07-03-2004, 08:56 PM | #1 |
Member#: 21965
Vehicle:2002 WRX V-mounted 40R...what |
Misfires up the wazoo
I just installed some 785cc injectors, and I am pulling misfire codes from all 4 cylinders. I am running a UTEC, the latest version with the fuel map scaled for the 785's. A wide band is on the way, but is it possible that I am still running way too rich? or does it have something to do with the ignition system. Any suggestions for possible solutions? Thanks.
-Nate
01-30-2005, 12:31 PM | #2 |
Member#: 26179
Vehicle:2002 2.5 hybrid--aps Silver |
how did you end up fixing your problem--I have the same
Mike |
04-16-2005, 02:25 AM | #3 |
Member#: 70562
Vehicle:2006 Jeep TJ |
So far I think the answer is deal with it? I have these same horrible injectors, I wouldnt even wish them on Satan to tune.
04-17-2005, 01:59 AM | #4 |
Member#: 46399
Vehicle:0000 Knows nothing, about nothing. |
bad mouthing UR 785s?! no problems with mine, make sure your stock ecu is flashed with newest firmware
04-17-2005, 02:14 AM | #5 |
Member#: 37731
to rid yourself of the misfires, before starting your car, put it to the "ON" position. wait about 5 seconds, then turn on.
remember, the CELs will only go away after about 3-5 starts after no misfires detected, so it might not seem to work at first. also- probably want to check into getting new plugs. those might be fouled. <- uses UR 785cc injectors, with one step colder plugs, with the "5 second rule", and has no misfires anymore. |
04-17-2005, 03:09 AM | #6 | |
Member#: 60794
Vehicle:2007 Solstice GXP |
04-17-2005, 07:47 PM | #7 |
Member#: 55811
^^^ weird...i dont get them at start up i get them at random times...but NOT at start up. Will the 5 second rule help me too????
04-18-2005, 07:02 AM | #8 | |
Member#: 37731
Similar Threads | ||||
Help with greasing up the bushings | kmper02 | Newbies & FAQs | 1 | 06-02-2010 03:52 PM |
Misfiring up the A! | turbowgnWHAT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 12-09-2007 12:19 AM |
Whiteline out the Wazoo | TB RACING | Suspension/Brakes/Handling | 38 | 01-10-2005 05:09 PM |
Durango, CO sightings up the wazoo! | Evil-Mastermind | General Forum Archive | 7 | 10-10-2000 09:18 PM |
