fault is set and car goes in limp mode.
I also checked the oil level and adjusted just to rule out low oil effecting the AVCS.
Has anyone had sucess shimming the sensor or moving it closer?
I am starting to think its more of a mechanical problem than electrical.
CUNNINGHAM is offline   Reply With Quote
Old 10-06-2013, 09:23 AM   #73
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Update:
I ran a lab scope on the cam sensor and found a significant amount of noise coming from the sensor as well as very low voltage output from the sensor. I swapped in a known good sensor and the car ran perfectly, pattern was clear and voltage was normal. Replaced the sensor the other day and all has been well for 150miles so far.
Old 10-06-2013, 05:06 PM   #74
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
I had this code replaced the sensor and was fine but try cleaning the connector first
alexandern05 is offline   Reply With Quote
Old 11-12-2013, 05:27 PM   #75
SubNub
Member#: 53603
2004 EJ207 WRX
Add me to the list of cars with this P0340 CEL problem. Mine is a 2005 JDM EJ207 engine swapped into a USDM WRX. So far I know this:
1. It threw the CEL after the car sat for 3 days. It would barely start and barely IDLE. Only thing that kept it running was the warmup idle. Above 2kRPM, the engine was perfectly smooth.
2. After swapping in the EJ207, my USDM alternator has made a whining noise that is RPM dependent. It's NOT the A/C idler pulley as I have changed that.
3. I removed the battery side Cam Position Sensor, cleaned the sensor, cleaned the connector with MAF cleaner and applied dielectric grease to the connector. It was better for the first start but I think this was likely due to removing the battery which reset the ECU and cleared the code.
4. Shortly after cleaning the sensor connection, it threw the CEL after I changed my oil and had been charging my iPhone and running the radio for entertainment during the change (~1 hour taking my time) with the key on accessory. The idle again was very choppy but seemed to resolve after starting to drive. I could feel hesitation at 2K RPM for a moment in second gear though. Everywhere else felt fine.
Conclusions:
A. I theorize that I only seem to have an issue when the charge on my battery is low. I believe my alternator may not be putting out ample voltage due to the whine, especially below 2k RPMs.
B.The CAM Position Sensor must be very sensitive to electrical voltage, interference etc.
i. I've seen people say they fixed the issue with a grounding mod.
ii. I've seen others who have done the grounding mod but have a whining alternator also experience the problem
So, what do you guys think? I don't have a multimeter handy at the moment to check things out but it seems like a low battery may be at least part of the equation! I never had this issue on my USDM EJ205 though...Is it possible the sensor only becomes this sensitive to electrical disturbances when the sensor is failing?
SubNub is offline   Reply With Quote
ECU for MT 02 WRX that doesn't have the cam position sensor problem SW00P_G Private 'Wanted' Classifieds 3 07-30-2003 11:29 AM
Cam Position Sensor SHIELD? metoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-10-2003 10:38 PM
Cam Position Sensor CEL fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-01-2002 06:11 PM
Cam Position Sensor Fix? downshift1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-07-2002 04:06 PM
Help w/DTC's P0335 and P0340 Crank/Cam sensor malfunction Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2002 08:41 AM
