View Poll Results: do u think it would work | |||
yes this is a good idea | 11 | 14.47% | |
no this is a bad idea | 28 | 36.84% | |
are u stupid? | 37 | 48.68% | |
Voters: 76. You may not vote on this poll |
04-15-2006, 03:11 AM | #1 |
Member#: 39832
South East
Vehicle:02 +06 speed,r180 blue |
a safe way to eliminate turbo lag?
ok i was wondering...and i need some info....and opinions......if this is a stupid idea tell me! what if i took a nitrous bottle (filled with compressed air)an a line to the uppipe directly under the turbo going into the hot side of the turbo?....this would be usedto eliminate tubo lag down low...i think this would be a great expierment?thoughts?
04-15-2006, 03:28 AM | #2 |
Member#: 111641
Vehicle:2020 CWP STi RIP - 06' WRX w/ 6spd |
its worth a try...ALTHOUGH...nitrous tanks hold relatively low amounts of pressure and volume....a SCUBA tank would be MUCH better for this as a standard tank can be pressurized to 3000psi and 80lbs.
04-15-2006, 03:31 AM | #3 |
Member#: 39832
South East
imma start gathering parts for this project next week
04-15-2006, 03:32 AM | #4 |
Member#: 82378
South East
Vehicle:<--- Hot Donuts Now |
what turbo are you running? seriously, is the lag that bad?
04-15-2006, 03:32 AM | #5 |
Member#: 39832
South East
vf22..............
04-15-2006, 03:42 AM | #6 |
Member#: 82378
South East
dude, come on... its not that bad. i wouldnt risk effin up my turbo to try this. how about we swap....... vf22 for td04...
04-15-2006, 03:43 AM | #7 |
Member#: 112124
Vehicle:1998 Forester S Green |
would this help spin the turbo or would it just put more air into the engine
04-15-2006, 03:45 AM | #8 |
Member#: 39832
South East
it would just help the turbo...cause its going only through the exhaust
04-15-2006, 03:46 AM | #9 | |
Member#: 39832
South East
04-15-2006, 04:03 AM | #10 | |
Member#: 82378
South East
or just keep it in the powerband.... honestly, if you dont care if you mess it up, go for it. i dont know if there would be any danger of the exhaust gas coming up the line to the tank would there? not that it would combust (fire) but rather it might explode from the constant increase in pressure if your not using it. |
04-15-2006, 04:12 AM | #11 |
Member#: 39832
South East
the pressure would be no more dangerous than nitrous....i would be using a solinoid ......
04-15-2006, 04:20 AM | #12 |
Member#: 84498
Vehicle:2003 Impreza WRX W raith R eady B lue |
Why ask? It seems if you don't here what you want, your probably going to convince yourself anyway.
04-15-2006, 04:42 AM | #13 | |
Member#: 95459
Vehicle:the activity level of AutoX is > than F1 |
04-15-2006, 04:44 AM | #14 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
....deeeeeeeeeeeeeeeeeeeewwwwwwwwwwwwwwwwwwwwwwd.. .....ya should be able ta toon that 22 ta get full boost under 3k
04-15-2006, 04:46 AM | #15 |
Member#: 68758
SCIC
Vehicle:15 STi LE |
coat/wrap, port'n'polish, tune. as long as you run an appropriate exhaust, those will make it spool as close to a twinscroll as you could possibly hope for... without getting a twinscroll.
04-15-2006, 11:13 AM | #16 |
Member#: 99280
Vehicle:2006 WRX LTD OBP |
the lag on that shouldnt be much to begin with and the amount of air that is going to create wont be enough imo to generate a sufficent amount of boost. imo your just going to cut holes everywhere and not find it worth the efforts in the end.
:tup: to innovative thinking though. you did give me an awsome idea though... will discus more about it once i work out the details. |
04-15-2006, 01:40 PM | #17 |
Member#: 103392
I don't think it would be such a good idea, your exhaust gas will be hot as well as your turbo, and up pipe. When you inject your air it will come in really cold (Joule Thomson Effect). This will thermally shock your up pipe and turbo, and could take away energy (pressure) from your hot exhaust gases Before you go embarking on a expensive experiment, just do some quick calculations. Do you even know what the exhaust gas pressure is infront of the turbo with your current set up as rpm and load varies? What about behind the turbo? I think this topic may have been discussed before, maybe try search.
04-15-2006, 02:08 PM | #18 |
Member#: 97426
RMIC
Vehicle:2002 WRX PSM Stage Deuce!!! |
If he wants to do it, let him. If it works...GREAT!!! We'll have another mod to add to the list. If it doesn't work... he'll just be getting the "I told you so".
04-15-2006, 02:15 PM | #19 |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
supercharge it, that's the best way.
04-15-2006, 02:16 PM | #20 |
Member#: 86997
BAIC
Vehicle:2002 Impreza WRX Silver |
I vote for it not doing much....if anything
04-15-2006, 02:17 PM | #21 | ||
Member#: 94945
04-16-2006, 02:08 AM | #22 |
Member#: 34619
Vehicle:555 WRX World Rally Blue |
Unless your driving the batmobile, the lag is not that bad. I learned to adjust my driving style when I got my first Turbo
04-16-2006, 02:14 AM | #23 | |
Member#: 105404
NESIC
Vehicle:2006 FPGreenSTI SOLD 04 GMC 2500HD Duramax CC |
04-16-2006, 02:25 AM | #24 | |
Member#: 3097
NWIC
Vehicle:2013 Ford Focus ST Performance Blue |
I was thinking the thermal difference between the hot exhaust gas and the extremely cold compressed air would be very bad. You have that turbo running hot, and blast it with very cold air, and bad things are sure to happen sooner than later. Like cracked turbo housings, vanes, all that expensive stuff. I say do NOT do it, but if you do, let us know how bad it goes. |
04-16-2006, 02:29 AM | #25 |
Member#: 62595
SCIC
Vehicle:04 WRX Cobb S2 World Rally Blue |
its clearly a bad idea in many aspects. If this problem could be solved so easily then why dont you think car manufactorers and racing companies (with multi million dollar research and devolupment teams) havent tried this already? Its not like you're the first person to come up with this idea. Try if you'd like but you know what the end result will be.
best path to eliminate turbo lag in a stock 2 liter WRX? | alacrity024 | Off-Topic | 116 | 05-01-2006 10:26 AM |
easiest way to reduce turbo lag? | DesperodoZ | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 08-24-2005 06:06 PM |
ways to lessen turbo lag without removing cats? | ebr0t | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 08-20-2002 05:53 PM |
Best way to reduce turbo lag on a budget? | macboat | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 05-16-2002 09:08 PM |
Best/Cheapest way to reduce turbo lag on the WRX? | gooey | Newbies & FAQs | 14 | 11-06-2001 10:31 PM |
