04-10-2011, 12:54 AM | #26 |
Member#: 277309
hope this helps
05-25-2011, 09:56 AM | #27 |
Member#: 163991
lets say keeping the stock lines from trunk to engine bay...
600Lph pump, just adding aftermarket RAILS and keep engine bay to engine STOCK with the stock in line system, what will be the loss??? or adding the FULL FUEL RAIL SYSTEM, kepping trunk to engine bay stock, adding aftermarket parallel fuel lines to rails, all after market... the loss will be? |
05-25-2011, 10:57 AM | #28 | |||
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
05-25-2011, 11:37 AM | #29 |
Member#: 38909
Vehicle:03 4EAT Wagon 06STI Dom 2.5 XTR 355/372 |
I do know that Maxwell Power will not sell you a parallel kit. They told me that the will not run parallel on their cars. And they won't sell anything that they would not run on their own cars.
I think that says lots for series set-ups. |
05-25-2011, 11:54 AM | #30 | |
Member#: 163991
and what about the LOSS SUICIDAL EXPLAINED US? d@mn im confused... |
05-25-2011, 12:00 PM | #31 |
Member#: 51961
RMIC
They don't keep it stock, they keep it in series. You can still plumb aftermarket rails and aftermarket lines in series instead of parallel. You'll need to go with larger lines to keep the pressure drop low though, and you'll still never get the pressure differential as low as with a parallel setup.
05-25-2011, 12:15 PM | #32 | |
Member#: 163991
any experience with after market KITS? perrin, agency power... i dont wanna change FPR now.. my stock one my handle... |
05-25-2011, 02:58 PM | #33 | |
Member#: 38909
I have no idea about the pressure drop. Suicidal knows way, way more about this stuff than I do and is a better resource. Just stating what I was told by a very reputable engine builder/tuner. It is not to say that parallel won't work or even has less pressure drop. I was hoping that maybe they (maxwell power) would chime in. |
10-17-2013, 06:04 PM | #34 |
Member#: 190729
Pressure differential is moot and frankly I'm surprised anyone thinks it exists.
Here's why: 1. From the first injector to the last, the amount of fuel being used is less and less in steps. So from the beginning, you have less flow which lowers any potential for pressure drop. The largest demand on the fuel system is the line in the frame rail. Once it hits the first injector, the demand is less, which means flow rate is less, which means pressure drop is less. 2. The fuel system does not flow ONE flow rate through the whole system evenly. 3. The fuel pressure regulator is at the end. So if it sees a drop in fuel pressure at the last injector, it's going to bypass LESS fuel, which therefor keeps the pressure more balanced from beginning to end. Lastly: Nobody has ever had misfire issues from Series lines. Many people have had misfire issues with Parallel lines. Nobody has been able to prove any benefit with Parallel. Many people have experienced uneven fueling from cylinder to cylinder with parallel. The first year subaru implemented parallel rails, TONS of misfire issues. Just look up any 08+ STi. Parallel fuel rails result in large differences in rail temperature and fuel temperature. Fuel temperature is a very important part of fueling (how important? 50C is over 6% fueling. 6% is a lot when we're concerned over 1 or 2% see the last article http://www.injectordynamics.com/NewsletterFeb2013.html). Someone mentioned that by going parallel you lower the speed of the fuel in the rail by half. This is true, in fact in extreme cases it's more than half. HOWEVER, that's not ideal. You want the highest velocity you can get away with without creating a back pressure and pressure drops. Higher velocity means you do a better job of balancing rail temps. Balanced rail temps means balanced fueling. Nice fat rails with a large quantity of fuel going through them would be nice too, but too big and fuel have such a slow fuel flow that you'd once again establish large changes in fuel temp from rail to rail. So what you guys are doing is creating a problem while trying to prevent a problem that doesn't exist. If you go series with injectors in the wrong order, you could have issues. However, our firing order is linear down the fuel rail. Subaru H4 is the only engine ever created to do this. The order of fuel feed should be opposite of engine firing order. This means that the fuel injectors are always firing towards the source of fuel. That means that you aren't going to get any lack of fuel from the load on the rail. In V8's, I4, I6 etc, the firing order is not in a linear fashion down the rail and it is absolutely important and correct to go parallel with your fueling. Subaru isn't like any other engine out there. Any lack of fuel is from a pump that is too small or from a rail system that is too small to handle the flow rate. It isn't from being series. Last edited by Maxwell Power; 10-17-2013 at 06:10 PM. |
10-27-2013, 05:29 PM | #35 | |
Member#: 285083
Vehicle:2006 STi WRB |
One other way I think you could possibly better this parallell setup would be to run a bigger volume, lets say 8an, feed line directly off the fuel pump hanger then use a 8an to 6an nice Aeromotive Y block in the engine bay, which (I think) would come close to matching the fuel velocity on both 6an split feed lines now going to the rails with the main velocity on the bigger volume 8an main feed line, which would then also keep the main line fuel temperature pretty much the same temperature as the fuel going to rails even after being split by the Y block. Does this theory seem correct? I could be completely wrong as I have not done any real testing and im defiantly not an engineer lol. Either way this is an interesting subject to discuss and I think the main problems people report after doing parallel setup is caused by a half-assed setup. Seems like its much easier for the average person to screw up putting together proper parallel setup and just end up making matters worst like you said. |
10-27-2013, 06:14 PM | #36 |
Member#: 216984
Vehicle:1996 Impreza outback Green |
I have a friend here who has a 04 wrx wagon stock 2.0 stock engine with an upgraded intake, downpipe and 3 inch exhaust coupled with a custom tune done by him. The maf is the stock used one. Everything else is stock.
