11-28-2006, 01:39 PM | #1 |
Member#: 113666
Vehicle:60' all over you |
What DP do you run with your 06 wrx/sti?
still looking for info on what dp's you are running. thanks
11-28-2006, 01:45 PM | #2 |
Member#: 115819
Vehicle:2006 vf39 R0mRa1DeR Darknessess Wagon |
turboxs 4" bellmouth... as part of their stealthback.
As far as fitment goes, its ok at best... you have to move the ac drain line, hack the hell out of the heatshield, and I have a small exhaust leak at the dp to cat joint because the dp sat about 1.5" below the cat before bolting everything up, it also sits a little low at the cat because of this... |
11-28-2006, 01:56 PM | #3 |
Member#: 90516
Vehicle:2007 WRX, R.I.P.06TR Satin Pearl White |
PDE catless dp.
11-28-2006, 02:19 PM | #4 |
Member#: 126112
TXIC
Vehicle:93.5 Toyota Supra Red |
ERZ 3in Downpipe
11-28-2006, 02:25 PM | #5 |
Member#: 100834
BAIC
Vehicle:2006 Subaru STI Steel Grey Metallic |
cobb catted downpipe
11-28-2006, 02:42 PM | #6 |
Member#: 96075
SCIC
Vehicle:'16 Crosstrek Smurf Blue |
titek catless
11-28-2006, 02:53 PM | #7 |
Member#: 113666
11-28-2006, 02:58 PM | #8 |
Member#: 90186
Vehicle:2006 Impreza WRX Ltd 2011 Audi S4 |
11-28-2006, 03:19 PM | #9 |
Member#: 126112
TXIC
Its fits fine with some minor adjustments. it bolts up to the fpgreen just fine, the only problem will probally have to matting it to the catback,but with right exhaust gasket and some copper spray your fine.
i wonder if it 3in, or say they say it is. |
11-28-2006, 04:02 PM | #10 |
Member#: 107000
Vehicle:2015 BMW X1 |
11-28-2006, 04:22 PM | #11 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
helix catless Dp
11-28-2006, 04:25 PM | #12 |
Member#: 26226
Vehicle:2004 Impreza WRX WR Blue |
ignore my post.
Last edited by DVN428; 11-28-2006 at 04:26 PM. Reason: posted in the wrong thread by accident |
11-28-2006, 04:39 PM | #13 |
Member#: 109763
Vehicle:2006 aw TR [ GO PETTER GO! ] |
11-28-2006, 06:12 PM | #14 |
Member#: 112948
SWIC
Invidia V3 FTW!!!!
11-28-2006, 07:08 PM | #15 |
Member#: 119633
Vehicle:10 SWP STI 18 CWP STI Type RA |
Noob alert...
Are we better off with the catted version to prevent boost creep? I will be running an AP @ stage 2 and I've been trying to find a solution for the boost creep issue on the 2.5L. I found that it is best prevented with either a catted DP or a more restrictive cat-back (or axle-back) I have an Espelir 3" catback so I was going to buy a catted DP to avoid any problems....am I right or am I missing something? |
11-28-2006, 07:13 PM | #16 |
Member#: 106244
SCIC
Vehicle:2006 WRX vf48 |
11-28-2006, 07:19 PM | #17 |
Member#: 124236
SWIC
Vehicle:2006 WRX Built EJ257 Version 8 Twinscroll |
going catted MAY help with boost creep, but it doesn't always prevent it. i had a cobb catted dp running stg2, i still get creep =\
11-28-2006, 08:58 PM | #18 |
Member#: 132779
Vehicle:2006 STI Aspen White |
Invidia V2 Catless
11-29-2006, 12:46 PM | #19 | |
Member#: 109763
11-29-2006, 12:50 PM | #20 |
Member#: 104433
NESIC
Vehicle:2016 Mercedes - GLE past cars-06 STI /13 WRX |
Just curious:
How does that Cobb down-pipe and SPT catback sound??? Also how was fiment? Thanks |
11-30-2006, 08:48 PM | #21 |
Member#: 121561
SCIC
Vehicle:2006 STG.2 WRX Pearl blue |
Im running a MadDad metal v2 catted DP with divorced wastegate and and it is mated to a Cobb catback, runs strong and sounds great definately not real loud either.
12-01-2006, 03:44 PM | #22 |
Member#: 35876
SCIC
Vehicle:2008 Legacy GT SpecB Grey |
hks45
12-01-2006, 04:24 PM | #23 |
Member#: 124236
SWIC
12-01-2006, 08:46 PM | #24 |
Member#: 119117
AKIC
Vehicle:06 wrx sgm SGM |
12-01-2006, 08:48 PM | #25 |
Member#: 119117
AKIC
What mods do you run with your Cobb stg-2 Map? | WRBlueberry | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 05-19-2010 09:57 PM |
What DP do you run with your Cobb CBE? | 02bugeyeWRX | Newbies & FAQs | 7 | 05-03-2009 12:11 PM |
What DP do you run with your Cobb CBE? | 02bugeyeWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 05-02-2009 10:30 PM |
What size Injectors do you run with your 20 g turbo? | plus plus plus | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 02-18-2006 12:38 PM |
What springs do you wear with your stock WRX struts? | miraclemonkeywrx | Brakes, Steering & Suspension | 11 | 03-11-2004 11:23 AM |
