01-08-2012, 05:19 PM | #1 |
Member#: 37359
Vehicle:2003 WRX |
Root cause of raw fuel smell issue?
First, I do not have the fuel leak for which the SOA fix applies. But, I did just get a fuel leak from a different hose on the days when it got very cold in PA.
Does anyone know why cold temps caused the original leak? I want to see if the same root cause would apply to my leak (from a piece of non-OE fuel hose that connects to the fuel filter "in"). I was fine during the warm months and seems fine again now that we're in the 40s. Thanks.
01-08-2012, 09:31 PM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
Well - the fix is to shorten the hard line and lengthen the rubber hose - based on that, I would guess that as it gets cold, the rubber line gets stiff - if it's short, there isn't enough material there to deal with engine vibration, and the seal is lost, resulting in a leak.
I would check the fuel line and make sure it's not scored on the inside or something, then try a different clamp to hold it in place (maybe the tubing is too large an id and when you crank down the clamp, it results in a leak?) |
01-08-2012, 11:44 PM | #3 |
Member#: 37359
Vehicle:2003 WRX |
Thanks. Since my issue is the rubber hose connection from the firewall to the fuel filter, engine vibration isn't an issue. I've re-tightened the clamp, but I'll have to wait until it gets cold to see if it starts leaking again.
Similar Threads | ||||
Raw Fuel Smell Log | fluffybunny | Warranty Issues & SOA Problems | 3411 | 01-10-2021 05:16 PM |
Raw Fuel Smell/Leaking Fuel Line on WRX | pumpkyn | Rocky Mountains Impreza Club Forum -- RMIC | 40 | 10-01-2020 06:48 AM |
Raw Fuel Smell Inside Cabin - WRX | Kenneth2000 | Warranty Issues & SOA Problems | 13 | 12-21-2012 10:28 PM |
Raw Fuel Smell.... | Rebellion | South East Region Forum | 7 | 01-25-2005 09:48 AM |
Raw Fuel Smell | Giljorak | Rocky Mountains Impreza Club Forum -- RMIC | 10 | 03-08-2002 07:03 AM |