He had bought a set of perrin equal length parallel fuel rails and lines and wants to put them on his engine. After reading this thread and the info that Dom shared which I understand the basic concept of, I believe that my friend had wasted his money in a round about way. He is putting out probably around 255 hp maybe? At this point, would the stock lines and rails still be fine, or can he upgrade his lines but keep the rails? |
10-27-2013, 11:14 PM | #37 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
He in no way needs any fuel system upgrades for that power level.
10-29-2013, 02:39 PM | #38 |
Member#: 190729
Stock rails are good to 500whp.
10-29-2013, 02:54 PM | #39 |
Member#: 349361
Vehicle:2013 STi SWP |
10-29-2013, 03:33 PM | #40 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
My understanding is the stumble can be tuned out adjusting the fueling compensation tables. Also reroute how the hoses run to and from the stock rails. Another is a older style sti, or aftermarket fuel pressure regulator.
10-29-2013, 04:09 PM | #41 |
Member#: 349361
Well tuning it out couldn't be done. I tried the 3' fuel line mod, ams fpr kit, and the Lucas. The Lucas has been by far the best. The other two didn't do ****. Ams fpr kit came w a fuelab aftermarket fpr. Didn't work. The true solution is rails. I been talking w NOMORESHANKS. he did rails and boom! It was gone
10-29-2013, 06:05 PM | #42 |
Member#: 190729
That's great. However, I was talking to the other guy about his 255hp car with upgraded fuel rails.
10-30-2013, 12:14 AM | #43 |
Member#: 216984
10-30-2013, 12:16 AM | #44 |
Member#: 190729
I see no advantage at all. I've taken apart engines running over 500whp for years on all stock lines and had no differences in anything on any cylinder. I just don't see what kind of advantage you think you'd get... if it isn't a restriction or limitation in any way, what can you possibly gain?
10-30-2013, 03:48 AM | #45 | |
Member#: 216984
Thanks |
10-30-2013, 12:28 PM | #46 | |
Member#: 275500
Vehicle:1992 SVX |
10-30-2013, 01:47 PM | #47 |
Member#: 358782
Vehicle:2013 STi DGM |
I just want to say thank you to maxwell power for chiming in on this and dropping some serious knowledge that honestly everyone should know.
10-31-2013, 05:21 AM | #48 |
Member#: 285083
Id rather run the proper sized lines to keep pressure drop to a minimum, it will allow your whole fuel system to run more consistent and efficient, especially when using an intank pump because they drop off in flow significantly as the pressure demand goes up.
Notice how some people can magically make ~50whp more before "running out of injector" on the same size injectors,fuel, and pump? Sure there could be alot of other factors involved but pressure drop from total line size could be a big part. |
10-31-2013, 04:23 PM | #49 |
Member#: 190729
No. It does not. Parallel would be appropriate, but every step should be taken to maximize flow though the rails evenly and quickly to help control temperature.
10-31-2013, 04:26 PM | #50 | |
Member#: 190729
Similar Threads | ||||
Parallel Fuel Lines Anyway to Log fuel to each cylinder? | kakarotoni | AccessPort | 1 | 08-26-2009 12:54 PM |
would the series to parallel fuel line conversion for RS work on WRX? | whiterabbit | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 02-22-2004 01:16 AM |
Series to Parallel Fuel Mod or New Fuel Rails? | Need4Boost | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 04-10-2003 10:05 AM |
Question on finding parts for the series to parallel fuel rail mod | Legacy777 | Normally Aspirated Powertrain | 1 | 02-24-2003 09:06 AM |
DIY Series To Parallel Fuel Delivery Modification | thoughto | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-28-2002 12:19 AM |
